Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 10-26-2009, 12:13   #1 (permalink)
Member: 1085928
Thanks Meter: 6
Sonyerricson K220i No supported accessory problem(Charging problem).
Brother please tell me how to solve Sonyerricson K220i "No supported accessory"(Charging problem) problem.
The Following User Says Thank You to ribka For This Useful Post:
Old 10-26-2009, 13:19   #2 (permalink)
Member: 709604
Thanks Meter: 173
you fully flash with infinity box your problem will solve
The Following 2 Users Say Thank You to krishna.cell For This Useful Post:
Old 11-06-2009, 08:31   #3 (permalink)
shoeb7's Avatar
Member: 196194
Thanks Meter: 47
yes mr krishna ia right
i did the same
1 flash phone with repair ffs..
then do unlock
charging problem solved and camera image is also saving
here is the log
[B]flash log[/B]
COM8 [VCP0] selected
module v1.37
Device: Sony-Ericsson-K220i
"advanced chip detection" active
Action: flash write
"smart write" active
write: Firmware
K200i_K220i_main_R1AB003_CXC1250822_En_Ru_Ee_Lt_Lv _Pl_Ua.80M.bin
write: Flex/Customization
K200i_flex_R1AB003_CXC1250822_CDA102773-48_R2A.80F.bin
skip: Language Pack
skip: FFS/File system
skip: Images
skip: Melody
skip: Eeprom
Checking data, wait...
Boot ...
Press Power button now !
loading...
Boot done
Check connection ...
Check connection done
Set baud ...
406250
Set baud done
Check hardware ...
flash: 01227E22212200:92EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
software version: R1AD001
software version: CXC1250818
version flex: CDA102806/1
imei: 35243402401718
Check hardware done
Read data ...
reading Sony-Ericsson-K220i_35243402401718_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-1_20091106-120855.80E.bin
reading Sony-Ericsson-K220i_35243402401718_eeprom_calibration-2...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-2_20091106-120859.80E.bin
reading Sony-Ericsson-K220i_35243402401718_ffs...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_ffs_20091106-121039.80E.bin
Read data done
Check data ...
Check data done
Write ...
Area: Firmware
Write: Firmware
Write: Firmware
flash: 01227E22212200:46237300000000
Write: Firmware
Area: Flex/Customization
Write: Flex/Customization
Write done
Finished, time used: 618 sec
Remove/Install battery now !
repair ffs log
module v1.37
Action: flash write
skip: Firmware
skip: Flex/Customization
skip: Language Pack
write: FFS/File system
K220i_ffs_repair_default.80E.bin
skip: Images
skip: Melody
skip: Eeprom
Boot ...
loading...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-1_20091106-105337.80E.bin
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-2_20091106-105345.80E.bin
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_ffs_20091106-105852.80E.bin
Read data done
Check data ...
Check data done
Write ...
Area: FFS/File system
Write: FFS/File system
Write done
Finished, time used: 695 sec
unlock log
module v1.37
Action: unlock
Boot ...
loading...
Boot done
Set baud ...
812500
Set baud done
Check hardware ...
software version: R1AB003
software version: CXC1250822
version flex: CDA102773/48
Check hardware done
Read data ...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-1_20091106-123108.80E.bin
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-2_20091106-123110.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: eeprom
Write: eeprom
locks cleared
Write done
Finished, time used: 53 sec
regards!
The Following User Says Thank You to shoeb7 For This Useful Post:
k220i shows unsuported accessory lohith03 Sony Ericsson Hardware Repair 54 06-01-2012 14:05
k220i not supported accessory asifalimass Sony Ericsson Hardware Repair 0 10-18-2009 10:30
07 Oct 2007: SE K200i, K220i models supported InfinitySupport Infinity-Box 55 03-25-2009 16:43
Mr. Zulea. NO upgrade dongle, no support area, no unlock w700, no unlock w300 Durango Unlock Dongle Problems (USB-Smart) 1 08-29-2006 04:02
Page generated in 0.15624 seconds with 9 queries
