02-22-2011, 10:43 | #7891 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:19 |
02-22-2011, 11:58 | #7892 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock G2158 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892033527019 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892033527019_REL_P1.1PU01V01.06_12.50.05 _22.02.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:13 |
02-22-2011, 12:01 | #7893 (permalink) |
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock G2158 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.03 Imei: 358892031430554 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Reading ... Saved: HUAWEI_358892031430554_REL_P1.1PU01V01.03_13.20.48 _22.02.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:21 |
02-22-2011, 12:05 | #7894 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | T156 Unlock Successfully Software engine version: 1.0.0.5455 Connect phone powered on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081036716358 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081036716358_P1.2PU02V01.01_16.02.48_22. 02.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:30 |
02-22-2011, 12:58 | #7895 (permalink) |
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock Z100 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042896712 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 5E 35 80 98 1B 0A 86 08 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042896712_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_16.44.47_22.02.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:02:09 |
02-22-2011, 12:59 | #7896 (permalink) |
Registered User Join Date: May 2007 Location: india
Member: 511520 Status: Offline Sonork: 100.1573642 Thanks Meter: 127 | ::: Successfilly Unlocked Motorola Ve538 ::: ::: Successfilly Unlocked Motorola Ve538 ::: Software engine version: 1.0.0.5744 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Feb 18 2009 11:41:00 RELEASE DATE : Feb 18 2009 11:40:00 FIRMWARE INFO : O'zapft is000Athens3.03ATHB1A_3.03P0 IMEI : 35832301034627-2 BLUETOOTH ADDR : 6B F3 5A CA 17 00 MEMORY ID : 00AD:0036 MEMORY NAME : hynix_HYC0SEH0AF3P MEMORY INFO : 0200:0020:06ED INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; DATA FOUND; PHONE CODE: 1234 RL STARTED; RL DONE; UNLOCK CODE(S): 07737568 MASTER CODE: 08768708 ENTER CODE(S) NOW ! DO NOT RESTART THE PHONE ! IF PHONE DOESN'T ASK ANY CODE OR YOU RESTART IT THEN REPEAT THE OPERATION ! Time needed - 00:00:11 |
02-22-2011, 13:19 | #7897 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 621455 Status: Offline Sonork: key4unlock Thanks Meter: 118 | >>>>WORLDS FIRST PALM PRE PLUS Unlock Done WITH FURIOUS GOLD<<<< hiiiiiiiiii 1st of all many many thanx to MR.HACK3R2K who made this and to all the team behind it................ here is log and procedure is shown as in video and in exe but most important to select DIAG por in exe port settings..................... Software engine version: 1.0.0.6366 Searching phone ... MODEL : QCOM SERIES 15 COMPILED DATE : Jul 21 2010 20:41:00 RELEASE DATE : Jul 21 2010 20:23:00 FIRMWARE INFO : CU0.5.48(259) IMEI : 01214500******** BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0036 MEMORY NAME : samsung_k9f1208 MEMORY INFO : 0200:0020:033C WORKING; UNLOCKED; POWER OFF PHONE TO COMPLETE UNLOCK AND AFTER DISABLE THE DIAG; Time needed - 00:00:01 Last edited by ikkks; 02-22-2011 at 13:26. |
The Following User Says Thank You to ikkks For This Useful Post: |
02-22-2011, 13:39 | #7898 (permalink) |
Freak Poster Join Date: Mar 2004 Location: at home
Member: 56735 Status: Offline Thanks Meter: 35 | palm pre plus unlocked with success thanks furious team Software engine version: 1.0.0.6366 Searching phone ... MODEL : QCOM SERIES 15 COMPILED DATE : May 12 2010 16:30:00 RELEASE DATE : May 12 2010 16:13:00 FIRMWARE INFO : CU0.5.42(257) IMEI : 3599580xxxxxxx-x BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0036 MEMORY NAME : samsung_k9f1208 MEMORY INFO : 0200:0020:033C WORKING; UNLOCKED; POWER OFF PHONE TO COMPLETE UNLOCK AND AFTER DISABLE THE DIAG; Time needed - 00:00:01 |
The Following User Says Thank You to rachelyna For This Useful Post: |
02-22-2011, 18:17 | #7900 (permalink) |
No Life Poster Join Date: Dec 2006 Location: ! Age: 39
Member: 414755 Status: Offline Sonork: quickgsm Thanks Meter: 389 | succesfully unlock ZTE BLADE just one secend ^ _ ^ Software engine version: 1.0.0.6366 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Sep 16 2010 16:55:00 RELEASE DATE : May 12 2010 18:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-53303002 IMEI : 35316004004994-7 BLUETOOTH ADDR : 34 67 C8 4A 15 D0 CALCULATING; UNLOCK CODE: 76214677 UNLOCKED ! Time needed - 00:00:01 BR / TA@UFIK BY / QUICK - MOBILE |
The Following 2 Users Say Thank You to quickgsm For This Useful Post: |
02-23-2011, 08:13 | #7901 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Pakistan
Member: 49285 Status: Offline Thanks Meter: 51 | BlackBerry phones Unlocking successful 1-Searching for usb device ... Reading info ... IMEI: 980046005273963 Calculating ... MEP LOCK: MEP-15326-002 MEP1 [SIM]: 26766294 MEP2 [NETWORK]: 74230383 MEP3 [NETWORK SUBSET]: 06694499 MEP4 [SERVICE PROVIDER]: 82134892 MEP5 [CORPORATE]: 18796358 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:01:00 /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// 2-Searching for usb device ... Reading info ... IMEI: 358264013769393 Calculating ... MEP LOCK: MEP-04104-007 MEP1 [SIM]: 4063658038920074 MEP2 [NETWORK]: 6084227924435448 MEP3 [NETWORK SUBSET]: 4486614191203687 MEP4 [SERVICE PROVIDER]: 2167222983081467 MEP5 [CORPORATE]: 3770668329674174 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:40 ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// 3-Searching for usb device ... Reading info ... IMEI: 359484020701135 Calculating ... MEP LOCK: MEP-06814-004 MEP1 [SIM]: 2689847974804041 MEP2 [NETWORK]: 1996072556647011 MEP3 [NETWORK SUBSET]: 2489734768576894 MEP4 [SERVICE PROVIDER]: 5860119366261441 MEP5 [CORPORATE]: 6313258204985887 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:41 //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// 4-Searching for usb device ... Reading info ... IMEI: 358516026959315 Calculating ... MEP LOCK: MEP-16472-001 MEP1 [SIM]: 7110406581157105 MEP2 [NETWORK]: 5885598911156087 MEP3 [NETWORK SUBSET]: 8863160827551264 MEP4 [SERVICE PROVIDER]: 5500257131090684 MEP5 [CORPORATE]: 6451812041925483 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:39 ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// 5-Searching for usb device ... Reading info ... IMEI: 355383030324355 Calculating ... MEP LOCK: MEP-11414-002 MEP1 [SIM]: 1467948531534889 MEP2 [NETWORK]: 3911213020097871 MEP3 [NETWORK SUBSET]: 1054684456350230 MEP4 [SERVICE PROVIDER]: 6125535325959491 MEP5 [CORPORATE]: 4142551103884946 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:43 ////////////////////////////////////////////////////////////////////////// 6-Searching for usb device ... Reading info ... IMEI: 980002000072033 Calculating ... MEP LOCK: MEP-15326-001 MEP1 [SIM]: 1709753608545999 MEP2 [NETWORK]: 0175609129624951 MEP3 [NETWORK SUBSET]: 7154881199418569 MEP4 [SERVICE PROVIDER]: 5756777779821299 MEP5 [CORPORATE]: 2969341942640646 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:39----------------- 7-Searching for usb device ... Reading info ... IMEI: 358428031599641 Calculating ... MEP LOCK: MEP-07723-005 MEP1 [SIM]: 5073012109102303 MEP2 [NETWORK]: 8024364105794923 MEP3 [NETWORK SUBSET]: 3906332896781419 MEP4 [SERVICE PROVIDER]: 2170203136290602 MEP5 [CORPORATE]: 1792663531042322 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:39 8-Searching for usb device ... Reading info ... IMEI: 353486049755022 Calculating ... MEP LOCK: MEP-07723-006 MEP1 [SIM]: 1666418305034513 MEP2 [NETWORK]: 6231657250726822 MEP3 [NETWORK SUBSET]: 8000909420027760 MEP4 [SERVICE PROVIDER]: 9281972937781346 MEP5 [CORPORATE]: 7123966772543395 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:39 9-Searching for usb device ... Reading info ... IMEI: 353490049998319 Calculating ... MEP LOCK: MEP-04598-005 MEP1 [SIM]: 5672947221074795 MEP2 [NETWORK]: 6902214253897309 MEP3 [NETWORK SUBSET]: 7308243104248631 MEP4 [SERVICE PROVIDER]: 5500502180563799 MEP5 [CORPORATE]: 1815130435310594 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:41 10-Searching for usb device ... Reading info ... IMEI: 359485028648004 Calculating ... MEP LOCK: MEP-16472-001 MEP1 [SIM]: 7481229305008113 MEP2 [NETWORK]: 6897518726628782 MEP3 [NETWORK SUBSET]: 2618285341480757 MEP4 [SERVICE PROVIDER]: 5737133075519003 MEP5 [CORPORATE]: 5840893412204466 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:40 //////////////////////////////////////////////////////////// 11-Searching for usb device ... Reading info ... IMEI: 353932042280849 Calculating ... MEP LOCK: MEP-04598-005 MEP1 [SIM]: 5681617875617044 MEP2 [NETWORK]: 5030883064361464 MEP3 [NETWORK SUBSET]: 5152086757386018 MEP4 [SERVICE PROVIDER]: 2091425803029770 MEP5 [CORPORATE]: 5405630413567306 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:40 12-Searching for usb device ... Reading info ... IMEI: 980042005028283 Calculating ... MEP LOCK: MEP-04626-002 MEP1 [SIM]: 07797389 MEP2 [NETWORK]: 43078045 MEP3 [NETWORK SUBSET]: 30082704 MEP4 [SERVICE PROVIDER]: 94567281 MEP5 [CORPORATE]: 67399761 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:48 13-Searching for usb device ... Reading info ... IMEI: 353488046243622 Calculating ... MEP LOCK: MEP-04103-001 MEP1 [SIM]: 3576349341789291 MEP2 [NETWORK]: 9542080765851692 MEP3 [NETWORK SUBSET]: 3127659906559007 MEP4 [SERVICE PROVIDER]: 3557080246468192 MEP5 [CORPORATE]: 9400004319396575 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:43 14-Searching for usb device ... Reading info ... IMEI: 356200027643895 Calculating ... MEP LOCK: MEP-04104-007 MEP1 [SIM]: 2940665125922481 MEP2 [NETWORK]: 6309421161629347 MEP3 [NETWORK SUBSET]: 6937428945660990 MEP4 [SERVICE PROVIDER]: 3145920400907970 MEP5 [CORPORATE]: 5250485675432840 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:40 15-Searching for usb device ... Reading info ... IMEI: 358265018327962 Calculating ... MEP LOCK: MEP-16472-001 MEP1 [SIM]: 7434927030378473 MEP2 [NETWORK]: 4270093856007309 MEP3 [NETWORK SUBSET]: 7725418617797740 MEP4 [SERVICE PROVIDER]: 4547931060929107 MEP5 [CORPORATE]: 5077125242461868 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:38 16-Searching for usb device ... Reading info ... IMEI: 353491043078090 Calculating ... MEP LOCK: MEP-04598-005 MEP1 [SIM]: 4795694820445213 MEP2 [NETWORK]: 0986445493202725 MEP3 [NETWORK SUBSET]: 6208194993477943 MEP4 [SERVICE PROVIDER]: 1718067127042201 MEP5 [CORPORATE]: 8234966353882853 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:42 17-Searching for usb device ... Reading info ... IMEI: 359484022104320 Calculating ... MEP LOCK: MEP-06814-004 MEP1 [SIM]: 7636117804856226 MEP2 [NETWORK]: 6037402200621033 MEP3 [NETWORK SUBSET]: 2890013629106755 MEP4 [SERVICE PROVIDER]: 2034325936862487 MEP5 [CORPORATE]: 0436628672187157 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:44 |
02-23-2011, 08:47 | #7902 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | Palm Pre2 Unlocked cool and smooth>>>> Software engine version: 1.0.0.6366 Searching phone ... MODEL : QCOM SERIES 15 COMPILED DATE : May 12 2010 16:30:00 RELEASE DATE : May 12 2010 16:13:00 FIRMWARE INFO : CU0.5.42(257) IMEI : 35813*********** BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0036 MEMORY NAME : samsung_k9f1208 MEMORY INFO : 0200:0020:033C WORKING; UNLOCKED; POWER OFF PHONE TO COMPLETE UNLOCK AND AFTER DISABLE THE DIAG; Time needed - 00:00:01 |
02-23-2011, 11:11 | #7903 (permalink) |
Temporary banned !! Join Date: Aug 2007 Location: Austria (Linz)
Member: 568521 Status: Offline Thanks Meter: 240 | SOny Ericsson X1i Unlock Done Starting cab upload; Preparing to install; Checking installed file; Library found; Reading data; Saved: C:\Dokumente und Einstellungen\Administrator\Desktop\Alle Handy Programme\Furios Gold\HTC_10.55.00_23.02.2011.bin IMEI: 3572630214213901 NCK CODE: 44026023 SP CODE: NOT LOCKED Time needed - 00:00:23 |
02-23-2011, 12:29 | #7905 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | T 156 Done. Software engine version: 1.0.0.5478 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081035104234 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:03 B,R. |
