03-26-2018, 23:05 | #14491 (permalink) |
No Life Poster Join Date: Sep 2010 Location: Cali-Colombia Age: 46
Member: 1389840 Status: Offline Sonork: 100.1627479 Thanks Meter: 114 | Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MediaTek USB Port (COM33)) Preparing to start flash mode; Preparing to open COM33 Connecting; Downloading DA; Initializing; Rid: b8a9a008166f7f84cb081e4256515d42 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem128.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM183; DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x484A0190 0x61344741 0xF117A432 0x6BC30AE1 [SIZE=0x3AC000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x125000000 SIZE: 0x285380000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_26_03_2018_16_51_38.txt |
03-27-2018, 14:06 | #14492 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | Alcatel U5 4047x unlock sim OTSmart Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM230)) Preparing to start flash mode; Preparing to open COM230 Connecting; Downloading DA; Initializing; Rid: 6464d539f78013ef33ba342ccff115b9 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x484A0190 0x61344738 0x354DA532 0x23344A65 [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 35xxxxx IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 4047X-2AVDRO1 USRDATA INFO: 0xCE800000 SIZE: 0xFFC80000 Searching data; Locked to [SIM1]: 226-01 code_cat_n: 35574126 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 35574126 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:07 Log file saved to: LOG_27_03_2018_15_44_36.txt |
03-27-2018, 15:23 | #14493 (permalink) |
Freak Poster Join Date: May 2006 Location: Kosovo
Member: 272517 Status: Offline Sonork: 1604061 Thanks Meter: 68 | Doro 632 unlock Done... Searching phone; Phone detected (@oem73.inf,%mtk6218%;MTK USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: SHUTTLE02A-S08A_DORO632_L17GE_200_151021 Hw Version: CKT76_11A_HW Reading phone info; IMEI: 352427-06-191071-6 Reading simlock info; Unlock codes: Locked to: 228-01 code_cat_n: 59094924 enabled: yes tries: 8 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Time needed - 00:00:29 Log file saved to: LOG_27_03_2018_16_21_16.txt |
03-27-2018, 16:59 | #14494 (permalink) |
Freak Poster Join Date: Jul 2014 Location: Haiti
Member: 2216186 Status: Offline Sonork: 100.1668130 Thanks Meter: 120 | Alcatel OT-5056O Unlock & FRP Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM195 Connecting; Init; Port opened; Phone detected (@oem143.inf,%ztedevice0112%;ZTE Handset Diagnostic Interface(DFU)) Preparing to start flash mode; Preparing to open COM10 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 14.7 GB IMEI: 01458400037666-2 PTH: 06 PTS: HAQ PROV_ID: 5056O-2AAQUS1-R1 SBTADDR: F0:34:04:87:B41 SWIFIADDR: F0:34:04:87:B42 HS_PN: SAA1F5AWA10C SSN: Y2KE02CCVGZ04EB Work id: 020DB4DC Done; Stype: 00000001 SECURITY: X8C0LS01BR20 Size: 000002A5 Backup saved to: 01458400037666-2 Backup file(s) removed; Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; FRPEx Done; Log file saved to: LOG_27_03_2018_10_46_06.txt Time needed - 00:01:22 |
03-27-2018, 17:30 | #14495 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | vodafone 600 Software engine version: 1.0.0.10659 Searching phone ... MODEL : QCOM SERIES 51 COMPILED DATE : Dec 28 2017 14:54:00 RELEASE DATE : Jul 24 2017 21:00:00 FIRMWARE INFO : MPSS.JO.1.1.c1-00049-8909_GEN_PACK-1.97462.1.108480.1 IMEI : 355595074xxxxx-5 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: PT_MR2_VDF_P809V50V1.0.0B23 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\TM\Desktop\vdf60\QCOM_SMART_TOOL_v1.0.0.1 0659\355595074xxxxxx_27_03_2018_17_23_22.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM4 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM3)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_27_03_2018_17_27_42.txt Time needed - 00:04:23 |
03-27-2018, 19:10 | #14496 (permalink) |
Freak Poster Join Date: Aug 2004 Location: WORLDWIDE
Member: 78516 Status: Offline Thanks Meter: 62 | Vodafone vfd 510 frp removal VODAFONE VFD510 PACK 5 QCOM SMART TOOL MODULE USB CABLE enter FTM mode with volume down and power use ZTE HANDSET DIAGNOSTIC INTERFACE driver ( port com) select port com and do job BR |
03-27-2018, 23:33 | #14497 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 4047G FRP DONE Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM (Android) (COM228)) Preparing to start flash mode; Preparing to open COM228 Connecting; Downloading DA; Initializing; Rid: 1ae3e52866b87ce8d4b5e19e4dc73bd5 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0x9B520705 0x8554C70C [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 014910-00-376664-3 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 4047G-2ARGDO1 USRDATA INFO: 0xCE800000 SIZE: 0xFFC80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_27_03_2018_18_32_41.txt |
03-28-2018, 13:37 | #14498 (permalink) |
Member: 880649 Status: Offline Thanks Meter: 73 | ot-4015x -2ARGRO3 Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on FTEAM USB Serial Port (COM399); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.P3 Hw Version: JRDSZ72_WE_JB3_HSPA_HW Reading phone info; IMEI: 86xxx Reading simlock info; Locked to: 226-10 code_cat_n: 2479568226 enabled: yes tries: 10 code_cat_ns: 9067644128 enabled: no tries: 10 code_cat_sp: 7441396693 enabled: no tries: 10 code_cat_c: 3203963221 enabled: no tries: 10 code_cat_sim: 9835634395 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:01:43 Log file saved to: LOG_28_03_2018_15_25_33.txt |
03-28-2018, 15:23 | #14499 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | ALCATEL OT 7048X(ALCATEL GO PLAY) LOCKED BY MTN CAMEROON UNLOCK DONE USING FURIOUS GOLD PACK5 Code: Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem116.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM42 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 size 7,3 GB IMEI: 86702302131365-9 PTH: 07 PTS: FMP PROV_ID: 7048X-2AMNCM7 SBTADDR: F0:34:04:83:16:79 SWIFIADDR: F0:34:04:83:16:7A HS_PN: SAA64HAAC10C SSN: 5WKB26BBLEZ00KT Work id: 1933BBD5 Setup 1; Done; Setup 2; Done; Setup 3; Done; Uploading; Done; SECURITY: X7FM1UP0BQ00 Size: 00000430 Backup saved to: 86702302131365-9 Backup file(s) removed; Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; Erase Done; FRPEx Done; Log file saved to: LOG_28_03_2018_15_11_36.txt Time needed - 00:00:28 |
03-28-2018, 16:57 | #14500 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Software engine version: 1.0.0.10643 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Jul 2 2017 03:07:00 RELEASE DATE : Jun 27 2017 02:00:00 FIRMWARE INFO : MPSS.JO.3.0-00306-8909_GEN_PACK-1.102677.1.105159.1 IMEI : 866964xxxxxxxx-1 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: P890A06V1.0.0B13 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\cell center\Desktop\01-FURIUOS GOLD DONGLE\QCOM_SMART_TOOL_v1.0.0.10643\86696403410664 _28_03_2018_11_50_32.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM36 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_28_03_2018_11_52_47.txt Time needed - 00:02:18 |
03-28-2018, 22:15 | #14501 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Central America
Member: 746276 Status: Offline Sonork: 100.1609752 Thanks Meter: 675 | ZTE A520 locked to Claro, succesfully unlocked via direct unlock. |
The Following User Says Thank You to netmobile For This Useful Post: |
03-29-2018, 00:31 | #14502 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 5056n unlock done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem207.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM11 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 14.6 GB IMEI: 01465000541634-8 PTH: 08 PTS: B71 PROV_ID: 5056N-2ATBUS7 SBTADDR: CC:FD:17:85:3E:B3 SWIFIADDR: CC:FD:17:81:95:81 HS_PN: SAA1F5BWA10C SSN: N6KB12CERPZ071J Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 087BDBA4 Done; Stype: 00000001 SECURITY: XUB0UP01BR10 Size: 000002C3 Backup saved to: 01465000541634-8 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_28_03_2018_19_29_35.txt Time needed - 00:09:54 |
03-29-2018, 22:06 | #14503 (permalink) |
Freak Poster Join Date: Dec 2009 Location: JAM
Member: 1196714 Status: Offline Thanks Meter: 238 | COOLPAD 3622A SIM_LOCK REMOVED ! done by QCOM SMART TOOL Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: COOLPAD MODEL: COOLPAD 3622A ANDROID: v5.1.1 CPU: QCOM IMEI: NA KERNEL: Linux version 3.10.49-g3523c12-00138-g30951a4 (mine@ubuntu) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Mar 31 14:39:55 CST 2017 Cleaning; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [Coolpad Android Diagnostics USB VCOM (COM64)] Backing up sensitive data; connect_server: OK; backup in progress: OK; Backup saved to: C:\Furious-Gold\ADB\ Done; Done; Done; Restarting the phone; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [Coolpad Android Diagnostics USB VCOM (COM64)] Restoring sensitive data; connect_server: OK; restore in progress: OK; Done; SIM_LOCK REMOVED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE THE UNLOCK ! Log file saved to: LOG_29_03_2018_16_01_56.txt Time needed - 00:04:35 |
The Following 2 Users Say Thank You to shainelus For This Useful Post: |
03-31-2018, 12:04 | #14504 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | VNS-L11 IMEI Done Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2018-03-06 17:29:34.520 Autodetect started! 2018-03-06 17:29:35.208 Found COM port: COM354 2018-03-06 17:29:35.211 Open port COM354 (Android Adapter PCUI (COM354))... 2018-03-06 17:29:35.326 Start read phone info! 2018-03-06 17:29:36.340 Connecting to server... 2018-03-06 17:29:38.345 Connected! 2018-03-06 17:29:38.348 Read data from server... 2018-03-06 17:29:40.298 Read data from server success! 2018-03-06 17:32:34.852 Autodetect started! 2018-03-06 17:32:35.448 Found COM port: COM354 2018-03-06 17:32:35.453 Open port COM354 (Android Adapter PCUI (COM354))... 2018-03-06 17:32:35.568 Start read phone info! 2018-03-06 17:32:36.582 Connecting to server... 2018-03-06 17:32:39.030 Connected! 2018-03-06 17:32:39.032 Read data from server... 2018-03-06 17:32:40.604 Read data from server success! 2018-03-06 17:32:51.291 CP State: ready 2018-03-06 17:32:51.299 Read phone basic info... 2018-03-06 17:32:52.628 Read phone secure info... 2018-03-06 17:33:01.333 Detect phone done! Model: VNS-L11 MEID: 00000000000000 pESN: 00000000 IMEI: 863047035212510 IMEI 0: 863047035212510 IMEISV: 23 Firmware ver.: VNS-C900B123 SN: 4TE7N16A20012253 Custom SN: 7N3RUP16AC045411 WiFi MAC: 8C:0D:76:7E:95:76 BlueTooth MAC: 8C:0D:76:7E:99:73 Vendor: vodafone Country: za FASTBOOTallas-Trunk_FASTBOOT BOOTallas-Trunk_BOOT RECOVERYunknow) SYSTEM:VNS-L31C900B123_SYSTEM MAINVER:VNS-C900B123 DATAVER:VNS-C900B123_DATA_vodafone_default APTIME:Sun Sep 18 11:50:00 CST 2016 CUSTTIME:Mon Sep 19 11:21:35 CST 2016 RAM: 3G eMMC: 16G IMEI 1 Sim Lock status: NET: unlocked NETSUB: unlocked SP: unlocked Fixed IMEI 1 CRC: 863047045646541 2018-03-06 17:33:10.271 Autodetect started! 2018-03-06 17:33:10.872 Found COM port: COM354 2018-03-06 17:33:12.999 Repairing start New IMEI 1 : 863047045646541 2018-03-06 17:33:13.005 Connecting to server... 2018-03-06 17:33:14.210 Connected! 2018-03-06 17:33:14.213 Read data from server... 2018-03-06 17:33:15.845 Read data from server success! 2018-03-06 17:33:15.853 Open COM port COM354 (Android Adapter PCUI (COM354))... 2018-03-06 17:33:19.838 CP State: ready 2018-03-06 17:33:19.845 Read phone basic info... 2018-03-06 17:33:21.193 Read phone secure info... 2018-03-06 17:33:29.846 Read from server... 2018-03-06 17:33:30.321 Read from server success! 2018-03-06 17:33:30.661 Repair IMEI 1 start! 2018-03-06 17:33:30.669 Phone secure identify start 2018-03-06 17:33:34.714 Phone secure identify success! 2018-03-06 17:33:34.722 Reading from server... 2018-03-06 17:33:35.985 Read from server success! 2018-03-06 17:33:36.899 Repair IMEI 1 Success! 2018-03-06 17:33:36.907 Synchronize NV... 2018-03-06 17:33:37.322 Synchronize NV success! 2018-03-06 17:33:37.326 Factory reset... 2018-03-06 17:33:39.839 Factory reset success! 2018-03-06 17:33:39.859 Finished! |
04-01-2018, 17:28 | #14505 (permalink) |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | alcatel 1010x unlock done Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port (COM120)) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W11.32.SP.V12.F4 Hw Version: JRDHZ50M_11B_HW Reading phone info; IMEI: 860056-02-178528-3 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:08 Log file saved to: LOG_1_04_2018_21_26_25.txt |
