Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 12-15-2019, 12:51   #15346 (permalink)
Registered User
Member: 731353
Thanks Meter: 254
S.A Vodafone locked ITEL i2160s unlock done by selecting ZTE 522[new]
Using library Brom_DLL_v5.1316.1
Searching phone;
(for some models keep SPACE or * (STAR) key pressed before inserting the cable)
Phone detected (MTK USB Port (COM248))
Preparing to start meta mode;
Meta mode entered;
Baseband Chip: MT6261
Sw version: it2160S-DL194-EnFrPo-MZ-Vodacom-20180625
Hw Version: SAGETEL61D_11C_HW
Reading phone info;
IMEI: 359399-09-xxxxxxx
Reading security;
Done;
Checking;
Preparing;
Writing security;
Phone unlocked; Remove battery and cable;
Time needed - 00:00:16
Log file saved to: LOG_15_12_2019_13_44_07.txt
The Following 2 Users Say Thank You to bigjef1 For This Useful Post:
Old 12-16-2019, 13:18   #15347 (permalink)
IM8
Member: 694535
Thanks Meter: 70
Blackview A60 FRP Done!
open OTsmart , select OT-5080 phone powered off and connect to usb .
Using library Brom_DLL_v7.1813.3
Searching phone in normal mode;
[connect the phone powered off to the usb cable]
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM22))
Preparing to start flash mode;
Preparing to open COM22
Connecting;
Downloading DA;
Initializing;
Rid: fa06ff0f7f947374bdee46f4cd32bbb6
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
DEVICE INFO:
BB CHIP: MT6580 [CA00, 00, 6580, FF]
HW_STORAGE_EMMC: 0x484A0190 0x61344741 0x3532A432 0xE9B3460A [SIZE=0x3AC000000]
IMEI1 [OTP 0000]: 000000-00-000000-0
IMEI2 [OTP 0000]: 000000-00-000000-0
PROVIDER: N/A
USRDATA INFO: 0x96800000 SIZE: 0x60000000
Factory Reset Protection successfully removed !
Time needed - 00:00:00
Log file saved to: LOG_16_12_2019_13_46_15.txt
Old 12-18-2019, 12:32   #15348 (permalink)
Member: 2775355
Thanks Meter: 177
T-Smart FP789L-T Unlock Done
Searching phone;
For an successful connection do the following:
1. Connect the phone powered off with the battery inside to the usb cable
Phone detected (@oem173.inf,%usbcomm_dl%;SPRD U2S Diag)
Preparing to sync;
Port opened [COM149];
Entering diagnostic mode;
Done;
Chip type: 0000:0000
Platform Version: MOCORTM_17B_Release_W19.44.3_Debug
Project Version: sharkle_Feature_Phone
BASE Version: FM_BASE_17B_Release_W19.44.3
HW Version: sc9820e_modem
10-30-2019 05:27:36
Build number: sp9820e_2h10_oversea-user 4.4.4 KTU84P eng.a1401.20191128.133614 test-keys
PHONE INFO:
BT ADDR: FF:FF:FF:FF:FF:FF
SW IMEI[0]: 864934-04-006973-9
SW IMEI[1]: 864934-04-006974-7
SW IMEI[2]: 867400-02-031663-8
SW IMEI[3]: 867400-02-031664-6
SIMLOCK FLAG: ON
BKP saved to : BKP_000000-00-000000-0_864934-04-006973-9_00000000_18_12_2019_14_12_21.spd
SIM_LOCK TYPE: 3
IMEI: 864934-04-006973-9 UNLOCK CODE: 43740508
Done;
Log file saved to: LOG_18_12_2019_14_12_26.txt
Time needed - 00:00:07
The Following 3 Users Say Thank You to KSJphoneFastFix For This Useful Post:
Old 12-19-2019, 09:15   #15349 (permalink)
Member: 132881
Thanks Meter: 105
zte L130 done
Searching phone;
1. Power on the phone and power it off and leave the battery inside
2. Keep pressed firmly volume DOWN key
3. Insert the usb cable inside the phone while keeping pressed volume DOWN
Phone detected (@oem340.inf,%dvcdsc%;SCI USB2Serial)
Preparing to sync;
Port opened [COM23];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: Spreadtrum Boot Block version 1.1
Starting FDL2;
FDL2 sent;
Starting auth;
HW IMEI : 000000-00-000000-0
Analysing data; Please WAIT !
OK;
PHONE INFO: NONE
SW IMEI[0]: 861486-04-******-0
SW IMEI[1]: 867400-02-******-0
SW IMEI[2]: 867400-02-******-8
SW IMEI[3]: 867400-02-******-6
SIMLOCK FLAG: ON
Reading NV;
NV saved to : NV_000000-00-000000-0_861486-04-138767-0_96330000_18_12_2019_14_26_35.spd
Gathering security data;
Security check result: 0
Connecting to server;
Authorisation process started;
Done;
Requesting data from server ! Wait please ...
Re-programming;
Security programmed;
Sync NV;
Done;
Old 12-19-2019, 09:19   #15350 (permalink)
Member: 132881
Thanks Meter: 105
aspire 5 done again
Searching phone;
Preparing to sync;
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Starting FDL2;
FDL2 sent;
Starting auth;
OK;
PHONE INFO: NONE
SW IMEI[0]: 860250-04-******-0
SIMLOCK FLAG: ON
Reading NV;
NV saved to : NV_000000-00-000000-0_860250-04-******-0_98550000_18_12_2019_14_44_32.spd
Done;
Re-programming;
Sync NV;
Done;
Old 12-20-2019, 10:18   #15351 (permalink)
Member: 746586
Thanks Meter: 205
Vodafone VFD 510 frp reset
Software engine version: 1.0.0.10922
Searching phone ...
MODEL : QCOM SERIES 51
COMPILED DATE : Mar 14 2019 17:20:00
RELEASE DATE : May 10 2017 19:00:00
FIRMWARE INFO : MPSS.JO.3.0-00291-8909_GEN_PACK-1.97872.1.98558.1
IMEI : 35224909353877-2
BLUETOOTH ADDR : 00 00 00 00 00 00
FIRMWARE: ZA_MR4_VDF_P809V51V1.0.0B04
close_event_report: OK;
close_log_report: OK;
close_message_report: OK;
closing_com_port: OK;
Starting the backup process;
connect_server: OK;
backup in progress: OK;
Backup saved to: C:\Users\antho\Downloads\QCOM_SMART_TOOL_v1.0.0.10 922\35224909353877_20_12_2019_10_59_11.bkp
switching_download_mode: OK;
Preparing to open COM48
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory 22CD
start_frp_reset: OK;
frp_reset: OK;
Log file saved to: LOG_20_12_2019_11_02_10.txt
Time needed - 00:03:04
Old 12-21-2019, 19:42   #15352 (permalink)
Member: 216446
Thanks Meter: 220
Alcatel one touch p310a language portuguese added success
Using library Brom_DLL_v7.1413.5
Phone detected (MediaTek PreLoader USB VCOM Port (COM41))
Preparing to open COM41
Connecting;
Downloading DA;
Initializing;
Rid: 6f6023b4c78eba3307550e520c222038
Done;
Switching to DA_HIGHSPEED_VCOM;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \;
If the detection fails, install manually the port from the device manager using usbvcom.inf;
DA_HIGHSPEED_VCOM (@oem63.inf,%mtk_sp_da%;MediaTek DA USB VCOM Port)
TRYING TO OPEN COM42;
DEVICE INFO:
BB CHIP: MT6582_S00 [CA00, 00, 6582, FF]
HW_STORAGE_EMMC: 0x38000115 0x33424D57 0x9F5B0152 0x4341B361 [SIZE=0x1D2880000]
IMEI1 [OTP 0001]: 014135-00-006125-7
IMEI2 [OTP 0001]: 000000-00-000000-0
PROVIDER: P310A-2ATBUSK
USRDATA INFO: 0x5F880000 SIZE: 0x173000000
Loading the file ...
Cfg done ...
Formatting file system now...
Done;
Downloading bootloader...
Done;
Downloading images...
Done;
Success;
Time needed - 00:02:12
Log file saved to: LOG_21_12_2019_23_50_27.txt
Old 12-21-2019, 20:49   #15353 (permalink)
ThePhoneTechDoc's Avatar
Member: 2673816
Thanks Meter: 612
Smile Alcatel OT-6062W new security unlock done
Phone detected (MediaTek USB Port (COM45))
Preparing to open COM45
Requesting authorization;
Connecting;
Downloading DA;
Initializing;
Rid: 8ba1f42b50b641a84a752c08d8a25e9f
Done;
DEVICE INFO:
BB CHIP: MT6763 [CA01, 01, 6763, 00]
HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x901D0742 0x9585EDF2 [SIZE=0x748800000]
IMEI1 [OTP 0001]: 015126-00-
PROVIDER: 6062W-2BTBUS7
USRDATA INFO: 0x13B800000 SIZE: 0x6088FBE00
Searching data;
Checking server support license;
Bruteforcing ... relax ;-)
Buteforce took 00:00:00
Checking data integrity;
Data integrity: OK;
SIM_LOCK: ENABLED
Rebuilding security;
Time needed - 00:00:05
The Following 2 Users Say Thank You to ThePhoneTechDoc For This Useful Post:
Old 12-24-2019, 09:42   #15354 (permalink)
Member: 2179221
Sonork: 100.1685104
Thanks Meter: 66
Smile HUAWEI Y530-U00 unlock With Furious-gold Only Adb mode no need manifacture 1.10 sec
Connecting;
Check your phone and "Always allow from this computer" and select "OK".
Connected;
BRAND: HUAWEI
MODEL: HUAWEI Y530-U00
ANDROID: v4.3
CPU: QCOM
IMEI: 864921024582712
KERNEL: Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Aug 4 14:57:37 IST 2014
Cleaning;
Loading files;
Done;
Reconnecting;
Setting access;
Done;
Exploiting;
Android v4.3 TRUE
Backing up sec area;
Done;
Getting sec size;
00118353 bytes
Decompressing;
Backup saved to: 864921xxxxxxxxxxx
Finished;
BT ADDR: E0:19:1D:8C:AF:2D
MAC ADDR: E0:19:1D:8C:99:AF
BOOTLOADER PASS: 4423516311035202
MCC-MNC: [unitel/ao]
LOCK [0] HASH: 3D835CD2966CC118CB06EA89A6DF914B
LOCK [1] HASH: 51675D5A8A4B3508FDA4747B6AB152D3
LOCK [2] HASH: 24C72D6256FD8A807B653DECD62D783F
LOCK [3] HASH: BE5B202DFA8D306AB531D59DA4B2EBC3
LOCK [4] HASH: BE5B202DFA8D306AB531D59DA4B2EBC3
LOCK [5] HASH: CD6BA6FBC39D278AD68FC673E7CAE7C7
LOCK [6] HASH: 3F2DE1CAEC5E5749FCC1920DF8E189F7
LOCK [7] HASH: BE5B202DFA8D306AB531D59DA4B2EBC3
LOCK [8] HASH: BE5B202DFA8D306AB531D59DA4B2EBC3
LOCK [9] HASH: BE5B202DFA8D306AB531D59DA4B2EBC3
Starting;
Done;
Unlocking in progress;
Calc 0000 ;
Calc 0001 ;
SIM_LOCK REMOVED !
Rebooting;
Old 12-27-2019, 09:15   #15355 (permalink)
Registered User
Member: 731353
Thanks Meter: 254
mobicel beam forever locked done
Searching phone;
Phone detected (@oem20.inf,%usbcomm_dl%;SPRD U2S Diag)
Preparing to sync;
Port opened [COM9];
Done;
Platform Version: MOCORTM_17C_W18.23.4_P22_Debug
Project Version: pike2_pub
BASE Version: FM_BASE_17C_W18.23.4_P22
HW Version: sc7731e_modem
09-17-2019 20:33:29
Build number: k130-user 8.1.0 OPM2.171019.012 1569730015 release-keys
PHONE INFO:
SW IMEI[0]: 357809-10-010622-1
SW IMEI[1]: 867400-02-031662-0
SIMLOCK FLAG: ON
BKP saved to : BKP_000000-00-000000-0_357809-10-010622-1_00000000_27_12_2019_00_12_11.spd
SIM_LOCK TYPE: 2
IMEI: 357809-10-010622-1 UNLOCK CODE: 11483414
Done;
Log file saved to: LOG_27_12_2019_00_12_15.txt
Old 12-27-2019, 13:33   #15356 (permalink)
Member: 132881
Thanks Meter: 105
Vodacom 3g vibe unlocked
Searching phone;
Phone detected (@oem227.inf,%mtk_preloader%;PreLoader USB VCOM Port)
Searching for debug port; (be sure drivers from support were installed)
Debug Port found on Android Gadget VCOM Driver (COM1823);
Preparing to connect meta mode;
Meta mode entered;
Baseband Chip: MT6572, E01
Sw version: MOLY.WR8.W1315.MD.WG.MP.V62.P16
Hw Version: SR72_W_KK_HSPA_HW
Reading phone info;
IMEI: 358030-10-******-8
Reading simlock info;
Locked to: 655-01
code_cat_n: 12345678 enabled: yes tries: 224
code_cat_ns: 56781234 enabled: no tries: 255
code_cat_sp: 11112222 enabled: no tries: 255
code_cat_c: 33334444 enabled: no tries: 255
code_cat_sim: 55556666 enabled: no tries: 255
code_cat_ns_sp: 77778888 enabled: no tries: 255
code_cat_sim_c: 99990000 enabled: no tries: 255
Time needed - 00:00:56
Old 12-28-2019, 12:57   #15357 (permalink)
mothertelecom's Avatar
Member: 1033714
Sonork: 1640811:mothertelecom
Thanks Meter: 91
unlock done mobiwire nokosi
mtk code reader
select AQUILA
https://www.4shared.com/get/luDFPJiZ...iver_v108.html
Searching phone;
Phone detected (@oem26.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android))
Debug Port found on MediaTek USB VCOM (Android) (COM30);
Meta mode entered;
Sw version: MOLY.WR8.W1315.MD.WG.MP.V62.P14
Reading phone info;
IMEI: 359473-09-006758-4
Locked to: 234-30
code_cat_n: 12345678 enabled: yes tries: 4
code_cat_ns: 56781234 enabled: no tries: 5
code_cat_sp: 11112222 enabled: no tries: 5
code_cat_c: 33334444 enabled: no tries: 5
code_cat_sim: 55556666 enabled: no tries: 5
code_cat_ns_sp: 77778888 enabled: no tries: 5
code_cat_sim_c: 99990000 enabled: no tries: 5
Time needed - 00:04:01
Log file saved to: LOG_28_12_2019_17_43_06.txt
The Following User Says Thank You to mothertelecom For This Useful Post:
Old 12-28-2019, 16:51   #15358 (permalink)
Member: 2673816
Thanks Meter: 612
Smile Alcatel 5041C 2019 security unlock done
Connecting;
Downloading DA;
Initializing;
Rid: cb57556f54897bfc5999b4f3407862db
Done;
DEVICE INFO:
BB CHIP: MT6739 [CB00, 02, 6739, 00]
HW_STORAGE_EMMC: 0x51000115 0x4D333645 0x230D0342 0x5BA57B07 [SIZE=0x3A4A00000]
IMEI1 [OTP 0001]: 015174-00-
PROVIDER: 5041C-2ARKUS1
USRDATA INFO: 0x139000000 SIZE: 0x2672FBE00
Searching data;
File not found;
Time needed - 00:00:01
Old 12-29-2019, 09:49   #15359 (permalink)
buffer2k11's Avatar
Member: 2604648
Thanks Meter: 346
Alcatel 4034g unlock success
Phone detected (MediaTek PreLoader USB VCOM_V1632 (Android) (COM20)) (Driver version: 3.0.1504.0)
Preparing to open COM20
Connecting;
Downloading DA;
Initializing;
Rid: 6662c18848bf06b0ba3faa34b57088ab
Done;
DEVICE INFO:
HW_STORAGE_EMMC: 0x45000170 0x44453848 0x2C300134 0x1965E18C  [SIZE=0x1C8C00000]
IMEI1 [OTP 0001]: 015347-00-021xxx-x
PROVIDER: 4034G-2AB7AUA
USRDATA INFO: 0x82800000 SIZE: 0x60000000
Searching data;
Locked to [SIM1]:	505-01
code_cat_n:	1965238892333263 enabled:	no	tries: 10
code_cat_ns:	4027745186053000 enabled:	no	tries: 98
code_cat_sp:	5930368598966105 enabled:	no	tries: 10
code_cat_c:	8161262885729405 enabled:	no	tries: 10
code_cat_sim:	9092273207604644 enabled:	no	tries: 10
code_cat_ns_sp:	9161267785375210 enabled:	no	tries: 5
code_cat_sim_c:	9429491358447390 enabled:	no	tries: 5
Time needed - 00:00:10
Log file saved to: LOG_29_12_2019_16_40_40.txt
br,
The Following User Says Thank You to buffer2k11 For This Useful Post:
Old 12-29-2019, 15:47   #15360 (permalink)
Member: 2506794
Sonork: 100.1675120
Thanks Meter: 118
zte FNB CONEXIS X2 unlock done...
The Following User Says Thank You to MOTHALAB79 For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.46109 seconds with 10 queries
