Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
12-31-2010, 02:02 | #1501 (permalink) |
Junior Member Join Date: Aug 2008
Member: 844933 Status: Offline Sonork: +96311 Thanks Meter: 2 | i have vivaz show emergency calls only can you help me ! thanks a lot please catsh me on my email [email protected] |
12-31-2010, 05:45 | #1502 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1480207 Status: Offline Thanks Meter: 0 | Hi guys! I've previously posted in the "24 hours" thread but didn't get a reply. So I'm trying here: I have a problem with my W995. I took my phone apart (completely) to take a look at the flex ribbon (which was probably damaged because my screen was go hay-wire). After assembling the phone, I could not get the phone to power on. I thought I broke the ribbon completely, but it wasn't. Here's why: - On charging / connected via USB, the phone behaves normally (no issues) - When connected via USB (in Mass Media mode) with the phone off, pressing any button results in a pop up message (can't remember what it is, but it is nothing unusual). - Note that pressing the hang-up/power off key also triggers the same reaction. Hence, it is unlikely that the ribbon is broken, isn't it? I tried repairing using SE PC Suite but it always fails. It stops like 10 seconds into the "downloading" phase. Any suggestions? Thanks in advance! |
01-01-2011, 02:02 | #1505 (permalink) |
Junior Member Join Date: Nov 2007
Member: 630929 Status: Offline Thanks Meter: 0 | Hello i have problem with my SE Vivaz.One two time per day my phone block (freeze) i hav to take out battery to fix.Now my question is if i update my soft can i fix this problem.Thanks |
01-01-2011, 18:18 | #1507 (permalink) |
Member: 1478559 Status: Offline Thanks Meter: 0 | hello friend's i am new here i have sony ericsson t610 when i recive and doing call my phone is hang and not working when i try to open blutoth phone hang again my WAP option not working and much more option not working pls tell me what i do if this is software problam then pls told me how i flash it pls give me new firware or flash software thank's. |
01-03-2011, 14:27 | #1509 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | hi i have w995 phone flash ok but no powar on i chak powar saple on 1 or 2 ples .i should i do please help me SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35526403997734] OTP LOCKED:1 CID:52 PAF:1 IMEI:35526403997734 CERT:RED LDR:2009-06-26 15:47 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A082 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2009-06-26 15:48 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A082 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA writing "G:\setool\setool fiel\w595\R3DA026_APP_SW_1205_5129_GENERIC_LD_REDB ROWNBLUE_CID52_49_DB3150.software" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:52 Will flash 814 blocks... ssw file accepted writing "G:\setool\setool fiel\w595\R3DA026_FS_HUTCH_WORLD_LD_REDBROWNBLUE_C ID52_49.software" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:52 Will flash 587 blocks... ssw file accepted using GENERIC phone customization tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/MC_MUSIC_HOOK_3.itm tpa/preset/custom/MC_PHOTO_HOOK_3.itm tpa/preset/custom/MC_VIDEO_HOOK_3.itm tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm tpa/preset/custom/preloaded_config.xml tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm tpa/preset/custom/Customize.xml Elapsed: 158 secs. Elapsed: 7 secs. |
01-10-2011, 09:50 | #1511 (permalink) |
Junior Member Join Date: Feb 2009
Member: 976913 Status: Offline Thanks Meter: 0 | Hi. Ericsson G35 Fixed Wireless Terminal are 1-2 in my hand. Equipment works, but does not provide dial tone. How do I repair that needs to change I wonder what part? Or with the software you are correct, then what you have to install the software? Thanks. |
01-11-2011, 07:42 | #1514 (permalink) |
Freak Poster Join Date: May 2002 Location: malaysia Age: 49
Member: 12388 Status: Offline Thanks Meter: 23 | hello sir~~i have problem in sonyerricson P1,no network, how to solve it~~Pls help me it's urgent~~~~ thanks |
The Following User Says Thank You to maxyap For This Useful Post: |
01-11-2011, 10:10 | #1515 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1174317 Status: Offline Thanks Meter: 7 | se w595 display blank hlp me sir plssssssssss...., se w595 display ok strip ok only board fault display fully colour dots hlp me sir..., |
The Following User Says Thank You to naveentoto03 For This Useful Post: |
..::Get ALL BB5 Problems I Solved In Only 1 hours::.. | 786786 | Nokia Repair Guide and FAQ | 4179 | 03-28-2014 18:56 |
.....::::: Get Me Ur Problem I Solved In Only 6 Hours::::.... | 786786 | Motorola Hardware Repair | 315 | 06-08-2013 17:55 |
..::Get ALL DCT4 Problems I Solved In Only 1 hours::.. | RIZWANJAT | Nokia Hardware & Hardware Repair | 5 | 11-26-2010 18:12 |
Post urs problem here solves in 24 hrs by Javajohn | Javajohn | Nokia Hardware & Hardware Repair | 92 | 06-17-2006 07:43 |
problem and solve in SL45i | Ahmed Jundy | x1x to x45/x50 | 6 | 12-31-2003 00:42 |
