06-23-2015, 02:45 | #1 (permalink) |
Freak Poster Join Date: Aug 2012
Member: 1796117 Status: Offline Thanks Meter: 16 | Samsung S6 G920A - Water Damaged - Can not connect to computer |
07-29-2015, 09:04 | #2 (permalink) |
Freak Poster Join Date: Jun 2003 Location: LZ - Bulgaria
Member: 30940 Status: Offline Thanks Meter: 13 | Almost the same symptoms with an S6 water damaged, few little spots on the PCB, perfectly cleaned, but can't power ON. I make this jumper and it is fine now, maybe this can help you: |
The Following User Says Thank You to symbiah For This Useful Post: |
08-03-2015, 03:04 | #3 (permalink) |
Member: 1796117 Status: Offline Thanks Meter: 16 | I'll be damned.....I made same jumper and have power back to board, was able to get in D/L mode and restore S/W with Odin. Since I have not replaced LCD yet, curious if everything else worked well on the phone after this jumper? Also, how did you ever think to jump power here? I like to learn why I did something, lol. Thank You very much! |
08-06-2015, 11:08 | #4 (permalink) |
Member: 30940 Status: Offline Thanks Meter: 13 | On my phone everything works absolutely well after the jumper, tested. How i manage to made it : first i connect the phone to regulated power supply and check that if i press POWER ON there is no reaction - no current flow. When i put charger always show me charging at 98%, even if battery is disconnected. So i look for some fuse, didnt find, look for schematic, didnt find, check the power ways - the ticker ones, and found this two points as "suspected", check on another board show me zero Ohm between them, on mine was infinity, the rest is history... Wish you good luck! |
