12-30-2019, 00:50 | #15361 (permalink) |
No Life Poster Join Date: Jan 2014 Location: CUBA Age: 32
Member: 2108610 Status: Offline Thanks Meter: 379 | OTSmart Alcatel 6062W FRP Done! Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM57)) Preparing to start flash mode; Preparing to open COM57 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 3514a5726d9d8d7c7803ddb7442bc784 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6763 [CA01, 01, 6763, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x19BE0742 0x215604F2 [SIZE=0x748800000] IMEI1 [OTP 0001]: ------------------------ IMEI2 [OTP 0001]: ------------------------ PROVIDER: 6062W-2BTBUS7 USRDATA INFO: 0x13B800000 SIZE: 0x6088FBE00 Factory Reset Protection successfully removed ! Time needed - 00:00:00 |
The Following User Says Thank You to yosbel182us For This Useful Post: |
12-30-2019, 01:47 | #15362 (permalink) |
Member: 2108610 Status: Offline Thanks Meter: 379 | OTSmart Alcatel 5059Z FRP Done!! Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (Dispositivo serie USB (COM49)) Preparing to start flash mode; Preparing to open COM49 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 4f2f56d8790269e05feb534414a293ea Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0x1CD40342 0x2DC59206 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 01--------------------- IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5059Z-2AE4US7 USRDATA INFO: 0x133800000 SIZE: 0x26CAFBE00 Factory Reset Protection successfully removed ! Time needed - 00:00:00 |
The Following 2 Users Say Thank You to yosbel182us For This Useful Post: |
12-30-2019, 01:50 | #15363 (permalink) |
Member: 2108610 Status: Offline Thanks Meter: 379 | OTSmart Alcatel 7047A Unlock Done Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM29)) Preparing to start flash mode; Preparing to open COM29 Connecting; Downloading DA; Initializing; Rid: 861d29615531019062efdc6a167f1b11 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem274.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM40; DEVICE INFO: BB CHIP: MT6582_S01 [CA01, 01, 6582, 05] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0x0188124C 0x97C10B79 [SIZE=0xE9B00000] IMEI1 [OTP 0001]: ------------------------ IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 7047A-HBPSAR1 USRDATA INFO: 0x65880000 SIZE: 0x80280000 Searching data; Locked to [SIM1]: 722-34 code_cat_n: 2017617194 enabled: yes tries: 1 code_cat_ns: 0095082697 enabled: no tries: 10 code_cat_sp: 2447489184 enabled: no tries: 10 code_cat_c: 1045478763 enabled: no tries: 10 code_cat_sim: 2255429918 enabled: no tries: 10 code_cat_ns_sp: 4107457315 enabled: no tries: 5 code_cat_sim_c: 3114948349 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:05 |
12-30-2019, 01:55 | #15364 (permalink) |
Member: 2108610 Status: Offline Thanks Meter: 379 | OTSmart Alcatel A466BG Tracfone FRP Done! Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM29)) Preparing to start flash mode; Preparing to open COM29 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 23a299c1086eb50efff949f39560579c Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem274.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM40; DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, 05] HW_STORAGE_EMMC: 0x46000115 0x4D32584E 0x14970142 0xD5B333C6 [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 01--------------------- IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: A466BG-2AKFUS1-R USRDATA INFO: 0x88000000 SIZE: 0x145D00000 Factory Reset Protection successfully removed ! Time needed - 00:00:02 |
12-30-2019, 01:56 | #15365 (permalink) |
Member: 2108610 Status: Offline Thanks Meter: 379 | OTSmart Alcatel 5059W Unlock Success Done!! Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM26)) Preparing to start flash mode; Preparing to open COM26 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 6f04b1a67b9e2715eab0ececa03da399 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem238.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM93; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x53E00742 0x678413D4 [SIZE=0x748800000] IMEI1 [OTP 0001]: 01--------------------- IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:07:40 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:07:43 |
12-30-2019, 01:59 | #15366 (permalink) |
Member: 2108610 Status: Offline Thanks Meter: 379 | QComSmartTool Alcatel 5044R Unlock Done!! Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem267.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM12 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 7.3 GB IMEI: 01----------------- PTH: 05 PTS: YAG PROV_ID: 5044R-2AAQUS1-R1 SBTADDR: D4:2857:74B SWIFIADDR: D4:285:EA:60:4A HS_PN: SAA1HQ0WA10C SSN: TCKC10CNSNA049N Work id: 22021984 Done; Stype: 00000001 SECURITY: XAYAUAG0CL10 Size: 000002F7 Backup saved to: 01482700695941-5 Unlocking; SIM_LOCK REMOVED ! |
The Following 3 Users Say Thank You to yosbel182us For This Useful Post: |
12-30-2019, 02:01 | #15367 (permalink) |
Member: 2108610 Status: Offline Thanks Meter: 379 | QCOMSmartTool Alcatel 5056N Unlock Done! Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem10.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM42 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 14,7 GB IMEI: 01----------------- PTH: 08 PTS: B6G PROV_ID: 5056N-2ATBUS7 SBTADDR: 28:BE:03:BF:C7:33 SWIFIADDR: 28:BE:03:A6E:FA HS_PN: SAA1F5BWA10C SSN: N6KB09CKVLZ03TY Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 04DB9B50 Done; Stype: 00000001 SECURITY: XUB0UP01BR10 Size: 000002C3 Backup saved to: 01465000233604-4 Unlocking; SIM_LOCK REMOVED ! |
12-30-2019, 02:03 | #15368 (permalink) |
Member: 2108610 Status: Offline Thanks Meter: 379 | QCOMSmartTool Alcatel 6039K FRP Done!! Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM76 Connecting; Init; Port opened; Phone detected (@oem129.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM357 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 size 14,6 GB IMEI: 86----------------- PTH: 13 PTS: AB2 PROV_ID: 6039K-2AALWE7 SBTADDR: D0:9D:AB:54:07:2D SWIFIADDR: D0:9D:AB:54:07:2E HS_PN: SAA34D2AC10C SSN: NVKK06BASHY0116 Work id: 0A3AE35E Setup 1; Done; Setup 2; Done; Setup 3; Done; Uploading; Done; SECURITY: X1A0L502BQ20 Size: 00000430 Backup saved to: 86702402004237-2 Checking the simlock; Magic ok; ERROR: SIM_LOCK not enabled; FRP has been Reset Successfully; Erase Setup Done; Erase Done; Erase Done; FRPEx Done; |
12-30-2019, 17:12 | #15369 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Jamaica
Member: 2673816 Status: Offline Thanks Meter: 612 | Alcatel 5033M frp done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM45)) Preparing to start flash mode; Preparing to open COM45 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 7de0a04234f5bd9054a420bdbd15ed04 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x46000115 0x4D323645 0xF8010342 0xA576A59B [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 358054-10- IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5033M-2HC9JMA USRDATA INFO: 0x85000000 SIZE: 0x31B2FBE00 Factory Reset Protection successfully removed ! Time needed - 00:00:00 |
The Following User Says Thank You to ThePhoneTechDoc For This Useful Post: |
01-02-2020, 14:21 | #15370 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | y6 2019 frp done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM228)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM228 Connecting; Downloading DA; Initializing; Rid: 16282d99159ff8a7a660f37d0f7716b5 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x61B00142 0xEF263EDE [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x659A00000 Formatting FRP partition now... Done; Factory Reset Protection successfully removed ! Time needed - 00:00:03 Log file saved to: LOG_2_01_2020_18_19_08.txt |
01-02-2020, 15:35 | #15371 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 408 | wiko y60 w-k510 unlock done by furiousglod Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM6)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739 Sw version: Hw Version: alps-mp-p0.mp1-V5.20_tinno.sz.p0mp1.k39tv1.64.bsp_P22 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R3.MP.V37.3.P8 Hw Version: TK_MD_BASIC_HW Reading phone info; IMEI 1: 355572-10-259803-3 IMEI 2: 355572-10-264845-7 Loading config; Done; Working; Unlocking; Unlocking SIM2; Phone unlocked; Remove battery and cable; Time needed - 00:00:28 Log file saved to: LOG_2_01_2020_15_27_07.txt |
The Following User Says Thank You to Freeboy08 For This Useful Post: |
01-03-2020, 08:57 | #15372 (permalink) |
Freak Poster Join Date: Feb 2011 Location: pakistan
Member: 1524022 Status: Offline Sonork: 100.1608738 Thanks Meter: 56 | huawei g520-0000 imei repiar done 2020-01-03 12:51:01.954 Repairing start New IMEI 1 : 354407038201 New IMEI 2 : 354407038201 2020-01-03 12:51:01.967 Connecting to server... 2020-01-03 12:51:03.009 Connected! 2020-01-03 12:51:03.014 Read data from server... 2020-01-03 12:51:04.718 Read data from server success! 2020-01-03 12:51:04.728 Open COM port COM132 (DBAdapter Reserved Interface (COM132))... 2020-01-03 12:51:12.807 Read secure info... 2020-01-03 12:51:13.544 Read basic info... 2020-01-03 12:51:14.048 Repair phone security data start! 2020-01-03 12:51:14.053 Calculating phone secure data... 2020-01-03 12:51:16.392 Calculate phone secure success! 2020-01-03 12:51:16.396 Writing phone secure data... 2020-01-03 12:51:19.223 Writing phone secure data success! 2020-01-03 12:51:19.606 Repair phone security data success! 2020-01-03 12:51:19.614 Repairing IMEI 2... 2020-01-03 12:51:20.503 Repair IMEI 2 success! 2020-01-03 12:51:20.509 Finished! |
01-03-2020, 19:58 | #15373 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | Searching phone; For an successful connection do the following: 1. Power on the phone and power it off 2. Keep pressed firmly volume UP key 3. Insert the usb cable inside the phone while keeping pressed volume UP Phone detected (@oem23.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM8]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2019, FuriouSTeaM Starting FDL2; FDL2 sent; Starting auth; memory_type: IF_TYPE_MMC dev_no: 0 part_type: PART_TYPE_UNKNOWN vendor: Man 00008f Snr e04aeb56 product: UY5CS0 revision: 1.0 memory_size: 29.3 GB HW IMEI : 000000-00-000000-0 PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: 355130-10-313236-7 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_355130-10-313236-7_98550000_3_01_2020_18_52_44.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; |
01-04-2020, 12:13 | #15374 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | tecno lb7 frp remove done by select la7 using FG TECNO LB7 FRP REMOVE OK BY FG Code: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM143)) Preparing to start flash mode; Preparing to open COM143 Connecting; Downloading DA; Initializing; Rid: 09cbe8f17327d2f2b5b49516cdcd057e Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x684A0190 0x50613842 0xE595023E 0x5D56C34A [SIZE=0x749400000] PROVIDER: N/A USRDATA INFO: 0x104800000 SIZE: 0x6423FBE00 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_3_01_2020_12_05_53.txt |
The Following User Says Thank You to fokal2008 For This Useful Post: |
01-06-2020, 13:04 | #15375 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | alcatel ot-5046y unlock done phone came with sim1 permanently blocked just select phone model in ot smart and check remove simlock it will ask to direct unlock after reading code and just press yes logs: Connecting; Downloading DA; Initializing; Rid: 9ba46acaf5f2ca47798778cf4b44a1c8 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem203.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM15; DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x51000115 0x42363133 0x38270142 0x2B647EDA [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 355151-08-104308-7 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5046Y-2CE8GB1 USRDATA INFO: 0xC6800000 SIZE: 0x2D9A00000 Searching data; Locked to [SIM1]: 234-30 code_cat_n: 9135240458326478 enabled: yes tries: 0 code_cat_ns: 6453246642320410 enabled: no tries: 10 code_cat_sp: 5689359060414731 enabled: no tries: 10 code_cat_c: 7068264161416872 enabled: no tries: 10 code_cat_sim: 9487173623337088 enabled: no tries: 10 code_cat_ns_sp: 7818902903899234 enabled: no tries: 5 code_cat_sim_c: 7698565230510787 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:05 Log file saved to: LOG_6_01_2020_11_53_07.txt done... |
