09-27-2009, 10:04 | #1261 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | vodafone 830 unlock ok FG MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Memory Info: 00AD:0078 Nand init done; Reading; Imei : 3542680***2235-6 Reading; SP saved to: SP_35426802072235_5DD_14.00.19_27.09.2009_HUAWEI.b in Erasing; Writing; Unlocked ! Done ! Time needed - 00:00:25 |
09-27-2009, 16:13 | #1262 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Amoi skype S1 unlocked successfully with my hot Bling Bling Software engine version: 1.0.0.2824 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Oct 18 2007 02:01:00 RELEASE DATE : Aug 10 2007 08:00:00 FIRMWARE INFO : M6260A-KYRZ-2.1.3022 IMEI : 357---------- BLUETOOTH ADDR : 1C 04 39 40 12 00 MEMORY ID : 00AD:0036 MEMORY NAME : hynix_hycosehomf3p MEMORY INFO : 0200:0020:06BD INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:07 |
The Following User Says Thank You to azeem781986 For This Useful Post: |
09-28-2009, 08:01 | #1264 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 319956 Status: Offline Thanks Meter: 124 | successfully unlocked 8900 new security successfully unlocked blackberry 8900 new security here is log:- Searching for usb device ... Reading info ... IMEI: 353471033591880 Calculating ... MEP: MEP-04598-005 MEP2 CODE: 5631383045370866 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:12 thanks furious team wbr;- johnysofts |
09-28-2009, 08:48 | #1265 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | u 900 unlocked FG Software engine version: 1.0.0.2824 Searching phone ... MODEL : U900 COMPILED DATE : Nov 13 2006 15:43:00 RELEASE DATE : Nov 13 2006 12:00:00 FIRMWARE INFO : U900-MSM6250A-V11e-NOV-13-2006-H3G-IT IMEI : 35930400376039-7 BLUETOOTH ADDR : DE 55 40 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35930400376039700 BLUETOOTH ADDR: [OK] DE5540561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:16 |
09-28-2009, 14:41 | #1267 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Blackberry 8320 orange Searching for usb device ... Reading info ... IMEI: 354005028099415 Calculating ... MEP: MEP-07321-002 MEP2 CODE: 41394263 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:13 |
The Following User Says Thank You to Unlocker AL For This Useful Post: |
09-29-2009, 10:31 | #1268 (permalink) |
No Life Poster Join Date: Apr 2009 Location: lebanon Age: 37
Member: 1008455 Status: Offline Sonork: 0000 Thanks Meter: 99 | thanks F G T Press power on ! Start auth ! SW Ver: P1.2JD01V01.01:ULC2GL Imei: 358545027502048 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:08 ---------------------------------------------------------- Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:21 |
09-29-2009, 11:03 | #1269 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Islamic Republic Age: 36
Member: 466635 Status: Offline Sonork: 100.1614186 Thanks Meter: 482 | Press power on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 35308103411**** PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:04 |
09-29-2009, 11:05 | #1270 (permalink) |
09-30-2009, 04:52 | #1273 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | U 890 unlock ok fg Software engine version: 1.0.0.2824 Searching phone ... MODEL : U890 COMPILED DATE : Apr 18 2006 14:28:00 RELEASE DATE : Apr 18 2006 17:00:00 FIRMWARE INFO : U890-MSM6250A-V10a_wm-APR-18-2006-H3G-UK IMEI : 35921300317681-1 BLUETOOTH ADDR : 9F 66 44 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35921300317681100 BLUETOOTH ADDR: [OK] 9F6644561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01: |
09-30-2009, 04:55 | #1274 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Software engine version: 1.0.0.2824 Searching phone ... MODEL : U310 COMPILED DATE : Oct 12 2006 14:55:00 RELEASE DATE : May 9 2006 17:00:00 FIRMWARE INFO : U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI : 35281801228085-4 BLUETOOTH ADDR : EE BE 63 A1 19 00 MEMORY ID : 0098:0076 MEMORY NAME : toshiba_ty90009800cogg MEMORY INFO : 0200:0020:0900 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35281801228085400 BLUETOOTH ADDR: [OK] EEBE63A11900 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:17 |
09-30-2009, 17:56 | #1275 (permalink) |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | ks360 unlocked by furio gold ok ks360 unlocked in fuw sec by furios : lateste ke module pak1 use come port with ke500 ,kf300 cable and read code Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 27059930 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:15 |
