05-12-2017, 08:18 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | 12/05/17 SPDTool v1.0.0.3023 - WILIKE / LIKE 3G+ DUO / NYX-XYN 307 / IPLUS I3 - W1ST SPD SERVICE TOOL - Update 1.0.0.3023 Added:
NEW FILES:
HOW TO UNLOCK WILIKE 3G+ DUO / LIKE 3G+ DUO 1. Download latest version of SPD TOOL module 2. Select the correct model (WILIKE 3G+ DUO / LIKE 3G+ DUO) 3. Check the sticker under the battery for the correct release date of the firmware installed in the phone 4. Get from the support the PATCH file having the same date as the one found on the sticker. You can consult the images bellow for the details. If the file is not available then read the flash from the phone and send it to us or simply reflash the phone with the full flash files available on the support and use after the correct PATCH file for it. 5. If anything goes bad after writing the PATCH file (WHITE SCREEN / HANG) then simply reflash the phone with the full flash files available on the support and use after the correct PATCH file for it. best regards, FuriouSTeaM |
The Following 19 Users Say Thank You to .:hack3r2k:. For This Useful Post: |
