Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
09-14-2004, 23:38 | #1 (permalink) |
Crazy Poster Join Date: Sep 2004
Member: 80227 Status: Offline Thanks Meter: 2 | P800 - extreme battery drain & hot The phone is hot to the touch too. I've: - checked for background apps - formatted the thing - tried 2 different batteries (different mha too) Am I right in thinking there's a resistor in there doing too much work or something? Could there be a short? - how much do these things cost to fix in general? < £40? - the fix for a not-recharging problem involves a transistor near the power socket. Could this be involved here too? When my screwdrivers arrive I'll take the case off and try to find where the heat is coming from; probably the battery. Maybe I can get replacement part from somewhere - replacement mainboard? |
09-17-2004, 00:10 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: South Coast UK
Member: 58075 Status: Offline Thanks Meter: 17 | Never heard of the problem with SE phones, nokias yes all the time mainly 7250 and I remove camera and all ok, check for water damage and anything obvious inside that maybe shorting out |
09-18-2004, 10:50 | #5 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | @ Jago25 98 Open handset check for liquid damage I've had one like that the charging circuitry was faulty check to see If its the phone thats getting hot or the battery Regards D. |
04-07-2005, 19:38 | #6 (permalink) |
Junior Member Join Date: Apr 2005 Location: ITALY Age: 55
Member: 135005 Status: Offline Thanks Meter: 0 | I've EXACTLY the same problem (seems not to getting charge, no red light no sw indicator, but sloooowly charge in hours. when disconnected the charger, battery drains to zero in minutes, even with the phone turned off, and getting hot from connector area!) No liquid penetration, no drops! It happen after that the external power charger was ****! hhheeelllppp!!! |
04-07-2005, 23:43 | #7 (permalink) |
Member: 80227 Status: Offline Thanks Meter: 2 | Well I bought another P800 in the end!! However, there's a post regarding a problem that I feel might be related: http://forum.gsmhosting.com/vbb/showthread.php?t=154259 Pay attention to platijet. He's the man on that thread (hero). Also, check that the screen isn't touching the side, possibly refit it. And obviously clear background programs with SMAN 's flush (I set it to internet button) |
04-08-2005, 09:22 | #8 (permalink) |
Freak Poster Join Date: Aug 2004 Location: spain Age: 46
Member: 79485 Status: Offline Thanks Meter: 47 | mmmm.... ok, here goes the solution: Try to change a small regulator,it is like a transistor with three point to board and then change charge filter (it seems like a small silver square), both pieces near of the charge conector on board. B.R. |
04-08-2005, 14:19 | #11 (permalink) |
Junior Member Join Date: Jan 2005 Location: Macedonia Age: 54
Member: 110512 Status: Offline Thanks Meter: 0 | petermov is right. The regulator is actualy a fuse wich protects the phone from high current. If the charging voltage is bad, then this regulator is short circuiting and protecting the phone. Its location is on the top left corner of the PCB near the power regulating IC. There are 2 with same size so check wich of them is short circuted.If the phone is not watter damaged then is unlikely that the small cristal on the bottom is the problem. Good luck. |
04-09-2005, 12:17 | #12 (permalink) |
Member: 135005 Status: Offline Thanks Meter: 0 | Current absorption even when P800 is off! First of all I would want to thank who answered me Now I would want to say something that should exhibit with extreme clarity my problem. If I introduce a charged battery in the telephone, leaving the P800 completely turned off, the current absorption is 300mA !!! So I don’t think that adding some wire bridge in the PCB will solve this. Maybe the problem is in some components, that drains continuously current from the battery, with or without the external charge, with the telephone switched on or off, making some warm in the external connector zone (+30°C, when Tambient=+22°C). So, what is broken? One of the two diode (or transistor?) 6F42? The IC R1A KC H487F? Other? Unfortunately I am a newbie and I don’t have nothing to be able to decide alone thing to do (don’t have the partlist, neither the schematic ). If someone of you has these information, would pray to send them by email ([email protected]) I've uploaded two photos of my P800, so that you can annotate them with some suggestions. Thank you all. Francesco P800 photo 1-Connector zone P800 photo 2-Full |
04-10-2005, 13:01 | #13 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | so,problem is not that phone can't charge but somewere you have shortcircuit.measure the "+" and "-" of battery connector to PCB to find the resistance(in normal case must be more than 20Kohm)so,connect only PCB(not screen etc) to the battery and try to find by tuching all parts of PCB from where heat is coming. Quote:
04-10-2005, 17:06 | #14 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 53
Member: 97158 Status: Offline Thanks Meter: 11 | hi master of gsm mr savigsm wil u pls help me fr my ericssion t310 everthing is ok but when i on the phone after 3/4 min phone wil restart .pls help me n send the soluations on my mail pls at [email protected] |
moto L6 invalid battery & hot | .:SARCAR:. | Motorola Hardware Repair | 5 | 04-14-2009 03:25 |
6111 drain battery and became hot when charging | goran124 | Nokia Hardware & Hardware Repair | 7 | 04-19-2007 13:45 |
K700i drain battery and become hot | Olan121 | Sony Ericsson Hardware Repair | 1 | 04-17-2007 14:30 |
6210- battery drain?? | F C | Nokia Hardware & Hardware Repair | 3 | 01-25-2002 21:24 |
5110 hardware prblem ( battery drain fast) | Fai555 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-09-2001 03:06 |
