02-21-2011, 08:06 | #7877 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | t156 unlock ok Software engine version: 1.0.0.5444 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081033652754 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081033652754_P1.2PU01V01.01_00.03.59_21. 02.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:49 |
02-21-2011, 08:15 | #7878 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | z100 restart with sim ok Software engine version: 1.0.0.5444 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 35 04 98 12 0A 96 0A Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:07:22 |
02-21-2011, 08:17 | #7879 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | z100 unlock ok Software engine version: 1.0.0.5444 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041014895 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 35 04 98 12 0A 96 0A Flash ID(0): 00C2:22A7 Saved: ZTE_352865041014895_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_00.15.49_21.02.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:53 |
02-21-2011, 10:44 | #7880 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock T156 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081036812934 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_353081036812934_P1.2PU03V01.01_13.11.08_21. 02.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 |
02-21-2011, 11:43 | #7881 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | z100 restart with sim ok Software engine version: 1.0.0.5444 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 C9 65 28 9A F5 56 0A 92 06 Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:07:14 |
02-21-2011, 11:45 | #7882 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | z100 unlock ok Software engine version: 1.0.0.5444 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042225847 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 C9 65 28 9A F5 56 0A 92 06 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042225847_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_03.44.32_21.02.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:43 |
02-21-2011, 13:49 | #7883 (permalink) |
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock G2158 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892033445006 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892033445006_REL_P1.1PU01V01.06_17.21.50 _21.02.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:32 |
02-21-2011, 15:21 | #7884 (permalink) |
Freak Poster Join Date: Jun 2007 Location: pirmahal pakistan
Member: 529953 Status: Offline Sonork: 100.1605485 Thanks Meter: 46 | blackberry 9800 unlocking Searching for usb device ... Reading info ... IMEI: 35546604xxxxxxxxxxx Calculating ... MEP LOCK: MEP-07723-007 MEP1 [SIM]: 5329800525636382 MEP2 [NETWORK]: 3662293862359729 MEP3 [NETWORK SUBSET]: 9877146423405315 MEP4 [SERVICE PROVIDER]: 7663875537071681 MEP5 [CORPORATE]: 4260699504803207 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:01:20 |
02-21-2011, 15:22 | #7885 (permalink) |
Member: 529953 Status: Offline Sonork: 100.1605485 Thanks Meter: 46 | blackberry 9000 unlocking Searching for usb device ... Reading info ... IMEI: 355256026xxxxxxxxxx Calculating ... MEP LOCK: MEP-06424-002 MEP1 [SIM]: 1141690597752834 MEP2 [NETWORK]: 0940445141015645 MEP3 [NETWORK SUBSET]: 4635131470352598 MEP4 [SERVICE PROVIDER]: 9051409710149451 MEP5 [CORPORATE]: 1362441632551225 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:01:28 |
02-21-2011, 16:12 | #7886 (permalink) |
No Life Poster Join Date: Jan 2008 Location: KEF_TUNISIA
Member: 681313 Status: Offline Thanks Meter: 506 | lg c320 unlock ok Software engine version: 1.0.0.5949 Searching phone ... MODEL : LGC320 COMPILED DATE : Oct 4 2010 10:39:00 RELEASE DATE : Jun 22 2010 18:00:00 FIRMWARE INFO : LGC320-QSC6270-V10a-OCT-04-2010-XX IMEI : 35461304022040-4 BLUETOOTH ADDR : 3E 5C 5A D3 17 5C ENTERING DOWNLOAD MODE; ENTERED; BOOT VERSION: BS/LGC320/V10a LOADING DATA; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; READING SEC DATA; SECURITY TESTS PASSED ! INFO HASH WRITTEN; UNLOCKING PASSED ! LOCK HASH WRITTEN; SEC DATA 1 WRITTEN; SEC DATA 2 WRITTEN; UNLOCKED ! Time needed - 00:02:03 |
02-21-2011, 17:54 | #7887 (permalink) |
Freak Poster Join Date: Jan 2010 Location: MALI
Member: 1219355 Status: Offline Thanks Meter: 104 | Toshiba g450 ok Code: Software engine version: 1.0.0.5949 Searching phone ... MODEL : QCOM SERIES 9 COMPILED DATE : May 29 2008 22:06:00 RELEASE DATE : Feb 29 2008 03:00:00 FIRMWARE INFO : M6281A-KLRX-4.0.9525 IMEI : 35201502044987-4 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 0020:00AA MEMORY NAME : st_nand02gr3b2c MEMORY INFO : 0800:0040:0038 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; CLOSED; PHONE CODE: 1234 SCANNING; UNLOCK CODE: 02254214 DONE ! RESET ! Time needed - 00:00:59 |
02-22-2011, 06:47 | #7888 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | f102 unlocked success. this is my first phone with FG... ============================== Software engine version: 1.0.0.5949 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003225622-5 BLUETOOTH ADDR : E4 47 ED 1A 18 08 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:09 thanx |
02-22-2011, 07:52 | #7889 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | Software engine version: 1.0.0.5455 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040367658 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 15 67 09 31 05 90 06 01 9E 06 Flash ID(0): 00C2:22A7 Saved: ZTE_352865040367658_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_11.50.27_22.02.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:52 |
02-22-2011, 10:18 | #7890 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Software engine version: 1.0.0.5419 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081039953586 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_353081039953586_P1.2PU03V01.01_14.10.22_22. 02.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 |
