11-25-2008, 14:03 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | V3 Unlock problem boot loader:08.26 Sw version: R374_G_0E.41.C3R_B When try to remove rsa it show no need to remove rsa just unlock with smart-clip with single button. and when trying to unlock with smart-clip it show error message:RDL SIG ERROR:55:02: Here's log: Code: SmartMoto xxx S-Card: xxxxxxx Smart-Clip dongle, v xxxx, assigned Smart-Clip: xxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxx, version: 4xxx, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF This phone does not need "Remove RSA" procedure, you may unlock it with Smart-Clip button |
11-25-2008, 14:23 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ KK Mobile, V3 with the boot version 8.26 can be unlocked via Remove RSA procedure. As can be seen from your log file, the phone is connected via TP. In order to perform Remove RSA procedure, the phone suppose to be powered on. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-25-2008, 15:07 | #4 (permalink) |
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | unlock successfully done. SmartMoto 3.14 Looking for S-Card... not found (card readers searched: 0 of 1) S-Card: xxxxxxx Smart-Clip dongle, v 2.08, assigned Smart-Clip: xcxxxxx Europe, initializing... OK Clip serial: xxxxxxx, version: 4.07, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF This phone does not need "Remove RSA" procedure, you may unlock it with Smart-Clip button Searching for phone... found Motorola Phone (V3/P), getting test interface... OK Model V3/P Firmware R374_G_0E.41.C3R_B Switching to flash mode... OK [S Flash Neptune LTE] Reading phone boot version... 8.26 Sending boot... OK Writing flash... OK "Remove RSA" performed successfully, you may service and unlock the phone as usual W.b.r Karan |
V3 unlock problem! | uffehbg | Motorola P2K (USB-Smart) | 6 | 05-02-2006 14:25 |
v3 unlocking problem | 8210 | Smart-Clip | 2 | 01-05-2006 17:26 |
v3 unlock problem | gaz3051 | Smart-Clip | 10 | 07-10-2005 16:42 |
V3 unlock problem. TOTALMOTO team, GOBI | blue_life1111 | TotalMoto | 10 | 05-02-2005 15:13 |
Rogers Motorola V3 Unlocking problem | nabeel7 | Smart-Clip | 2 | 03-25-2005 12:24 |
