04-27-2011, 10:45 | #8536 (permalink) |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | Software engine version: 1.0.0.5574 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Apr 10 2009 19:16:00 RELEASE DATE : Jul 8 2008 05:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_3A IMEI : 3542220xxxxxxxxxxx BLUETOOTH ADDR : 7E 09 55 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:08 |
04-27-2011, 13:07 | #8537 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | zte racer unlock Software engine version: 1.0.0.6607 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Oct 28 2010 03:32:00 RELEASE DATE : May 12 2010 18:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-53303002 IMEI : 3532940404xxxx-x BLUETOOTH ADDR : 84 01 0E 37 F5 98 CALCULATING; UNLOCK CODE: 34447518 UNLOCKED ! Time needed - 00:00:01 |
04-27-2011, 13:26 | #8538 (permalink) |
Temporary banned !! Join Date: Aug 2007 Location: Austria (Linz)
Member: 568521 Status: Offline Thanks Meter: 240 | Vodafone 231 Unlock Done Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:011A Reading ... Saved: SAGEM_14.20.02_27.04.2011_PARTIAL.bin Done ! Time needed - 00:01:20 |
04-27-2011, 17:33 | #8539 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | LG U900 Success: MODEL : U900 COMPILED DATE : Jan 23 2007 10:39:00 RELEASE DATE : Jan 23 2007 12:00:00 FIRMWARE INFO : U900-MSM6250A-V11g-JAN-23-2007-H3G-IT IMEI : 35930400050637-1 BLUETOOTH ADDR : 3D D3 33 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35930400050637100 BLUETOOTH ADDR: [OK] 3DD333561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED BR Allumts |
04-27-2011, 19:00 | #8540 (permalink) |
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | vodafone 236 Software engine version: 1.0.0.5779 Connect phone powered on ! Start auth ! SW Ver: ES-SR-P108E6(S)V1.0.0B02 Imei: 352785030165559 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0103 Reading ... Saved: ZTE_352785030165559_ES-SR-P108E6(S)V1.0.0B02_19.56.09_27.04.2011_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:25 |
04-28-2011, 09:08 | #8541 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | Huawei T156 Successfully Unlocked Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037229724 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_353081037229724_P1.2PU03V01.01_13.06.02_28. 04.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:52 |
04-28-2011, 09:08 | #8542 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | LG kp170 Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:55 |
04-29-2011, 16:53 | #8543 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | huawei g2200 unlocked Software engine version: 1.0.0.5779 Connect phone powered on ! Start auth ! SW Ver: 08.06.00:18.26.22:06.00.00:ULC2GL Imei: 359391025321209 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-32 [00 31] ... Preloader sent .... Loader sent .... Flash ID(0): 0020:8828 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:08:19 |
04-30-2011, 06:05 | #8544 (permalink) |
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | ZTE 102.. Software engine version: 1.0.0.5637 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003265783-6 BLUETOOTH ADDR : 07 43 44 4A 15 D0 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:10 |
04-30-2011, 10:50 | #8546 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 297936 Status: Offline Thanks Meter: 201 | sagem my411cv unlock... Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411Cv Hash: 00005228 Algo: 05 Firmware: EVN,SE: 200707 1617 Imei: 356575010262013 Phone code: 0000 Prod. code: 987014622 Id calculation done; CODES: NET LO CODE: 1582216756 NET HI CODE: 0504280692 DIRECT UNLOCK: OK Done ! Time needed - 00:02:26 |
04-30-2011, 12:45 | #8547 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | ZTE T870 Unlock Done Free with FG Logs : Code: Software engine version: 1.0.0.6607 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jul 8 2010 20:14:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : TEL_AU_P624B1V1.0.0B20-S IMEI : 35977303078173-5 BLUETOOTH ADDR : 72 C8 70 37 F5 98 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 1 (MCC: 1 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:48 LITTLE MASTER |
04-30-2011, 13:27 | #8548 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | Zong G.R231 unlock done. zte G.R231 unlocked. > IMEI: 35424903273**** > NCK: 805564913503 > SPCK: 122291143445 FOR SOME MODELS TYPE *983*8284# OR ###825*09# (WITHOUT SIM) TO ENTER THE N.P. CODE. B.R mobile mart. |
04-30-2011, 15:36 | #8549 (permalink) |
Freak Poster Join Date: Apr 2005 Location: pakistan
Member: 141121 Status: Offline Sonork: 100.1580885 Thanks Meter: 20 | Lg900g unlock sucess thanks furious LG900G UNLOCK INSTRUCTION WITH FURIOUS GOLD 1. FIRST SELECT GW300 FLASH UR PHONE WITH THIS FILE (GW300AT-00-V10c-204-XX-AUG-31-2009+2_TotalBin) DOWNLOAD SUPPORT AREA. 2.AFTTER FLASH PRESS UNLOCK SOFTWARE GIVE U CODES HEAR IS LOG Attach USB cable now ... Phone detected ! USB Port opened ! RamLoader download success; Config done ! Authorising; Authorisation passed; Getting memory info; Memory: EC000000B1 Getting unlock data; Checking unlock data; Calculating; IMEI: 0121920029737**** Codes: 3613742785820691 3613742785820691 3613742785820691 Enter codes using 2945#*71001# Restarting; Time needed - 00:00:39 3. INSERT ANY SIM CARD AND ENTER 1ST CODE 2 TIME AND ENJOY UR PHONE UNLOCKED. ENJOY WITH FURIOUS GOLD. |
04-30-2011, 19:19 | #8550 (permalink) |
No Life Poster Join Date: Dec 2008 Location: morocco
Member: 931360 Status: Offline Sonork: 100.1592533 Thanks Meter: 539 | unlock f100 succesful Software engine version: 1.0.0.6607 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 21 2009 19:05:00 RELEASE DATE : Sep 15 2009 20:00:00 FIRMWARE INFO : YOG_ES_P607C4V1.0.0B07-S IMEI : 358047xxxxxxxx-8 BLUETOOTH ADDR : 00 00 00 00 00 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 214 MNC: 4) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:50 |
