09-05-2019, 16:25 | #15257 (permalink) |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Honor 8a jat-l29 9.0.1 frp done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM169)) Preparing to start flash mode; Preparing to open COM169 Connecting; Downloading DA; Initializing; Rid: fcddd895c15f8ce58b618e045055166f Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0xFA370142 0x9B55A4D6 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x659A00000 Contents saved to : E:\SETUP\FG\PACK6\OTSmart_v1.0.0.3605_Cowabanga_Ed ition\jat l29\HUAWEI JAT-L29_IMEI_951715D7_8855D92E_fcddd895c15f8ce58b618e0 45055166f_5_09_2019_01_01_34.osp Downloading images... Done; Searching phone; (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM182)) Preparing to start fastboot mode; Done; Fastboot mode entered; Connecting; switching_fastboot_mode: OK; resistance is futile : OK !?; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; Factory Reset Protection successfully removed ! Time needed - 00:01:57 |
09-05-2019, 17:02 | #15258 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | itel it6080 sc6531efm lock code remove done ITEL IT6080 SPD SC6531EFM FORMAT DONE BY CHOSING ITEL IT6110 |
The Following User Says Thank You to fokal2008 For This Useful Post: |
09-06-2019, 17:42 | #15259 (permalink) |
No Life Poster Join Date: Jul 2010 Location: cameroon
Member: 1356561 Status: Offline Thanks Meter: 433 | furios gold wiko sunny 3 unlock by spdservice tols Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem8.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM25]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_17C_W18.23.4_P2_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P2 HW Version: sc7731e_modem 06-20-2018 11:11:40 Build number: W_K120SUN-user 8.1.0 OPM2.171019.012 1562315636 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 358074-09-553137-5 SW IMEI[1]: 358074-09-561217-5 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON SIM_LOCK TYPE: 3 IMEI: 3xxxxx-xx-xxxxx-5 UNLOCK CODE: 88190403 Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_6_09_2019_18_20_40.txt Time needed - 00:00:02 |
The Following User Says Thank You to idrissou mohama For This Useful Post: |
09-07-2019, 08:15 | #15260 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Pakistan
Member: 2206874 Status: Offline Sonork: 100.1584591 Thanks Meter: 36 | VODAFONE 231 BT unlock DONE Software engine version: 1.0.0.6621 Connect phone powered on ! Start auth ! SW Ver: ELI_IF_111208_1501 Imei: 354561021951622 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:011A Reading ... Saved: SAGEM_354561021951622_ELI_IF_111208_1501_12.12.09_ 07.09.2019_PARTIAL.bin Done ! Time needed - 00:01:20 |
The Following User Says Thank You to TauheedMobiles For This Useful Post: |
09-10-2019, 15:16 | #15261 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | unlock network orange rise53 finally done ORANGE RISE53 DONE Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem204.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM129]; Entering diagnostic mode; Done; Chip type: 6B4C:5300 Platform Version: MOCORTM_15C_W17.39.2_P1.03_Debug Project Version: sc983x_cp1 BASE Version: FM_BASE_15C_W17.39.2_P1.03 HW Version: sc983x_modem 12-22-2017 21:57:31 Build number: sp9832a_2h11_orange-user 7.0 NRD90M eng.jinjiy.20180412.165739 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 867302-03-175584-8 SW IMEI[1]: 867302-03-185584-6 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: OFF SIM_LOCK TYPE: 2 ERROR: Simlock not enabled ! Phone is unlocked; Log file saved to: LOG_10_09_2019_15_41_39.txt Time needed - 00:00:00 AFTER THAT REPAIR SLOCK DONE |
09-10-2019, 20:48 | #15262 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | huawei p20 lite frp done Fly Captain Huawei Resurrector 0.0.0.38 user:57A96656 Device detected: COM68: HUAWEI USB COM 1.0 (COM68) BOOTLOADER File to update: Kirin659_T0_A8.0_V1 10/09/2019 03:44:58 p.m. Starting to write device... Process identifier:4663075 Writing bootloader... Writing Kirin659_T0_A8.0_V1_3.dtwork... Writing Kirin659_T0_A8.0_V1_4.dtwork... Waiting for fastboot device... Device found: 6NUDU18811009532 Looking for a device in fastboot mode Device found: 6NUDU18811009532 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:6NUDU18811009532 IMEI:867904038917063 IMEI1:000000000000000 MEID:00000000000000 Build number: :ANE-LX3 9.1.0.134(C771E4R1P7) Model: ANE-LX3 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Unlocking FRP... Writing FRP partition FRP partition UPDATE :FAIL partition error Writing FRP partition FRP partition UPDATE ...OK Software written 10/09/2019 03:46:35 p.m. Writing device finished OK |
The Following User Says Thank You to maxpatri9 For This Useful Post: |
09-11-2019, 22:37 | #15263 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | HUAWEI P20 LITE DOWNGRADE DONE Fly Captain Huawei Resurrector 0.0.0.38 user:57A96656 Looking for a device in upgrade mode COM661: Android Adapter PCUI (COM661) COM662: DBAdapter Reserved Interface (COM662) 11/09/2019 05:14:56 p.m. Starting to write device in UPGRADE mode... Device found: 6NUDU18811008812 11/09/2019 05:15:02 p.m. start to write update file File to update: UPDATE.APP File size: 4,339,279,260 bytes Current version(CURVER): ANE-BD 1.0.0.999 Process identifier:4665305 Validating file... Detecting port... Preparing to write... Writing file 1 of 34: SHA256RSA...OK Writing file 2 of 34: CRC...OK Writing file 3 of 34: CURVER...OK Writing file 4 of 34: VERLIST...OK Writing file 5 of 34: PACKAGE_TYPE...OK Writing file 6 of 34: EFI...OK Writing file 7 of 34: XLOADER...OK Writing file 8 of 34: FW_LPM3...OK Writing file 9 of 34: FASTBOOT...OK Writing file 10 of 34: MODEMNVM_UPDATE...OK Writing file 11 of 34: TEEOS...OK Writing file 12 of 34: TRUSTFIRMWARE...OK Writing file 13 of 34: SENSORHUB...OK Writing file 14 of 34: FW_HIFI...OK Writing file 15 of 34: KERNEL...OK Writing file 16 of 34: RAMDISK...OK Writing file 17 of 34: RECOVERY_RAMDISK...OK Writing file 18 of 34: RECOVERY_VENDOR...OK Writing file 19 of 34: ERECOVERY_KERNEL...OK Writing file 20 of 34: ERECOVERY_RAMDISK...OK Writing file 21 of 34: ERECOVERY_VENDOR...OK Writing file 22 of 34: RECOVERY_VBMETA...OK Writing file 23 of 34: ERECOVERY_VBMETA...OK Writing file 24 of 34: DTS...OK Writing file 25 of 34: MODEM_FW...OK Writing file 26 of 34: VBMETA...OK Writing file 27 of 34: ODM...OK Writing file 28 of 34: CACHE...OK Writing file 29 of 34: SYSTEM...OK Writing file 30 of 34: CUST...OK Writing file 31 of 34: VENDOR...OK Writing file 32 of 34: VERSION...OK Writing file 33 of 34: PRODUCT...OK Writing file 34 of 34: USERDATA...OK Software written 11/09/2019 05:33:26 p.m. Writing device finished OK |
09-12-2019, 11:37 | #15264 (permalink) |
Freak Poster Join Date: Dec 2015 Location: BENIN NIGERIA
Member: 2502646 Status: Offline Sonork: 100.1581304 Thanks Meter: 34 | Zte k81 unlock done Software engine version: 1.0.0.10850 Searching phone ... MODEL : QCOM SERIES 51 COMPILED DATE : Jul 11 2017 06:36:00 RELEASE DATE : May 11 2017 04:00:00 FIRMWARE INFO : MPSS.JO.3.0-00296-8909_GEN_PACK-1 IMEI : 86485503170044-8 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: P890R81_BELLV1.0.0B12 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\Hp\Desktop\FURIOUS GOLD\PACK 5\86485503170044_12_09_2019_11_22_29.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM551 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD Looking for the interface; Port found [Qualcomm HS-USB QDLoader 9008 (COM181)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_12_09_2019_11_26_40.txt Time needed - 00:04:15 |
The Following User Says Thank You to hamat For This Useful Post: |
09-12-2019, 19:18 | #15265 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Jamaica
Member: 2673816 Status: Offline Thanks Meter: 612 | Alcatel 5059R unlock done Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM45)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.112_k39tv1.bsp_P7 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R3.MP.V10.3.P14 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 015242-00 IMEI 2: 000000-00-000000-0 Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:46 |
The Following User Says Thank You to ThePhoneTechDoc For This Useful Post: |
09-13-2019, 18:18 | #15266 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | HUAWEI CRO L03 UNLOCK DONE Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM10)) Preparing to start flash mode; Preparing to open COM10 Connecting; Downloading DA; Initializing; Rid: ea1d5cff2c17425b20306fac1674dff6 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x484A0190 0x61344738 0xF222D432 0x4BB48E34 [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xC4000000 SIZE: 0x10CF80000 Searching data; Locked to [SIM1]: 370-02 code_cat_n: 2420678110313225 enabled: yes tries: 10 code_cat_ns: FFFFFFFF enabled: no tries: 10 code_cat_sp: FFFFFFFF enabled: no tries: 10 code_cat_c: FFFFFFFF enabled: no tries: 10 code_cat_sim: FFFFFFFF enabled: no tries: 10 code_cat_ns_sp: FFFFFFFF enabled: no tries: 10 code_cat_sim_c: FFFFFFFF enabled: no tries: 10 Phone unlocked; Remove battery and cable; Time needed - 00:00:05 Log file saved to: LOG_13_09_2019_13_16_20.txt |
09-14-2019, 07:36 | #15267 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Inside
Member: 455852 Status: Offline Sonork: 100.1596308 Thanks Meter: 1,993 | Software engine version: 1.0.0.6486 Connect phone powered on ! Start auth ! SW Ver: ERT-TJ-MLT-P108A26(G)(S)V1.0.0B02 Imei: 356894030025726 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_356894030025726_ERT-TJ-MLT-P108A26(G)(S)V1.0.0B02_11.32.07_14.09.2019_PARTIAL .bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:25 |
09-16-2019, 12:39 | #15268 (permalink) |
Freak Poster Join Date: May 2006 Location: Kosovo
Member: 272517 Status: Offline Sonork: 1604061 Thanks Meter: 68 | COOLPAD 3622A unlock done Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: COOLPAD MODEL: COOLPAD 3622A ANDROID: v5.1.1 CPU: QCOM IMEI: NA KERNEL: Linux version 3.10.49-g3523c12-00138-g30951a4 (mine@ubuntu) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Mar 31 14:39:55 CST 2017 Cleaning; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [Coolpad Android Diagnostics USB VCOM (COM118)] Backing up sensitive data; connect_server: OK; backup in progress: OK; Backup saved to: D:\Boksat\Furios gold\instalimi\FURIOUS-GOLD\PACK5\ADB\ Done; Done; Done; Restarting the phone; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [Coolpad Android Diagnostics USB VCOM (COM118)] Restoring sensitive data; connect_server: OK; restore in progress: OK; Done; SIM_LOCK REMOVED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE THE UNLOCK ! Log file saved to: LOG_16_09_2019_12_58_26.txt Time needed - 00:05:02 |
09-18-2019, 12:59 | #15269 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | MobiWire Nakai unlock successful unlock done by otzflasher selecting Ayasha Using library Brom_DLL_v5.1428.0 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM16)) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6261 Sw version: MOBIWIRE_NAKAI_SS_L_V01.2_181214_MP Hw Version: SAGETEL61M_11C_HW Reading phone info; IMEI: 353292-10-0234xxx Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:16 Log file saved to: LOG_18_09_2019_14_56_46.txt |
09-20-2019, 16:11 | #15270 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Portugal Age: 43
Member: 7557 Status: Offline Thanks Meter: 26 | Vfd820 Vodafone smart X Software engine version: 1.0.0.10880 Searching phone ... MODEL : QCOM SERIES 56 COMPILED DATE : Jun 24 2019 01:16:00 RELEASE DATE : May 10 2019 02:00:00 FIRMWARE INFO : MPSS.TA.3.0.c1-00366-8953_GEN_PACK-1.202713.1.204312.1 IMEI : 35477709031702-0 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: VDF_P450K10V1.0.0B41 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Program Files (x86)\FURIOUS-GOLD\PACK5\QCOM_SMART_TOOL_v1.0.0.10879\3547770903 1702_20_09_2019_12_19_03.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM31 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22F9 start_frp_reset: OK; Thanks again Daniel |
The Following User Says Thank You to theboy For This Useful Post: |
