View Poll Results: samsung phone no imei and no baseband | |||
Software | 265 | 53.00% | |
Hardware | 235 | 47.00% | |
Voters: 500. You may not vote on this poll |
06-29-2014, 20:22 | #61 (permalink) |
Freak Poster Join Date: Aug 2011 Location: New York City
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | |
09-13-2014, 19:19 | #63 (permalink) |
Freak Poster Join Date: Jul 2012 Location: dhaka,bangladesh Age: 39
Member: 1785241 Status: Offline Sonork: 100.1616353:tarekkhl Thanks Meter: 192 | bassbend unknown & imei null,if your phone not enter download mood & mein board is water damage or droped its 100% hardware problem.some times power ic (PMxxxx,MAXxxxx)m CPU+FLASHRAM dasted or unsold made this problem,other ways if the mein board is clein & enterd in download mood its software problem.i am also repaire this problem in use this method meny time.........thanks to all |
12-04-2014, 14:56 | #64 (permalink) |
Junior Member Join Date: Sep 2014 Location: Timergara Dir
Member: 2257228 Status: Offline Thanks Meter: 2 | Hi, Is there any working solution for gt-19505 base band repair.. I have tried some different tactics but none is working. Z3x says no response from the phone.. though i have installed all the drivers.. my device is rooted and still i have that problem.. iEMi null/null if there is any tested solution then post it please.. |
05-23-2015, 14:09 | #67 (permalink) |
Junior Member Join Date: May 2015
Member: 2398189 Status: Offline Thanks Meter: 0 | Let assume it is hardware From existing experience, which part mostly need to be replaced? Any measuring point to determine which parts? If emmc still can read and write no error, can it considered good? Measurement results guided by Service Manual CP_VSD1(C352)=0.9~1.4V CP_VSD2(C353)=1.8V Some cases, I found no that two voltage n some is too low different from guide. After replace baseband ic, it still same low voltage Or somewhere cause it? |
06-11-2015, 08:23 | #70 (permalink) |
Junior Member Join Date: Jun 2006 Location: usa
Member: 299271 Status: Offline Thanks Meter: 4 | for instant i have 2 i9300 both had imei 000xx i tried imei repair on both and end up with both imei null null, i tried a few stock roms for hours but luck dont fix phones. so i found version 4.0 and got back imei to 000xxx root flash qcn problem solved now i need to unroot device and upgrade via ota. |
06-22-2015, 08:33 | #72 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 661195 Status: Offline Thanks Meter: 31 | gt-p5220 dead after flash i have Samsung p5220 tab dead after flash.(I think that bad firmware)now no download mode.i connect to power supply and press power on, it take 0.5 and immediately going to zero. but detecting in device manager as a "CLOVERVIEW" in yellow color.witch tool can repair this problem?or need to replace emmc chip?please help me experts.. Thank you. |
06-22-2015, 14:42 | #73 (permalink) |
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | Sounds like a bad cap. But unlikely. What is the history of the tab.? |
The Following User Says Thank You to concepttheman For This Useful Post: |
06-23-2015, 05:03 | #74 (permalink) |
Member: 661195 Status: Offline Thanks Meter: 31 | here the history. problem was unknown base band.I write a new certificate with octopus box..but problem not solved.after i convert this firmware package with octopus box and write it to phone. AP_P5220XXUBNH2_2412361_REV00_user_low_ship.tar BL_P5220XXUBNH2_2412361_REV00_user_low_ship.tar CP_P5220XXUBNH2_2412361_REV00_user_low_ship.tar CSC_OXA_P5220OXABNH2_2412361_REV00_user_low_ship.t ar GT-P5220_EUR_XX_20130523 writing log INFO : 6/15/2015 9:39:44 AM > To connect GT-P5220 phone you have to perform the following steps: INFO : 6/15/2015 9:39:44 AM > 1. Disconnect USB cable from phone. INFO : 6/15/2015 9:39:44 AM > 2. Go to Menu->Settings->More->About Device. INFO : 6/15/2015 9:39:44 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/15/2015 9:39:44 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/15/2015 9:39:44 AM > 5. Turn on "USB Debugging" option. INFO : 6/15/2015 9:39:49 AM > Selected firmware file: AP_P5220XXUBNH2_2412361_REV00_user_low_ship.oct WARN : 6/15/2015 9:39:52 AM > Please put the phone into Download Mode and connect USB cable. WARN : 6/15/2015 9:39:52 AM > To put GT-P5220 into Download Mode, You have to perform the following steps: WARN : 6/15/2015 9:39:52 AM > 1. Reconnect the battery. WARN : 6/15/2015 9:39:52 AM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 6/15/2015 9:39:52 AM > 3. When phone turns on, press "Volume+" key. INFO : 6/15/2015 9:39:52 AM > Found phone on INFO : 6/15/2015 9:39:52 AM > Firmware write started. INFO : 6/15/2015 9:39:52 AM > Writing PIT section... INFO : 6/15/2015 9:39:57 AM > PIT section has been written successfully. INFO : 6/15/2015 9:39:57 AM > Writing SBOOT section... INFO : 6/15/2015 9:39:59 AM > SBOOT section has been written successfully. INFO : 6/15/2015 9:39:59 AM > Writing PARAM section... INFO : 6/15/2015 9:40:01 AM > PARAM section has been written successfully. INFO : 6/15/2015 9:40:01 AM > Writing DNX section... INFO : 6/15/2015 9:40:03 AM > DNX section has been written successfully. INFO : 6/15/2015 9:40:03 AM > Writing IAFW section... INFO : 6/15/2015 9:40:05 AM > IAFW section has been written successfully. INFO : 6/15/2015 9:40:05 AM > Writing BOOT section... INFO : 6/15/2015 9:40:08 AM > BOOT section has been written successfully. INFO : 6/15/2015 9:40:08 AM > Writing RECOVERY section... INFO : 6/15/2015 9:40:10 AM > RECOVERY section has been written successfully. INFO : 6/15/2015 9:40:10 AM > Writing SYSTEM section... INFO : 6/15/2015 9:44:06 AM > SYSTEM section has been written successfully. INFO : 6/15/2015 9:44:06 AM > Writing RADIO section... INFO : 6/15/2015 9:44:10 AM > RADIO section has been written successfully. INFO : 6/15/2015 9:44:10 AM > Writing PIT section... INFO : 6/15/2015 9:44:12 AM > PIT section has been written successfully. INFO : 6/15/2015 9:44:12 AM > Writing CACHE section... INFO : 6/15/2015 9:44:17 AM > CACHE section has been written successfully. INFO : 6/15/2015 9:44:17 AM > Writing HIDDEN section... INFO : 6/15/2015 9:44:23 AM > HIDDEN section has been written successfully. INFO : 6/15/2015 9:44:23 AM > Firmware writing successfully completed. unfortunately..phone was dead.no download mode.ONLY DETECT AS "cloverview" device in device manager |
