01-06-2020, 14:21 | #15376 (permalink) |
Freak Poster Join Date: Jul 2009 Location: paraguay
Member: 1086987 Status: Offline Sonork: 1617504 Thanks Meter: 109 | Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM26)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM26 Connecting; Downloading DA; Initializing; Rid: fad3cce97e946388bb7ef8ed006d2607 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x4DAB0142 0x212603DE [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x176800000 SIZE: 0x5D1200000 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:00 |
01-07-2020, 23:30 | #15377 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | Alcatel 5099u last security Locked to telestra au unlock Done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM9)) Preparing to start flash mode; Preparing to open COM9 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 593766e52f8b1cd68dd7115f8bf6020a Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem12.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM11; DEVICE INFO: BB CHIP: MT6737T [CA00, 00, 321, 05] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0xF71D0342 0x9755ADAC [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 353938-09-024236-7 IMEI2 [OTP 0000]: 353938-09-024237-5 PROVIDER: 5099U-2FTSAU3 USRDATA INFO: 0xEE000000 SIZE: 0x2B2280000 Searching data; Locked to [SIM1]: FFF-FF code_cat_n: 8027129051232109 enabled: no tries: 0 code_cat_ns: 8027129051232109 enabled: yes tries: 99 code_cat_sp: 8027129051232109 enabled: no tries: 0 code_cat_c: 8027129051232109 enabled: no tries: 0 code_cat_sim: 8027129051232109 enabled: no tries: 0 Locked to [SIM2]: FFF-FF code_cat_n: 9717312763961282 enabled: no tries: 0 code_cat_ns: 9717312763961282 enabled: yes tries: 99 code_cat_sp: 9717312763961282 enabled: no tries: 0 code_cat_c: 9717312763961282 enabled: no tries: 0 code_cat_sim: 9717312763961282 enabled: no tries: 0 Phone unlocked; Remove battery and cable; Time needed - 00:01:41 |
01-08-2020, 12:03 | #15381 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | AGAIN TECNO POP2 FRP REMOVE DONE Code: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM143)) Preparing to start flash mode; Preparing to open COM143 Connecting; Downloading DA; Initializing; Rid: bd1b7014b2ba6358fd7307fcac4ec367 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x46000115 0x4D32364E 0x1AF90342 0xA91658E4 [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x88000000 SIZE: 0x148F80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_7_01_2020_12_06_59.txt |
01-08-2020, 12:24 | #15382 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | zte s755 unlock done by selecting s522 new Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port (COM248)) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6261 Sw version: VDC_ZA_ZTE-S755V1.0.0B03 Hw Version: MIKI61D_GB_11C_HW Reading phone info; IMEI: 867301-03-163157-9 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:12 Log file saved to: LOG_8_01_2020_13_22_12.txt |
The Following User Says Thank You to bigjef1 For This Useful Post: |
01-08-2020, 15:37 | #15383 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 408 | huawei y5 2019 AMN-LX9 FRP Remove done by furious Gold Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM25)) Preparing to start flash mode; Preparing to open COM25 Connecting; Downloading DA; Initializing; Rid: f727cf0f54663a34171e2853bba379fb Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0xC96E0142 0x271612AA [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x659A00000 Formatting FRP partition now... Done; Factory Reset Protection successfully removed ! Time needed - 00:00:01 Log file saved to: LOG_8_01_2020_14_29_29.txt |
The Following 2 Users Say Thank You to Freeboy08 For This Useful Post: |
01-11-2020, 09:02 | #15384 (permalink) |
No Life Poster Join Date: Apr 2005 Location: mars
Member: 132881 Status: Offline Thanks Meter: 105 | HISENSE F16 DONE Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (PreLoader USB VCOM Port (COM4)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1_P18 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V48.12.P4 Hw Version: TK_MD_BASIC_HW Reading phone info; IMEI 1: 862773-04-******-6 IMEI 2: N/A Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:27 |
01-11-2020, 11:24 | #15385 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | MobiWire Pictor unlocked done Furious Gold PACK 6 - OTZFlasher_v1.0.0.1656 Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM246)) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6260 Sw version: V04_M160330_UL18D_XB39E_EE_MP Hw Version: SAGETEL60A_12864_11B_HW Reading phone info; IMEI: 357717-06-361771-4 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:19 Log file saved to: LOG_11_01_2020_16_19_56.txt |
01-12-2020, 15:59 | #15386 (permalink) |
Freak Poster Join Date: Aug 2019 Location: ZW port of good hope
Member: 2925617 Status: Offline Thanks Meter: 49 | CONEXIS X1 0 COUNTER UNLOCK DONE Software engine version: 1.0.0.10928 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Nov 2 2016 12:31:00 RELEASE DATE : Sep 2 2016 08:00:00 FIRMWARE INFO : MPSS.JO.1.2.c3-00131-8909_GEN_PACK-1 IMEI : 356XXXXXXXXXXX BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: FNB_ZA_P809F52V1.0.0B10 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: E:\Setup\Furious\Pack 5\QCOM_SMART_TOOL_v1.0.0.10928\35675675765675_12_0 1_2020_16_53_28.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM55 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM49)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_12_01_2020_16_56_30.txt Time needed - 00:03:05 |
01-13-2020, 08:53 | #15387 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | DUB_LX2 new version frp success with QCOM Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem195.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM27 Connecting; Loading; Init; Port opened; Hello Received; MSM_ID: 0x0009A0E1 OEM_ID: 0x0015 MODEL_ID: 0x0065 PK_HASH: 6BC369511DA9CADB3A7AF61574F89DB385003D6241BDD1FF57 3DBA61BF6AE1196BC369511DA9CADB3A7AF61574F89DB38500 3D6241BDD1FF573DBA61BF6AE1196BC369511DA9CADB3A7AF6 1574F89DB385003D6241BDD1FF573DBA61BF6AE119 BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory, target id 8953 start_frp_reset: OK; frp_reset: OK; thanks team all other team failed to reset |
The Following User Says Thank You to Mr.3. For This Useful Post: |
01-13-2020, 12:34 | #15388 (permalink) |
Member: 2925617 Status: Offline Thanks Meter: 49 | MOBICEL RIO NETWORK UNLOCK DONE Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem22.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM7]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_17C_W18.23.4_P22_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P22 HW Version: sc7731e_modem 04-23-2019 15:44:41 Build number: k110-user 8.1.0 OPM2.171019.012 1565676976 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 357800-10-030082-3 SW IMEI[1]: 357800-10-080106-9 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_357800-10-030082-3_00000000_13_01_2020_13_11_12.spd SIM_LOCK TYPE: 2 IMEI: 357800-10-030082-3 UNLOCK CODE: 40078015 Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_13_01_2020_13_11_17.txt Time needed - 00:00:06 |
01-15-2020, 12:44 | #15389 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Sylhet Korim Ullah Market Age: 28
Member: 1714226 Status: Offline Sonork: 100.1683394 Thanks Meter: 243 | zte F320 direct unlock Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM6]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Chip type: 7702:0000 Starting auth; Memory NAND [CS0]: 00C8:00B1 - SIZE : 08000000 EFUSE HASH: 0000000000000000000000000000000000000000 EFUSE LOCK STATUS: 000E 000E 000E 000E 000E HW IMEI : 000000-00-000000-0 Reading phone info; PHONE INFO: VDF_UK_QB18S_P701A24 BT ADDR: EB:C8:9C7:374 SW IMEI[0]: 867063-02-040986-8 SW IMEI[1]: 000000-00-000000-0 SW IMEI[2]: 000000-00-000000-0 SW IMEI[3]: 000000-00-000000-0 SIMLOCK FLAG: ON FIXED NV BASE: 40040000 Reading NV; NV saved to : NV_000000-00-000000-0_867063-02-040986-8_77020000_15_01_2020_17_38_44.spd IMEI: 867063-02-040986-8 UNLOCK CODE: 77581825 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_15_01_2020_17_39_28.txt Time needed - 00:01:13 |
The Following User Says Thank You to rubelgsm For This Useful Post: |
01-16-2020, 17:24 | #15390 (permalink) |
Insane Poster Join Date: Jan 2016 Location: Santiago de Cuba
Member: 2510340 Status: Offline Thanks Meter: 74 | unlock alcatel 5024a solved Searching phone; For an successful connection do the following: 1. Power on the phone and power it off 2. Keep pressed firmly volume UP key 3. Insert the usb cable inside the phone while keeping pressed volume UP Phone detected (@oem100.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM62]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2019, FuriouSTeaM Starting FDL2; FDL2 sent; Starting auth; memory_type: IF_TYPE_MMC dev_no: 0 part_type: PART_TYPE_UNKNOWN vendor: Man 00008f Snr e01922c8 product: UY5CS0 revision: 1.0 memory_size: 29,3 GB HW IMEI : 000000-00-000000-0 PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: 35xxxxxxxxxxxxx SW IMEI[1]: 867xxxxxxxxxxxx SW IMEI[2]: 86xxxxxxxxxxxxx SW IMEI[3]: 86xxxxxxxxxxxxx SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_355130-10-155845-6_98550000_16_01_2020_17_15_23.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_16_01_2020_17_15_33.txt Time needed - 00:00:46 |
The Following User Says Thank You to duboy For This Useful Post: |
