12-10-2011, 14:50 | #9991 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031731234 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_358146031731234_P1.2PU01V01.02_17.47.57_21. 11.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:02:03 |
12-10-2011, 14:51 | #9992 (permalink) |
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042970004 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 5B 37 84 99 12 08 94 07 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042970004_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_10.04.41_21.11.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:02:16 |
12-10-2011, 14:55 | #9993 (permalink) |
No Life Poster Join Date: May 2007 Location: barsoume
Member: 515559 Status: Offline Sonork: no Thanks Meter: 121 | vodafone 255 unlock ok Software engine version: 1.0.0.6317 Insert cable in box now [NO BATTERY INSIDE PHONE] ! Starting communication ... Platform: E-Gold Voice3-32 [00 00] ... Preloader sent .... Loader sent .... Flash ID(0): 00EF:4016 Checking firmware version ... Detected: ED-DE-P118A16V1.0.0B08 Saved: ZTE_NONE_ED-DE-P118A16V1.0.0B08_14.48.45_10.12.2011_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 |
12-12-2011, 05:53 | #9994 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g1158 unlock Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334038472430 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_356334038472430_REL_P1.2PU04V01.04_12.15.57 _09.12.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:48 |
12-12-2011, 05:54 | #9995 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g1000 done Comm opened 4 ! Baud set ! Auth made ! Sw version: Rel_c1.2pu01v01.05 test mode status: Off sim status: Off imei: 356820040837883 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:13 |
12-12-2011, 11:37 | #9997 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | Z100 unlocked Software engine version: 1.0.0.5779 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865043622000 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 D9 65 28 DA F4 82 07 0D 07 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043622000_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_15.33.32_12.12.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:57 |
12-12-2011, 15:04 | #9998 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | zte v9c unlocking done..... Software engine version: 1.0.0.7439 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Jul 13 2011 00:42:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 355xxxxxxxxxxxx-x BLUETOOTH ADDR : 97 BF C2 62 B3 B4 TAG_ID:V9B06C INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:03 thxs furious team wbr. rajesh_ch |
12-13-2011, 06:50 | #10001 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | lg kp 170 flash and imei repair done Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Writing flash image ... Done ! Time needed - 00:12:55 Phone must be on ! Press any key till screen lights on ! SW VERSION: [OK] KP170AT-00-V10g-EUR-XXX-OCT-23-2008+0 IMEI: [OK] 00000000000000000 BLUETOOTH ADDR: [OK] 0005C9000000 STATUS: [OK] OK Done ! Time needed - 00:00:01 |
12-13-2011, 06:50 | #10002 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g 1000 unlock Comm opened 4 ! Baud set ! Auth made ! Sw version: Rel_c1.2pu01v01.05 test mode status: Off sim status: Off imei: 356820040841471 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:12 |
12-13-2011, 09:39 | #10003 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | ZTE F930 UNLOCK DONE Software engine version: 1.0.0.7480 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : May 11 2010 13:50:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : 3UK_GB_P608D1V1.0.0B04-S IMEI : 35994103012362-6 BLUETOOTH ADDR : 5A 94 E3 1A 18 08 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:48 |
12-13-2011, 14:35 | #10004 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Zte t155 unlocked Software engine version: 1.0.0.6316 Connect phone powered on ! Start auth ! SW Ver: P1.2BN02V01.01 Imei: 358832024149787 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_358832024149787_P1.2BN02V01.01_12.54.14_13. 12.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:44 |
12-13-2011, 19:17 | #10005 (permalink) |
Member: 605126 Status: Offline Sonork: 100.1617907 Thanks Meter: 297 | Successfully unlock at&t z221 thx to fg team at&t z221 unlock done... logs...... Software engine version: 1.0.0.7439 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Aug 8 2011 19:45:00 RELEASE DATE : Apr 19 2011 08:00:00 FIRMWARE INFO : ATT_AM_P671B40V1.0.0B09-S IMEI : 35661304163688-7 BLUETOOTH ADDR : 3C 5C 0E 08 46 38 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 0D0A2225DBA14CB738A8889040C1E0E9.bin ERASING; WRITING; READING; AFTER BACKUP: 425922645A7FEB6B5CA4AE552F6B79AE.bin UNLOCKED; RESET ! Time needed - 00:00:13 |
