Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
11-20-2006, 12:26 | #6 (permalink) |
Freak Poster Join Date: Oct 2005 Location: perth aust.
Member: 188959 Status: Offline Thanks Meter: 7 | Not sure if inunderstand your post correctly, but did you mean that you tested the keypad on another K series phone? if resistance o.k ., and keypad is o.k. , then flux and flow the I.C , but clean thoroughly with Alcohol first , dry , then flow. From personal history, the pad under the I.C is usually corroded, so you may need one of the guru's in here to post a pin out diagram ,and bypass..-good luck , it's a hard one....... |
11-20-2006, 12:31 | #7 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | Quote:
/vbb/showthread...=273060&page=3 salman | |
12-08-2006, 16:58 | #9 (permalink) |
Junior Member Join Date: Nov 2006
Member: 395835 Status: Offline Thanks Meter: 0 | k750i howto Hello I have the same problem with my k750i as you. With which tools is it possible a reflow or rehot of the keypad ic? Can I use my 25W soldering iron on the crystal surface of the ic and reflow the solder on the connectors underneath? Thank you for your answer. |
12-09-2006, 21:59 | #10 (permalink) | |
Freak Poster Join Date: Sep 2005 Location: USA Age: 58
Member: 176971 Status: Offline Thanks Meter: 116 | Quote:
6700c keypad problem | luyanda | Nokia Hardware & Hardware Repair | 20 | 04-09-2014 10:16 |
K 750 keypad light problam | crackp0d | Sony Ericsson Hardware Repair | 2 | 07-10-2009 05:17 |
k-750 keypad | krishna.cell | Sony Ericsson Hardware Repair | 0 | 05-11-2009 15:58 |
k 750 keypad not working pllease help me | sajithcellular | Sony Ericsson Hardware Repair | 2 | 10-19-2007 06:07 |
K 750 Keypad Stress | mobilecell084 | Sony Ericsson | 1 | 11-18-2006 20:00 |
