11-22-2011, 09:09 | #9856 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | G1000 unlock done. Baud set ! Auth made ! Sw version: Rel_c1.2pu01v01.05 test mode status: Off sim status: Off imei: 356820040256951 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:11 |
11-22-2011, 09:23 | #9857 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | ZTE f107 unlocked successfuly. Software engine version: 1.0.0.7045 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jun 17 2010 15:58:00 RELEASE DATE : Dec 8 2009 23:00:00 FIRMWARE INFO : H3G_GB_P607C5V1.0.0B11-S IMEI : 35804803124**** BLUETOOTH ADDR : 74 4A 43 4A 15 D0 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0331 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:12 |
11-22-2011, 09:46 | #9858 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g1000 ok Comm opened 4 ! Baud set ! Auth made ! Sw version: Rel_c1.2pu01v01.05 test mode status: Off sim status: Off imei: 356820040666183 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:12 |
11-22-2011, 10:27 | #9859 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Z100 unlock done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865043445154 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 30 84 98 96 01 17 0F Flash ID(0): 00C2:22A7 Saved: ZTE_352865043445154_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_14.26.26_22.11.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:46 |
11-22-2011, 10:29 | #9860 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Z 100 unlock done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042533059 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 30 84 95 01 08 9D 05 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042533059_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_14.28.36_22.11.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:42 |
11-22-2011, 10:31 | #9861 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Z 100 unlock done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042542357 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 DB 35 44 97 22 05 8C 10 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042542357_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_14.30.38_22.11.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:39 |
11-22-2011, 10:33 | #9862 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Z 100 unlock done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042531533 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 1B 32 44 97 22 07 12 0E Flash ID(0): 00C2:22A7 Saved: ZTE_352865042531533_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_14.32.43_22.11.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:39 |
11-22-2011, 11:10 | #9863 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 171 | zte modem Mf100 Software engine version: 1.0.0.7045 Searching phone ... MODEL : MF MODEM SERIES COMPILED DATE : Jan 29 2010 13:31:00 RELEASE DATE : Jan 27 2010 17:00:00 FIRMWARE INFO : M6246A-KPRZL-2.2.0095T IMEI : 35951803044699-9 BLUETOOTH ADDR : 00 00 00 00 00 00 ENTERING SECURE MODE; ENTERED; GETTING CODE HASH (4); GETTING SIGN; GETTING LOCK; CALCULATING; UNLOCKED ! NOW RECONNECT MODEM TO USB PORT ! Time needed - 00:00:04 |
11-22-2011, 11:14 | #9864 (permalink) |
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 171 | Huawei modem E160 Software engine version: 1.0.0.7045 Searching phone ... MODEL : QCOM SERIES 7 [KPRB] COMPILED DATE : Sep 9 2008 21:37:00 RELEASE DATE : Sep 9 2008 21:37:00 FIRMWARE INFO : 11.608.02.00.94 IMEI : 35387102945921-8 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0076 MEMORY NAME : SAMSUNG_K9F1208 MEMORY INFO : 0200:0020:0280 UNLOCK INFO IMEI: 353871029459218 NCK: 41625918 UNLOCK STATUS: [OK] OK LOCK STATUS: [OK] OK Time needed - 00:00:01 |
11-22-2011, 12:09 | #9865 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g2201c unlock done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620031580642 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 00EC:0106 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:04:06 |
11-22-2011, 12:22 | #9866 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Martech Service Manager
Member: 600683 Status: Offline Sonork: 1581690 Thanks Meter: 26 | MODEL : QCOM SERIES 10 COMPILED DATE : Sep 7 2011 02:19:00 RELEASE DATE : Apr 1 2011 04:00:00 FIRMWARE INFO : ORG_UK_P622F2V1.0.0B11-S IMEI : 35734104055531-7 BLUETOOTH ADDR : 78 39 1C 08 46 38 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: B8386E1AD5356DDE570A4FCE4091CD43.bin ERASING; WRITING; READING; AFTER BACKUP: CF84B89A09F2DDE705B8D18D44C4009C.bin UNLOCKED; RESET ! Time needed - 00:00:19 |
11-22-2011, 13:25 | #9867 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | T 156 unlock done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039429587 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081039429587_P1.2PU01V01.01_17.24.25_22. 11.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:28 |
11-22-2011, 15:53 | #9868 (permalink) |
No Life Poster Join Date: Nov 2004 Age: 45
Member: 93284 Status: Offline Thanks Meter: 202 | ZTE F160 Atlanta Unlocked OK Code: Software engine version: 1.0.0.7045 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : May 5 2011 17:44:00 RELEASE DATE : Apr 1 2011 04:00:00 FIRMWARE INFO : ORG_PL_P622F2V1.0.0B05-S IMEI : 35734104063891-5 BLUETOOTH ADDR : 30 22 02 08 46 38 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:34 |
11-22-2011, 18:52 | #9869 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Exca100 unlock done Starting cab upload; Preparing to install; Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: EC006284D4593035343330380A0A0A0800 Doing sp area internally backup; Please wait; Saved: C:\Program Files\FURIOUS-GOLD\PACK6\HTC_EC006284D4593035343330380A0A0A0800_ 13.34.22_22.11.2011.bin IMEI: 357 NCK CODE: 07206422 Time needed - 00:00:52 |
11-22-2011, 23:54 | #9870 (permalink) |
No Life Poster Join Date: May 2007 Location: MOROCCO
Member: 510826 Status: Offline Thanks Meter: 183 | Unlock Palm P101UEU Done : DIAG CODE IS 63208 1. ENTER #*8727277# AND PRESS DIAL 2. ENTER THE DIAG CODE ABOVE AND PRESS VALIDATE 3. SET FROM LIST USB PORT 1 AS DIAG 4. SET USE USBNET TO DISABLED 5. CONNECT USB AND INSTALL DRIVERS 6. AFTER UNLOCK UNDO ALL CHANGES MADE IN MENU ****************************************** Software engine version: 1.0.0.7045 Searching phone ... MODEL : QCOM SERIES 15 COMPILED DATE : May 12 2010 16:30:00 RELEASE DATE : May 12 2010 16:13:00 FIRMWARE INFO : CU0.5.42(257) IMEI : 35995803014667-0 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0036 MEMORY NAME : samsung_k9f1208 MEMORY INFO : 0200:0020:033C WORKING; UNLOCKED; POWER OFF PHONE TO COMPLETE UNLOCK AND AFTER DISABLE THE DIAG; Time needed - 00:00:01 |
