01-28-2015, 14:24 | #12288 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1271541 Status: Offline Thanks Meter: 35 | alcatel 3002g flash Done Successfully Using library Brom_DLL_v5.1316.1 EMI Settings Loaded; COM opened ok; Press power and keep it pressed now ! Requesting authorization; Done; Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6250_S0001 [CA01, 01, 625A, 05] MEMORY: [Numonyx] N25W256 [2C:CB:19] [SIZE=0x02000000] FAT INFO: 0x00E80000 SIZE: 0x01180000 IMEI1 [OTP]: 861221-02-080493-6 IMEI2 [OTP]: N/A Loading the file ... Cfg done ... File contents to write: [70008000-7000B7E7] ARM_BL [FFFFFFFF-00000406] ROOT_CERT [10008000-100122F3] ARM_EXT_BL [10E7E000-10E7E9AB] SECURE_RO_ME [100C0000-108AF143] PRIMARY_MAUI [10980000-10C12FC3] CUSTOM_PACK [10D00000-10D02E33] STUDYPARA_ROM [10D03000-10D03517] JUMP_TABLE [10D04000-10DA3DD3] VIVA Downloading bootloader... Done; Pre-formatting code area.. Done; Downloading images... Done; Done; Done; Done; Done; Done; Done; Formatting file system now... Done; Time needed - 00:12:02 |
01-31-2015, 13:47 | #12289 (permalink) |
No Life Poster Join Date: Sep 2002 Location: India
Member: 15238 Status: Offline Thanks Meter: 128 | alcatel ot-7040A locked to Boost Australia Unlock DONE This was a Phone locked to AUS - Boost Alcatel 7040A other tools were prompting for ROOT etc. etc. BUT otsmart did it in seconds. Only thing keep in mind - use Proper drivers attached with the latest OTsmart package. Code: Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM13 Connecting; Downloading DA; Initializing; Rid: b26226a0e577767af4892cbf989d422b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM17; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, FF] HW_STORAGE_EMMC: 0x30000111 0x39473430 0x14D31030 0x797176B5 [SIZE=0xEC480000] IMEI1 [OTP 0001]: 014278-00-026429-7 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 7040A-2BB7AU3 USRDATA INFO: 0x65880000 SIZE: 0x86C00000 Searching data; Locked to [SIM1]: 505-01 code_cat_n: 2877416827 enabled: yes tries: 99 code_cat_ns: 1604180068 enabled: no tries: 10 code_cat_sp: 3786193516 enabled: no tries: 10 code_cat_c: 0921997401 enabled: no tries: 10 code_cat_sim: 1644019895 enabled: no tries: 10 code_cat_ns_sp: 1424094490 enabled: no tries: 5 code_cat_sim_c: 1925051604 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:18 |
02-01-2015, 17:31 | #12291 (permalink) |
No Life Poster Join Date: Jan 2014
Member: 2108593 Status: Offline Thanks Meter: 839 | Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (@oem2.inf,%mtk_preloader%;MediaTek PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM12 Connecting; Downloading DA; Initializing; Rid: b359fab6181616703fce4b770a97f0ee Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem2.inf,%mtk_sp_da%;MediaTek DA USB VCOM Port) TRYING TO OPEN COM19; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x30000111 0x39473430 0x94081030 0xA761712F [SIZE=0xEC480000] IMEI1 [OTP 0001]: 3552xxxxxxxxxx84-5 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V785-2BVDGB1 USRDATA INFO: 0x61B80000 SIZE: 0x8A900000 Searching data; Locked to [SIM1]: 234-15 code_cat_n: 01407089 enabled: yes tries: 7 code_cat_ns: 19984785 enabled: no tries: 10 code_cat_sp: 19107456 enabled: no tries: 10 code_cat_c: 19206756 enabled: no tries: 10 code_cat_sim: 00500720 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:12 |
02-01-2015, 17:32 | #12292 (permalink) |
02-02-2015, 13:28 | #12293 (permalink) |
No Life Poster Join Date: Aug 2008 Location: The Matrix :) Age: 36
Member: 833760 Status: Offline Sonork: 100.1597150 Thanks Meter: 114 | IRBIS TX77 unlocked IRBIS TX77 Tablet (MTC) successfuly unlocked by MTK CODE READER: |
The Following User Says Thank You to ..::SuB::.. For This Useful Post: |
02-05-2015, 05:08 | #12294 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Alcatel OT4015D flash success OT 4015D OK Code: Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM16 Connecting; Downloading DA; Initializing; Rid: 59c8658eaba436d9869638ccf64828c7 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM24; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x4E000115 0x4D5A5835 0x57B00142 0x911149CA [SIZE=0xE9880000] IMEI1 [OTP 0001]: 863283-02-561719-0 IMEI2 [OTP 0001]: 863283-02-561720-8 PROVIDER: 4015D-2CRGCM3 USRDATA INFO: 0x5D680000 SIZE: 0x8C200000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:25:56 |
02-05-2015, 08:58 | #12295 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | ZTE X760 unlocked done > IMEI: 3523530225xxxxx > NCK: 915994165822 > SPCK: 377499385175 FOR SOME MODELS TYPE *983*8284# OR ###825*09# (WITHOUT SIM) TO ENTER THE N.P. CODE. |
02-05-2015, 19:35 | #12296 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | HTC Original unlock code read done... Starting cab upload; Preparing to install; Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: EC00DC5FC4C53037313630350505060700 Doing sp area internally backup; Please wait; Saved: F:\Box Softwares\Furious Gold\PACK6\HTC_EC00DC5FC4C53037313630350505060700_ 17.30.09_05.02.2015.bin IMEI: N/A NCK CODE: 63639841 Time needed - 00:00:44 |
02-07-2015, 11:16 | #12297 (permalink) |
Freak Poster Join Date: Mar 2004 Location: VietNam Age: 44
Member: 56938 Status: Offline Sonork: 100.1590777 Thanks Meter: 152 | Unlock ZTE B790 ok Step by step Unlock ZTE B790 by furious gold pack 5 Tool : Qcom smart tools - Amdo Thanks Furious Team |
The Following User Says Thank You to nhumanh For This Useful Post: |
02-07-2015, 15:13 | #12299 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | VODAFONE 236 UNLOCK Software engine version: 1.0.0.6572 Connect phone powered on ! Start auth ! SW Ver: ED-DE-P108E6(S)V1.0.0B05 Imei: 35278XXXXXXXXXX Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0103 Reading ... Saved: ZTE_35278XXXXXXXXXX_ED-DE-P108E6(S)V1.0.0B05_19.36.33_07.02.2015_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:05 |
