10-26-2011, 07:23 | #9736 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039599843 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081039599843_P1.2PU01V01.01_04.51.42_22. 10.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:46 |
10-26-2011, 19:11 | #9737 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Huawei g2100 unlock done comm opened 146 ! Baud set ! Auth made ! Sw version: Huawei g2100v100r001tcdc151b100sec test mode status: Off sim status: Off imei: 351633048524535 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:17 |
10-27-2011, 06:05 | #9738 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 1000 ufone unlock done COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820041805939 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:12 |
10-27-2011, 06:05 | #9739 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 1000 unlock done COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820065892413 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:12 |
10-27-2011, 08:35 | #9740 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Zong huawei g2100 unlock done, just in 14sec . Zong huawei g2100 unlock done, just in 14sec . COMM OPENED 4 ! BAUD SET ! AUTH MADE ! SW VERSION: HUAWEI G2100V100R001PAKC19B102SEC TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 351633041597934 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:14 |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
10-29-2011, 06:40 | #9742 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 1000 ufone unlock done COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820041804049 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:14 |
10-29-2011, 07:14 | #9743 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 49
Member: 1275418 Status: Offline Thanks Meter: 432 | t 156 unlock Software engine version: 1.0.0.6047 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042331488 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 3A 84 97 C4 00 18 10 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042331488_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_05.11.25_20.10.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:49 Software engine version: 1.0.0.6047 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039441434 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081039441434_P1.2PU01V01.01_06.09.53_27. 10.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:02:0 |
10-29-2011, 07:15 | #9744 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | z100 flash ok oftware engine version: 1.0.0.6047 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039469906 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081039469906_P1.2PU01V01.01_04.21.00_16. 10.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:52 Software engine version: 1.0.0.6047 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 3A 84 97 C4 00 18 10 Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:08:09 |
10-29-2011, 08:03 | #9745 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Software engine version: 1.0.0.6109 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042317875 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 39 65 28 9A F5 56 0A 09 0E Flash ID(0): 00C2:22A7 Saved: ZTE_352865042317875_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_12.02.18_29.10.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:42 |
10-29-2011, 08:06 | #9746 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Z100 flash done Software engine version: 1.0.0.6304 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 29 65 38 DA F4 05 02 84 0A Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:07:08 |
10-29-2011, 08:26 | #9747 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | vdf 570 unlock done Press power on shortly ... Starting communication ... MCU ID: 1B200316F66000C20200000000009630 ROM HASH: 731C27AB2AE00189FBD4FD3013B53252 ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 00002910 Algo: 05 Firmware: EVN,PI: 060508 1555 Imei: 351959021440666 Phone code: 0000 Prod. code: 254053893 Id calculation done; CODES: NET LO CODE: 3925271566 NET HI CODE: 2838952782 Done ! Time needed - 00:02:11 |
10-29-2011, 08:38 | #9748 (permalink) |
No Life Poster Join Date: Dec 2009 Location: NIGER
Member: 1186610 Status: Offline Thanks Meter: 333 | Software engine version: 1.0.0.898 Searching phone ... MODEL : U370 COMPILED DATE : oct 13 2011 14:42:00 RELEASE DATE : May 18 2011 14:00:00 FIRMWARE INFO : U370W-MSM6245-V10b-NOV-16-2007-XX IMEI : 35839101059710-3 BLUETOOTH ADDR : DF 98 33 75 1E 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:0308 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:04 |
10-29-2011, 09:19 | #9749 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | skype S2 unlock done Software engine version: 1.0.0.7045 Searching phone ... MODEL : QCOM SERIES 2 [KYUZ] COMPILED DATE : Apr 10 2009 19:16:00 RELEASE DATE : Jul 8 2008 05:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_3A IMEI : 35422202167543-6 BLUETOOTH ADDR : E6 5D 53 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:18 |
10-29-2011, 14:13 | #9750 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G2100 zong unlock done COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: HUAWEI G2100V100R001PAKC19B102SEC TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 351633041440929 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:18 |
