07-20-2006, 11:29 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: pccomp Age: 42
Member: 59173 Status: Offline Sonork: 100.1585568 Thanks Meter: 225 | SCDR2 NEW in METAL BOX - NOT WORK!!! But its not work. Dev. Not Found online repair log : Looking For Device ...Error Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok << DEVICE READY TO REBUILD! >> Rebuild Device in Progress: Write Flash ...Ok! Write Flash ...Ok! Write Flash ...Ok! < ERROR: DEVICE DAMAGED OR LPT SM II USED! > (what is mean ) need help |
07-21-2006, 09:13 | #3 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Poland Age: 46
Member: 43823 Status: Offline Thanks Meter: 308 | i got same probelm with custoemr how get sagmaster and run scdr but I eman in normal casing (green one LPT).....but as far as I know metal SCDR are only SCDR - not sagmaster or I'm wrong, correct me |
07-21-2006, 09:16 | #4 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Poland Age: 53
Member: 23714 Status: Offline Thanks Meter: 18,769 | check please repair tool for scdr 2 repair tool here - http://www.sagmaster.com/download/SC...ILDER_v1.2.rar b r smt |
07-25-2006, 18:16 | #5 (permalink) |
Member: 59173 Status: Offline Sonork: 100.1585568 Thanks Meter: 225 | what about this : Looking For Device ...Error Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok << DEVICE READY TO REBUILD! >> Rebuild Device in Progress: Write Flash ...Ok! Write Flash ...Ok! Write Flash ...Ok! < PROBLEM REBUILD DEVICE S/n: xxxxxxxxxxxxxxxx ERR: 100 > ???????????? |
09-19-2006, 09:55 | #6 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | I have the same problem with metal scdr2. please answer question, on box there is next to power connector description of ACP12, does this mean input of 12 volt AC? I have only 5 volt DC power input. |
09-19-2006, 13:43 | #8 (permalink) |
No Life Poster Join Date: Nov 2003 Location: near you ...
Member: 43036 Status: Offline Sonork: 100.62160 Thanks Meter: 2,386 | Yes I was also this problem ! But when i change Adaptor " Charger Nokia by one WRITEN on Charger ACP12 " It worck's very well Without any small problem for sure |
09-20-2006, 03:59 | #9 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | scdr2 metal box: Looking For Device ...Error Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok << DEVICE READY TO REBUILD! >> Rebuild Device in Progress: Write Flash ...Ok! Write Flash ...Ok! Write Flash ...Ok! < PROBLEM REBUILD DEVICE S/n: 0F30BE1ECBB7xxxx ERR: 100 > please explain, what to do next? thank you. |
mt-box not working in new ver 3.2.1.3,2,1 | .::PATEL TELECOM::. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 05-04-2010 10:49 |
New Infinity Box Not Working Helpppp | ARAB GSM | Infinity-Box | 7 | 01-13-2009 18:32 |
Universal Box not working in nokia 3110c | hc_nuck23 | Universalbox | 0 | 04-14-2008 18:53 |
new box not work-error? | chmielgrzegorz | ULT PRO | 9 | 03-10-2008 03:58 |
SCDRBOX.com SCDR2 in Metal Box! And No device not found! | GPGIndustries | GSM Mobile Links | 0 | 06-19-2006 03:52 |
