10-01-2009, 07:37 | #1276 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Islamic Republic Age: 36
Member: 466635 Status: Offline Sonork: 100.1614186 Thanks Meter: 482 | Bb 8100 Reading info ... IMEI: 35967501016**** Calculating ... MEP: MEP-04626-002 MEP2 CODE: 22287484 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:32 b.r SHERRY MOBILES |
10-01-2009, 08:17 | #1277 (permalink) |
Banned Join Date: Nov 2007 Age: 36
Member: 631286 Status: Offline Thanks Meter: 1,250 | Software engine version: 1.0.0.2824 Searching phone ... MODEL : U450 COMPILED DATE : May 4 2007 12:01:00 RELEASE DATE : May 9 2006 17:00:00 FIRMWARE INFO : U450-MSM6250-V10a-MAY-04-2007-H3G-IT IMEI : 35658001090986-0 BLUETOOTH ADDR : 82 2E 1B 62 1C 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:18D2 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35658001090986000 BLUETOOTH ADDR: [OK] 822E1B621C00 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:14 |
10-01-2009, 09:33 | #1278 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Software engine version: 1.0.0.2824 Searching phone ... MODEL : U370 COMPILED DATE : Dec 20 2007 15:20:00 RELEASE DATE : May 17 2007 14:00:00 FIRMWARE INFO : U370W-MSM6245-V10c-DEC-20-2007-XX IMEI : 35839101159506-4 BLUETOOTH ADDR : 47 29 C1 75 1E 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:0308 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:07 |
10-01-2009, 09:33 | #1279 (permalink) |
10-01-2009, 09:50 | #1280 (permalink) |
10-01-2009, 14:41 | #1281 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | Software engine version: 1.0.0.2950 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Apr 22 2009 14:35:00 RELEASE DATE : Nov 12 2008 22:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_8A IMEI : 35454102120834-8 BLUETOOTH ADDR : 90 EA 4D 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:06 AMOI INQ1 SUCESSFULL UNLOCKED Last edited by delchoni; 10-01-2009 at 14:50. |
10-01-2009, 20:40 | #1282 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 789577 Status: Offline Sonork: 1601878 Thanks Meter: 39 | Software engine version: 1.0.0.2950 Searching phone ... MODEL : CU920 COMPILED DATE : Dec 12 2008 14:36:00 RELEASE DATE : Nov 10 2008 23:00:00 FIRMWARE INFO : CU920-MSM4090201D-V10s-DEC-12-2008-ATT-US IMEI : 01148900707020-6 BLUETOOTH ADDR : 65 09 E5 A9 22 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:22 |
10-02-2009, 10:38 | #1283 (permalink) |
No Life Poster Join Date: Apr 2009 Location: lebanon Age: 37
Member: 1008455 Status: Offline Sonork: 0000 Thanks Meter: 99 | Press power on ! Start auth ! SW Ver: P1.2JD01V01.04:ULC2GL Imei: 353081032799861 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:06 Done ! Time needed - 00:00:21 --------------------------------------------- Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:23 |
10-02-2009, 16:10 | #1284 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | blackberry 9630 verizon usa unlocked ok Searching for usb device ... Reading info ... IMEI: 980045002177391 Calculating ... MEP: MEP-15326-002 MEP2 CODE: 61790214 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:26 |
10-03-2009, 05:13 | #1285 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | vodafone v 810 unlock ok FG Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Memory Info: 00EC:0078 Requesting random data ... Sending data ... Authorisation started ... Authorisation passed ... Unlock Code: 7777777777777777 Done ! Time needed - 00:00:11 |
10-03-2009, 08:40 | #1286 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Searching for usb device ... Reading info ... IMEI: 3594xxxxxxxxx Calculating ... MEP: MEP-06424-002 MEP2 CODE: 9244970422487669 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:32 |
10-03-2009, 08:41 | #1287 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Press Power On shortly ! Phone Detected ! Loading ... Boot info: FuriouSTeaM GSM DEVELOPEMENT Imei: 35734500205386-4 Flash ID 1: 0089:8810 0101 Flash ID 2: 0089:880D 0101 Reading info ... Firmware info: Amoi 9201-V12.0 Loading ... Loading ... Booting system ... Please wait ! Loader version: FuriouSTeaM GSM DEVELOPEMENT Setup done ... Phone code: 0000 Security locks disabled ... Phone unlocked ! Time needed - 00:01:20 |
10-03-2009, 12:09 | #1288 (permalink) |
Banned Join Date: Mar 2006
Member: 239004 Status: Offline Sonork: 100.1589817 Thanks Meter: 388 | T156 HUAWEI UNLOCKED Press power on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081033788509 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:03 |
10-03-2009, 12:23 | #1289 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 606302 Status: Offline Thanks Meter: 17 | KF310 unlock 100% Software engine version: 1.0.0.2950 Searching phone ... MODEL : KF310 COMPILED DATE : Dec 11 2008 11:43:00 RELEASE DATE : Nov 28 2008 08:00:00 FIRMWARE INFO : KF310-MSM6245-V10b-NOV-28-2008-XX IMEI : 354000000000000-7 BLUETOOTH ADDR : AD 6C 85 FB 21 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:02FD INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:06 Last edited by ::.imeimate.::; 10-03-2009 at 15:15. |
10-03-2009, 13:22 | #1290 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | Searching for usb device ... Reading info ... IMEI: 35764600/////// Calculating ... MEP: MEP-06041-004 MEP2 CODE: 4831454412433888 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:15 |
