Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 03-31-2015, 05:46   #1 (permalink)
Member: 696662
Thanks Meter: 5
Thumbs up Sony Xperia Z3 backlight solution
Tested on Xperia Z3 D6653 should also work on D6603 and D6616
imgur
The Following 4 Users Say Thank You to mietek190 For This Useful Post:
Old 03-31-2015, 21:05   #2 (permalink)
Registered User
Member: 941587
Sonork: 50000
man your email , to send image
Old 07-07-2015, 15:00   #3 (permalink)
ersa's Avatar
Member: 75290
Thanks Meter: 57
light solution for D6633
Hello,
PCB from D6633 is diffrent. Look atached file.
I need solution for this phone.
ERSA
Seb
Old 07-08-2015, 00:57   #4 (permalink)
Member: 696662
Thanks Meter: 5
Try this http://forum.gsmhosting.com/vbb/f261...ement-1942010/
The Following User Says Thank You to mietek190 For This Useful Post:
Old 07-08-2015, 08:55   #5 (permalink)
ersa's Avatar
Member: 75290
Thanks Meter: 57
light solution for D6633 Z3
Originally Posted by mietek190 View Post
Work perfect!!!
Thank you!
ERSA
Seb
Old 07-09-2015, 03:20   #6 (permalink)
Member: 1930387
Thanks Meter: 9
thanks it work fo me after water dammage
Old 02-09-2016, 00:14   #7 (permalink)
Member: 1424002
What voltage do i have to have on that fuse. I get 28v. Is that ok?
Old 03-04-2016, 01:49   #8 (permalink)
Member: 1424002
Tried changing the digitizer, no luck. Tried jumping the fuse, same no luck. I don't know what to do anymore.
Old 04-07-2016, 08:07   #9 (permalink)
Member: 1627867
plz gyz i need sony z3 dual display light ways any one know tell me
Old 05-06-2016, 06:51   #10 (permalink)
Member: 2402678
Sony xperia z - no backlight
Old 06-13-2016, 12:06   #11 (permalink)
Member: 2373055
freind my sony d6603 singal sim no lcd light problem plz revert the solution?????????????
Old 07-13-2016, 08:49   #12 (permalink)
Member: 973921
Where can I buy it?
What are the specs of this fuse?
Where can I buy it?
Old 07-17-2016, 09:14   #13 (permalink)
Member: 325534
Anyone knows what type of "fuse"/resistor is it exactly? I know that the one for the vibrator is "Resistor 0.0 Ohm +/-5% 63.0 mW K0402" and the backlight one at least looks the same. So is the original part just a 0 ohm resistor acting as a fuse?
Old 07-19-2016, 00:19   #14 (permalink)
Member: 696662
Thanks Meter: 5
Yes it's just 0 Ohm resistor acting as a fuse exactly the same as the one for vibrator in the corner of the motherboard.
Old 07-19-2016, 08:15   #15 (permalink)
Member: 973921
I don't have spare board so I can't take it from there...
Google helps me if I look for 0 ohm resistor? Any 0 ohm resistor (having the same dimentions) would be a good for me?
Page generated in 0.24298 seconds with 9 queries
