Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
05-07-2014, 17:05 | #2332 (permalink) |
Junior Member Join Date: Aug 2007
Member: 560591 Status: Offline Thanks Meter: 0 | u10i aino low sound earphone hi! i have a problem and i caanot fix it, i have u10i aino with low sound earphone. i replace the flex and the earphone , i check the line from l6105 ( and l6106) to the earphone contats with out a problem ( almost 0 omhs) the funny thing is i can hear test mode or regular conversation, but the sound is too low , when the original earphone, the sound was almost "nothing", but with the replacement part i win a lot, but not enought. witch is the problem? firmware? ( i never flash it), earphone need to be "special"? tx in advance |
05-10-2014, 19:49 | #2334 (permalink) |
No Life Poster Join Date: Apr 2006 Location: The Arrivals
Member: 263993 Status: Offline Sonork: 100.1612432 Thanks Meter: 173 | Sony Z1 After LCD Change Dead Any sulution? I change difrent LCD, Akku still same is there any fuse? Last edited by ebu mohammed-emin; 05-10-2014 at 19:52. Reason: fuse ? |
05-13-2014, 11:20 | #2335 (permalink) |
Junior Member Join Date: May 2014
Member: 2185455 Status: Offline Thanks Meter: 0 | Hi all! I need help with my Sony Xperia V. 11months old. Its back light went off. Like I have to use a flashlight to navigate it or like put it under direct light so I can read text messages. The phone works well still, sounds, calls, connectivity. Its really just the back light. I hope. I brought it to Sony center and it will cost me around 12 to 13 thousand in pesos since the LCD will have to be replaced they said. My phone was bought from an unauthorized online seller, "KIMSTORE". It only provides service warranty and also, I lost my receipt already. The problem started 2days ago. It was submerged under cold water. Although its water resistant, I think internal hardware became moist. Im not so sure what is the cause. That same night it started to flicker until the back light went off. Do I not have other solutions aside from replacing the LCD? The cost of the replacement is just too much for me. Please help me. Thank you in advance. |
05-14-2014, 10:22 | #2338 (permalink) |
Member: 2185455 Status: Offline Thanks Meter: 0 | Hi all! I need help with my Sony Xperia V. 11months old. Its back light went off. Like I have to use a flashlight to navigate it or like put it under direct light so I can read text messages. The phone works well still, sounds, calls, connectivity. Its really just the back light. I hope. The problem started 4 days ago. It was accidentally submerged under cold water. Although its water resistant, I think internal hardware became moist. Im not so sure what is the cause. That same night it started to flicker until the back light went off. Do I not have other solutions aside from replacing the LCD? Please help |
05-14-2014, 14:38 | #2339 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Nepal
Member: 1294102 Status: Offline Sonork: 100.1655641 Thanks Meter: 79 | sony ericsson w300i headset sign and mic problem hello to all ......... i got handset having mic and charging problem.... repaired charging but can't repair mic. after charging is done there is another problem headset sign......... please help as soon as possible i tried tis for mic but not solved [IMG]http://www.************/forum/uploads/monthly_07_2010/post-11129-1279405296.jpg[/IMG] i used this to repair charging.. [IMG]http://1.bp.********.com/-ZnnpRLlnfxI/TvTAD6QsjpI/AAAAAAAABiU/devKbAqf15w/s1600/W830i+Sony+ERicsson+Hardware+Charging+Solution.png[/IMG] |
..::Get ALL BB5 Problems I Solved In Only 1 hours::.. | 786786 | Nokia Repair Guide and FAQ | 4179 | 03-28-2014 18:56 |
.....::::: Get Me Ur Problem I Solved In Only 6 Hours::::.... | 786786 | Motorola Hardware Repair | 315 | 06-08-2013 17:55 |
..::Get ALL DCT4 Problems I Solved In Only 1 hours::.. | RIZWANJAT | Nokia Hardware & Hardware Repair | 5 | 11-26-2010 18:12 |
Post urs problem here solves in 24 hrs by Javajohn | Javajohn | Nokia Hardware & Hardware Repair | 92 | 06-17-2006 07:43 |
problem and solve in SL45i | Ahmed Jundy | x1x to x45/x50 | 6 | 12-31-2003 00:42 |
