12-21-2011, 18:45 | #10036 (permalink) |
No Life Poster Join Date: Mar 2006 Location: morroco
Member: 245026 Status: Offline Thanks Meter: 382 | Software engine version: 1.0.0.7615 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Jul 28 2011 12:14:00 RELEASE DATE : Aug 4 2010 16:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6030 IMEI : 00000000002008-8 BLUETOOTH ADDR : 12 25 B2 62 B3 B4 TAG_ID:P725AB07bR CALCULATING; UNLOCK CODE [OLD]: 38345868 UNLOCK CODE [NEW]: 08760486 COUNTER CLEAR DONE; UNLOCKED ! Time needed - 00:00:20 |
12-21-2011, 19:21 | #10037 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 804466 Status: Offline Thanks Meter: 27 | alcatel ot 585 success Make your handset power off, plug in the UART cable! Product: OT-585 Load DA file... Load AUTH file... Start to connect the handset, keep pressing the power on key! Start to read security information from handset... IMEI: 356888041455013 Security file: C:\Program Files\FuriouS-Gold\PACK8\Alcatel\Security\BackupSecurityFile\585 X-2ARGFR3 Read security information successfully! Start code calculate... Product: OT-585 IMEI: 356888041455013 Security file: C:\Program Files\FuriouS-Gold\PACK8\Alcatel\Security\BackupSecurityFile\585 X-2ARGFR3 NCK:2218283884 NSCK: SPCK: PCK: Code calculate finished successfully! |
12-21-2011, 21:42 | #10038 (permalink) |
Temporary banned !! Join Date: Aug 2007 Location: Austria (Linz)
Member: 568521 Status: Offline Thanks Meter: 240 | Orange Monte Carlo Unlock Done Software engine version: 1.0.0.7615 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Aug 31 2011 16:34:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 86854300034903-5 BLUETOOTH ADDR : F1 90 99 50 4B 34 TAG_ID:743OAT02P1A DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:01:04 |
12-22-2011, 09:36 | #10039 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Software engine version: 1.0.0.6331 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334037298158 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_356334037298158_REL_P1.2PU04V01.04_13.54.41 _17.12.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:45 |
12-22-2011, 09:37 | #10040 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g 1000 unlock Comm opened 4 ! Baud set ! Auth made ! Sw version: Rel_c1.2pu01v01.05 test mode status: Off sim status: Off imei: 356820040853153 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:19 |
12-22-2011, 09:38 | #10041 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | z100 done Software engine version: 1.0.0.6331 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865043712264 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 36 C4 98 91 04 8D 06 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043712264_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_11.18.29_21.12.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:40 |
12-22-2011, 09:39 | #10042 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g2201c unlock done Software engine version: 1.0.0.6331 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620033309297 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 0001:0110 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:04:17 |
12-22-2011, 09:39 | #10043 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g1000 COMM OPENED 4 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820041297558 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:12 |
12-22-2011, 09:40 | #10044 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g1000 COMM OPENED 4 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820040837545 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:13 |
12-22-2011, 12:11 | #10045 (permalink) |
Banned Join Date: Jan 2008
Member: 677796 Status: Offline Thanks Meter: 102 | Sagem my-411x Unlock successfull Press power on shortly ... Starting communication ... MCU ID: 13F00007218C60C1000000000000A01E ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411X Hash: 00002054 Algo: 05 Firmware: LO5,RE: 120407 1624 Imei: 355150017619382 Phone code: 0000 Prod. code: 252925020 Id calculation done; CODES: NET LO CODE: 0077427343 NET HI CODE: 1146974671 DIRECT UNLOCK: OK Done ! Time needed - 00:03:38 use ferious gold and update pack3 use exe SAGEMLOCO_BETA_v1.0.0.1926 and use driver PL2303_Prolific_DriverInstaller_v1.5.0 check video sagem my-411.mp4 - YouTube thankx ferious Team Nice update *********** |
12-22-2011, 15:34 | #10046 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | bb unlock Searching for usb device ... Reading info ... IMEI: 357256048392556 Calculating ... MEP LOCK: MEP-06813-002 MEP1 [SIM]: 8649151737504803 MEP2 [NETWORK]: 2395327362407890 MEP3 [NETWORK SUBSET]: 1869158792968956 MEP4 [SERVICE PROVIDER]: 5632752201618871 MEP5 [CORPORATE]: 8331938440591122 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:51 |
12-22-2011, 15:56 | #10047 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | vodafone555 unlock ok Make your handset power off, plug in the UART cable! Product: Vodafone555 Load DA file... Load AUTH file... Start to connect the handset, keep pressing the power on key! Start to read security information from handset... IMEI: 356694042785410 Security file: C:\Program Files\FuriouS-Gold\PACK8\Alcatel\Security\BackupSecurityFile\V55 5X-2AVDRO1 Read security information successfully! Start code calculate... Product: Vodafone555 IMEI: 356694042785410 Security file: C:\Program Files\FuriouS-Gold\PACK8\Alcatel\Security\BackupSecurityFile\V55 5X-2AVDRO1 NCK:2974989662 NSCK: SPCK: PCK: Code calculate finished successfully! I use LG GW300 rj45 cable |
12-23-2011, 07:02 | #10048 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | ZTE t50 unlock done Software engine version: 1.0.0.7623 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Aug 25 2011 20:48:00 RELEASE DATE : Jun 3 2010 07:00:00 FIRMWARE INFO : TEL_AU_P671A70V1.0.1B03-S IMEI : 86824600001477-9 BLUETOOTH ADDR : D8 F2 19 08 46 38 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; SP NEW DETECTED; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 1 (MCC: 1 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:15 |
12-23-2011, 07:13 | #10049 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | ZTE Tactile messaging done Code: Software engine version: 1.0.0.7615 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Apr 8 2011 10:17:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : ORG_FR_P671A80V1.0.0B18-S IMEI : 35635304005681-7 BLUETOOTH ADDR : 34 9D C5 C7 64 C6 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; SP NEW DETECTED; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 208 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:47 |
12-23-2011, 20:58 | #10050 (permalink) | |
No Life Poster Join Date: Aug 2009 Location: Future Age: 30
Member: 1093004 Status: Offline Thanks Meter: 4,382 | Siemens c65 unlocked!!!!!! Quote:
