06-14-2012, 22:09 | #10786 (permalink) |
Freak Poster Join Date: Dec 2009 Location: near the mosque
Member: 1187394 Status: Offline Thanks Meter: 14 | Searching for usb device ... Reading info ... IMEI: 35988400227.... Calculating ... MEP LOCK: MEP-05277-004 MEP1 [SIM]: 2218314022438740 MEP2 [NETWORK]: 6234240909130114 MEP3 [NETWORK SUBSET]: 4545879780214617 MEP4 [SERVICE PROVIDER]: 4272023974521171 MEP5 [CORPORATE]: 0105520789521246 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:48 |
06-15-2012, 00:11 | #10787 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Code calculate finished successfully! Product: SFR3440 Provider ID: F344X-2[X=A]SFFR1 IMEI: 867242001112499 Start code calculate... NCK:0675694862 NSCK: SPCK: PCK: Code calculate finished successfully! Product: SFR3440 Provider ID: F344X-2[X=A]SFFR1 IMEI: 867242001112291 Start code calculate... NCK:3147081575 NSCK: SPCK: PCK: Code calculate finished successfully! |
06-15-2012, 16:05 | #10788 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | U2800A at&t done Searching phone ... Phone detected ... MODEL : Q62xx-OSBL- STARTING; OK; LOADING; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35663104510755-6 READING; SP_SAVED_TO: SP_35663104510755_E77_08.31.07_14.06.2012_HUAWEI.b in ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:01:43 |
06-16-2012, 09:44 | #10789 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 1B 35 C4 99 87 0A 9A 01 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:56 |
06-16-2012, 11:08 | #10790 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Connect phone powered on ! Start auth ! SW Ver: 08.06.00:18.26.22:06.00.00:ULC2GL Imei: 357356031021558 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-32 [00 31] ... Preloader sent .... Loader sent .... Flash ID(0): 0020:8828 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:08:35 |
06-17-2012, 16:12 | #10791 (permalink) |
Freak Poster Join Date: Apr 2008 Location: *.onion
Member: 740263 Status: Offline Sonork: 100.1608512 Thanks Meter: 37 | Searching Huawei phone COM ports... not found ! Searching Android USB Interface... OK Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Starting bootloader... OK Sending data to server... OK Reading data from server... OK Sending boot data... OK Initializing NAND functions... OK Initializing NV functions... OK Server disconnected! Reading NV item #550...OK Reading NV item #114...OK Reading NV item #60001...OK Searching for OEMINFO data... OK Product name: U8220 Model name: Huawei U8230 IMEI: 357262030502251 S/N: MV7NAC1012601074 Firmware: U8230V100R001C01B208_EFS SIM Lock status: locked (NCK lock) 2012-06-17 17:07:42.601 Start unlocking procedure (357262030502251) Connecting to server... failed! Server disconnected! failed! Error connecting to server ! 2012-06-17 17:08:03.770 Start unlocking procedure (357262030502251) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Reading NV item #550...OK Checking bootloader status... OK Reading NV item #114...OK Searching for OEMINFO data... OK Creating backup of Sensitive Data... OK Backup saved to file "D:\FURIOUS\7\HUAWEI_ANDROID_UNLOCKER_0020\Backup\ 357262030502251_2012-06-17_170818.fhb" Sending data to server... OK Reading data from server... OK Writing NAND... OK Verification... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... Error! Server disconnected! 2012-06-17 17:08:33.254 Done! Searching Huawei phone COM ports... not found ! Searching Android USB Interface... OK Checking bootloader status... OK Reading NV item #550...OK Reading NV item #114...OK Reading NV item #60001...OK Searching for OEMINFO data... OK Product name: U8220 Model name: Huawei U8230 IMEI: 357262030502251 S/N: MV7NAC1012601074 Firmware: U8230V100R001C01B208_EFS SIM Lock status: not locked |
06-18-2012, 05:39 | #10792 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 35 06 96 05 02 0A 05 Flash ID(0): 001C:22C4 PARTIAL: MiniFone_TDS12-1_UomeX V15_MEGAFON_RUSSIA RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:04:18 |
06-18-2012, 10:12 | #10793 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Searching for usb device ... Reading info ... IMEI: 351846038483252 Calculating ... MEP LOCK: MEP-16472-001 MEP1 [SIM]: 3134483456114458 MEP2 [NETWORK]: 9505118517407717 MEP3 [NETWORK SUBSET]: 5897479934792711 MEP4 [SERVICE PROVIDER]: 5982763900251904 MEP5 [CORPORATE]: 1380288792884748 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:01:54 |
06-18-2012, 14:35 | #10794 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.6486 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620031668868 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 0001:0110 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:03:58 |
06-18-2012, 15:00 | #10795 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.7886 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Nov 4 2011 17:25:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 86160300035935-5 BLUETOOTH ADDR : 4F 76 B7 B2 1A 68 TAG_ID:QCNDef DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:43 |
06-18-2012, 17:16 | #10796 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 50
Member: 178616 Status: Offline Thanks Meter: 90 | motorolla dext unloc successfuly Software engine version: 1.0.0.7894 Searching phone ... MODEL : QCOM SERIES 18 COMPILED DATE : Jul 1 2010 14:27:00 RELEASE DATE : May 5 2010 02:00:00 FIRMWARE INFO : M76XX-SDCBALUM-63805036 IMEI : 35669103017788-1 BLUETOOTH ADDR : 00 26 BA 39 64 4F LOADING DATA; DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; NETWORK: 27623474 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:49 |
06-19-2012, 12:00 | #10797 (permalink) |
Freak Poster Join Date: Nov 2008 Location: G̣ dầu -tây ninh
Member: 896966 Status: Offline Sonork: 100.1607398 Thanks Meter: 46 | ZTE t3020 unlock done Software engine version: 1.0.0.7891 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Jan 27 2011 10:36:00 RELEASE DATE : May 12 2010 18:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-53303002 IMEI : 35351804128561-4 BLUETOOTH ADDR : 90 60 AE C7 64 C8 TAG_ID:P726TB10e UNSUPPORTED FIRMWARE VERSION FOR UNLOCK.IF THE CODE(S) DONT WORK SELECT DUMP ME FROM JOBS AND SEND THE RESULTED FILE TO SUPPORT. FOR ACER AND BOSTON MODELS FLASH DEVICE WITH FIRMWARE FROM SUPPORT CALCULATING; UNLOCK CODE [OLD]: 22842170 UNLOCK CODE [NEW]: 13140136 COUNTER CLEAR DONE; UNLOCKED ! Time needed - 00:00:03 |
06-19-2012, 12:46 | #10798 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 1B 36 04 96 51 08 18 01 Flash ID(0): 001C:22C4 PARTIAL: MiniFone_TDS12-1_UomeX V15_MEGAFON_RUSSIA RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:25 |
06-20-2012, 05:45 | #10800 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 2100 ZONG unlock done COMM OPENED 5 ! BAUD SET ! AUTH MADE ! SW VERSION: HUAWEI G2100V100R001PAKC19B102SEC TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 351633041111439 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:21 |
