12-04-2011, 08:12 | #9931 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | Vodafone 455 unlock done PACK 8 Make your handset power off, plug in the UART cable! Product: OT-455 Load DA file... Load AUTH file... Start to connect the handset, keep pressing the power on key! Start to read security information from handset... IMEI: 355768041861991 Security file: C:\Program Files\FuriouS-Gold\PACK8\Alcatel\Security\BackupSecurityFile\455 X-2BVDGB1 Read security information successfully! Start code calculate... Product: OT-455 IMEI: 355768041861991 Security file: C:\Program Files\FuriouS-Gold\PACK8\Alcatel\Security\BackupSecurityFile\455 X-2BVDGB1 NCK:0117626562 NSCK: SPCK: PCK: Code calculate finished successfully! |
12-04-2011, 13:19 | #9932 (permalink) |
Freak Poster Join Date: Dec 2004 Location: UNITED KINGDOM
Member: 96918 Status: Offline Sonork: 100.1602725 Thanks Meter: 32 | monte carlo successfully unlock 1.power off then just hold down -vol key and power for 5 to 10 sec it will show you ftm mode 2.connect with cable install driver if needed and press do job . |
The Following User Says Thank You to adnanshahzad For This Useful Post: |
12-05-2011, 09:37 | #9933 (permalink) |
No Life Poster Join Date: Nov 2004 Age: 45
Member: 93284 Status: Offline Thanks Meter: 202 | Vodafone 246 Unlock OK Code: Software engine version: 1.0.0.6304 Insert cable in box now [NO BATTERY INSIDE PHONE] ! Starting communication ... Platform: E-Gold Voice3-32 [00 00] ... Preloader sent .... Loader sent .... Flash ID(0): 00EF:4016 Checking firmware version ... Detected: ED-DE-P118A2V1.0.0B12 Saved: ZTE_NONE_ED-DE-P118A2V1.0.0B12_10.40.09_02.12.2011_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:51 |
12-05-2011, 13:15 | #9934 (permalink) |
Member: 93284 Status: Offline Thanks Meter: 202 | Orange Rio II P671A80 Unlock OK Code: Software engine version: 1.0.0.7439 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Apr 8 2011 09:18:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : ORG_UK_P671A80V1.0.0B23-S IMEI : 35635204014491-2 BLUETOOTH ADDR : 48 9C C7 C7 64 C6 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; SP NEW DETECTED; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 33) LOCKED NET 1 (MCC: 234 MNC: 86) LOCKED NET 2 (MCC: 1 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:35 BR |
12-07-2011, 05:54 | #9935 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | ufone g2201c unlock ok Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620033305899 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 0001:0110 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:04:13 |
12-07-2011, 05:55 | #9936 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g2158 done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892032741306 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892032741306_REL_P1.1PU01V01.06_18.38.19 _03.12.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:31 |
12-07-2011, 05:56 | #9937 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g2158 done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.03 Imei: 358892031492471 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Reading ... Saved: HUAWEI_358892031492471_REL_P1.1PU01V01.03_16.19.00 _03.12.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:02 |
12-07-2011, 05:57 | #9938 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | g1157 done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081033203954 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081033203954_P1.2PU01V01.01_18.41.47_03. 12.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:40 |
12-07-2011, 08:48 | #9939 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | T 156 unlock done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031735128 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_358146031735128_P1.2PU01V01.02_12.46.09_07. 12.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:29 |
12-07-2011, 09:49 | #9940 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | G2158 unlocked Software engine version: 1.0.0.5779 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892032978411 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892032978411_REL_P1.1PU01V01.06_13.36.36 _07.12.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:12 |
12-07-2011, 12:12 | #9941 (permalink) |
Freak Poster Join Date: May 2010 Location: Sadder, Karachi, Pakistan
Member: 1298429 Status: Offline Sonork: 100.109487 Thanks Meter: 57 | Acer Liquid 100 unlocked!! Software engine version: 1.0.0.7441 Searching phone ... MODEL : QCOM SERIES 16 COMPILED DATE : Oct 6 2010 16:43:00 RELEASE DATE : Mar 29 2010 13:00:00 FIRMWARE INFO : 8650B-SDCAOLYM-4075 IMEI : 35350803031995-3 BLUETOOTH ADDR : 00 16 D4 51 47 49 LOADING DATA; DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; NETWORK: 91334140 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. RESET ! Time needed - 00:00:56 |
12-07-2011, 16:42 | #9942 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Zte Z221 unlocked Software engine version: 1.0.0.7439 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Aug 8 2011 19:45:00 RELEASE DATE : Apr 19 2011 08:00:00 FIRMWARE INFO : ATT_AM_P671B40V1.0.0B09-S IMEI : 35661304031454-4 BLUETOOTH ADDR : A9 06 B3 62 B3 B4 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 0D0A2225DBA14CB738A8889040C1E0E9.bin ERASING; WRITING; READING; AFTER BACKUP: 425922645A7FEB6B5CA4AE552F6B79AE.bin UNLOCKED; RESET ! Time needed - 00:00:12 |
12-08-2011, 06:32 | #9943 (permalink) |
Banned Join Date: Feb 2008 Location: GSM Nowshera
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | gs360 54106046505332 nck: 7017315657703394 nsck: 8789809018142267 spck: 3948102387319230 cpck: 8476161288999923 simck: 4207868927802961 |
12-08-2011, 10:49 | #9944 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | HUAWEI U1280 DONE ! Searching phone ... Phone detected ... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35529103245930-3 READING; SP_SAVED_TO: SP_35529103245930_EA1_11.44.39_08.12.2011_HUAWEI.b in CHECKING; LOCKED_TO: MCC-MNC [0]: 259-05 MCC-MNC [1]: FFF-FF MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:04:04 |
12-08-2011, 14:16 | #9945 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | T156 unlock done Software engine version: 1.0.0.6314 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081033972483 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081033972483_P1.2PU01V01.01_18.14.53_08. 12.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:24 |
