11-24-2011, 14:27 | #9886 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | Blackberry 8520 successfully unlocked. Reading info ... IMEI: 3559310321***** Calculating ... MEP LOCK: MEP-11414-002 MEP1 [SIM]: 6685291228342275 MEP2 [NETWORK]: 0097271220736008 MEP3 [NETWORK SUBSET]: 5712375814563565 MEP4 [SERVICE PROVIDER]: 9735293160585412 MEP5 [CORPORATE]: 0394477701674319 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:45 |
11-24-2011, 18:31 | #9887 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | My411 unlock done Press power on shortly ... Starting communication ... MCU ID: 2A7002098A765AC10000000000002E04 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411Cv Hash: 00002291 Algo: 05 Firmware: EVN,SE: 230707 1109 Imei: 35xxxxxxxxxxxxxxxxx Phone code: 0000 Prod. code: 252961761 Id calculation done; CODES: NET LO CODE: 2518493206 NET HI CODE: 3604818902 Done ! Time needed - 00:02:03 |
The Following User Says Thank You to yaro_rguez For This Useful Post: |
11-25-2011, 09:54 | #9888 (permalink) |
Crazy Poster Join Date: Mar 2011
Member: 1528503 Status: Offline Sonork: 100.1591188 Thanks Meter: 15 | Metfone 210H unlock done. Code: [IMG]file:///C:/DOCUME%7E1/THIEN_%7E1/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]Software engine version: 1.0.0.6047 Connect phone powered on ! Start auth ! SW Ver: P1.8TM01V01.04 Imei: 354053022038419 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:011A Reading ... Saved: HUAWEI_354053022038419_P1.8TM01V01.04_15.43.38_25.11.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:47 |
11-26-2011, 10:24 | #9889 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Ufone 1000 Successfully Unlocked. Code: COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042217357 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:12 B,R. |
11-26-2011, 11:44 | #9890 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g1000 ok Comm opened 4 ! Baud set ! Auth made ! Sw version: Rel_c1.2pu01v01.05 test mode status: Off sim status: Off imei: 356820040388028 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:12 |
11-26-2011, 11:45 | #9891 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | ufone g2201c unlock done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620033304520 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 0001:0110 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:03:42 |
11-26-2011, 12:02 | #9892 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892033248202 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892033248202_REL_P1.1PU01V01.06_12.19.13 _23.11.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:22 |
11-26-2011, 12:31 | #9893 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 354354031012522 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_354354031012522_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10_16.30.26_26.11.2011_PARTIA L.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 |
11-26-2011, 13:15 | #9894 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G1000 unlock done COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820040018997 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:13 |
11-26-2011, 15:33 | #9895 (permalink) |
Freak Poster Join Date: May 2007 Location: SL3 averages 13min/code Age: 44
Member: 501129 Status: Offline Thanks Meter: 63 | -ZTE F102 H3G unlock done Software engine version: 1.0.0.7439 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jul 15 2009 11:34:00 RELEASE DATE : Jun 24 2009 19:00:00 FIRMWARE INFO : H3G_GB_P607C3V1.0.0B07-sec IMEI : 35674003009320-8 BLUETOOTH ADDR : 41 05 F2 93 22 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:48 |
The Following User Says Thank You to haigoshi For This Useful Post: |
11-26-2011, 20:11 | #9896 (permalink) |
No Life Poster Join Date: Dec 2008 Location: morocco
Member: 931360 Status: Offline Sonork: 100.1592533 Thanks Meter: 539 | unlock sfr startrail titanium succesful in 3 secs Software engine version: 1.0.0.7439 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Mar 25 2011 02:49:00 RELEASE DATE : Aug 4 2010 16:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6030 IMEI : 867449xxxxxxxx-x BLUETOOTH ADDR : 78 62 C6 C7 64 C6 TAG_ID:733SFR07 INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:03 |
11-26-2011, 23:27 | #9897 (permalink) |
No Life Poster Join Date: May 2007 Location: MOROCCO
Member: 510826 Status: Offline Thanks Meter: 183 | Unlock Alcatel OT 710 Done : Start code calculate... Product: OT-710 IMEI: 35280XXXXXXXXXX Security file: C:\Program Files\FuriouS-Gold\PACK8\Alcatel\Security\BackupSecurityFile\710 X-2BVRFR1 NCK:2737739429 NSCK: SPCK:2599308959 PCK: Code calculate finished successfully! |
11-27-2011, 07:05 | #9898 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 2100 unlock done COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: HUAWEI G2100V100R001PAKC19B102SEC TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 351633041461107 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:15 |
11-27-2011, 09:32 | #9899 (permalink) |
Freak Poster Join Date: May 2007 Location: algeria Age: 44
Member: 516016 Status: Offline Thanks Meter: 118 | successfully unlock huawei tactile tv cu module HUAWEI.exe pack 2 choose modele VIRGIN VMX Searching phone ... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35879200000000-4 READING; SP_SAVED_TO:SP_35879200000000_DA6_17.26.43_23.11.2 011_HUAWEI.bin CHECKING; LOCKED_TO: MCC-MNC [0]: 208-01 MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:03:49 |
11-27-2011, 12:02 | #9900 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | sagem my411X unlock done Press power on shortly ... Starting communication ... MCU ID: 3270001113A463C10000000000003218 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411X Hash: 00002054 Algo: 05 Firmware: LO5,RF: 280607 1806 Imei: 351628021524825 Phone code: 0000 Prod. code: 252925020 Id calculation done; CODES: NET LO CODE: 2085521132 NET HI CODE: 1015973164 Done ! Time needed - 00:02:51 |
