Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
10-15-2003, 23:53 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: FLA, US Age: 47
Member: 31969 Status: Offline Thanks Meter: 13 | "Rebuild SP area using OTP IMEI" caused 4 locks closed on T616 I used both DIV 8.2 or DIV 8.4, f/w version is R1A054. Last edited by toshik; 10-16-2003 at 00:13. |
10-16-2003, 14:17 | #3 (permalink) |
Member: 31969 Status: Offline Thanks Meter: 13 | "Read all codes" in fact reads all codes. However since all four locks are closed with "0" attempts the phone won't take any codes. "Reset GDFS" does not change anything. Would it be safe to assume that DIV8.4 is not working properly with T616 and maybe, T610? Last edited by toshik; 10-16-2003 at 14:31. |
11-15-2003, 22:51 | #4 (permalink) |
Freak Poster Join Date: Jun 2003 Location: New York
Member: 31012 Status: Offline Thanks Meter: 6 | yes, it is same with me, i tried to unlock two AT&T t616, can read all codes, but when i enter any code, the phone said "Not Allow". Anyone can help? Please............................ |
01-24-2004, 12:54 | #10 (permalink) | |
No Life Poster Join Date: Dec 2001 Location: [winscard.SCardTransmit]
Member: 8023 Status: Offline Thanks Meter: 13 | Quote:
from this, the problem can be that DIV 8.x, as it does not have SW version information about the particular piece, creates not the correct format seczone on rebuild. buy div usb | |
01-24-2004, 12:57 | #11 (permalink) |
Member: 8023 Status: Offline Thanks Meter: 13 | but if I'm right you should try to flash the phone with T610 R1L013 then apply the T616 to T610 no volume patch described in 2-3 topics below by MeRWiN... in the case, it must either rebuild or handle the given security zone... after you might need a reset gdfs again. |
01-24-2004, 13:00 | #12 (permalink) | |
01-25-2004, 12:15 | #13 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CT SA Age: 52
Member: 12733 Status: Offline Thanks Meter: 26 | Do not use Rebuild Sp area any more. Type original imei at the back of the phone or new one if you like and click change imei. Reset gdfs. user the T616=>T610 conversion : Flash Avr and ARM (same version;R1L013 preferable ). And flsh audio repaire file. Good luck |
01-28-2004, 16:55 | #14 (permalink) | |
Junior Member Join Date: Jan 2004 Location: USA
Member: 49511 Status: Offline Thanks Meter: 0 | Get 4 locks open Quote:
I played with my T616 and I have a solution for your 4 locks closed only if you made the Back Up GDFS: In DIV8.4: 1. Choose T616 2. Write GDFS with "your T616 Back Up GDFS" That it. Good luck. | |
Fighter 4.33 can solve 4 lock closed on t230, BUT Cruiser 4.20 can't!! Why?? | bestncheap | Cruiser Suite | 0 | 07-08-2005 10:08 |
Can I repair 4 locks closed on T610? just by Crusader? | byteforce | Griffin | 4 | 12-06-2004 12:57 |
4 lock closed on T610 | IgorGSM-SR | Sony Ericsson | 2 | 07-29-2004 20:45 |
rebuild sp area using otp imei | kingmobilephone | Sony Ericsson | 2 | 09-23-2003 13:35 |
4 locks closed on 8210 v5.08 | papogsm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-18-2001 00:10 |
