12-17-2008, 06:16 | #1 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 711274 Status: Offline Thanks Meter: 7 | w375 OTP LOCKED MOTOROLA H80S EEprom ST Model M58LR128FT 001a006400342795504 SW Ver: SW_W375_0.0.71.K2 FLASH: N/A VERSION: CODE.90.01 BOOT.90.05 FMGR.90.74 FLEX_W375_CS_002 DOM:200708072316 DOM2:200708072316 DOM3:000000000000 FBI:0 WATCH DOG:ON DSC: FLEX OFF PHONE:SECURITY E+VER:EAGLEPLUS V1.2.41 OTP is locked If OTP is locked Smart Clip can`t repair imei. How solve this setting or how make any solution for this problem? - man, don't be useless and look what is said in smartmoto manual: Network IMEI patch for the models C261, W370 and W375. Network IMEI! only the number that goes to the network. paffka what say? The phone not recognized in the network. DON`T PASS IME* in the verification, use one calculator for generate this numbrer an check this in number`s plain OK. |
12-17-2008, 08:41 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | IMEI section of SmartMoto service software was implemented by developer of this program for repair (original IMEI restore) purposes only! For some models IMEI could be restored simply by connecting the handset to SmartMoto via Smart-Clip as for flashing. Some models require to be flashed with “IMEI repair firmware patch”, only after that IMEI could be restored. In some cases flash chip on phone’s PCB requires to be replaced, to allow user to restore IMEI. However, every user that applies to this option must remember the original IMEI to be able to restore it. In any case if SmartMoto user, during phone repair process, applies IMEI that differs from the original IMEI, which was previously set with the phone, is doing that on his own responsibility. Developer of SmartMoto software does not take any responsibility for any incorrect use of that program. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
i have motorola w375 is lock before | ABDULLAHI MUHD | Infinity-Box | 0 | 02-04-2010 23:03 |
w375 phone lock | Plavush | Smart-Clip | 1 | 12-17-2008 10:28 |
w375 user lock | neetika99 | Infinity-Box | 1 | 12-11-2008 07:47 |
Big problem, Imei OTP locked!! | hungco | Smart-Clip | 1 | 08-12-2007 21:30 |
"Rebuild SP area using OTP IMEI" caused 4 locks closed on T616 | toshik | Sony Ericsson | 13 | 01-28-2004 16:55 |
