03-27-2010, 17:17 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Gaming Zone Age: 43
Member: 202298 Status: Offline Thanks Meter: 35 | G1157 dead after unlock today one set dead after unlock. process complete when i try to switch ON . but phone was dead. after all , i was so confuse.. i take some action like. 1) press reset switch near sim jeck but not solve. 2) press reset switch and try to restore but not connected to soft. 3) remove battery and connect again press switch ON but not solve 4) again remove battery and conntect again then try to restore "original restore file readed from phone when unlock process runing" but not solve "in restore mode phone not connecting to soft " 5) remove battery then connect to power supply and press ON OFF switch phone take ampair 2, 3 and take 2 and 3, 2 and 3. supply show about ampair condition phone take ampair but not switch ON. at this time phone is dead after unlock process complete. over all phone not connected to soft for restore.. plz plz give authentic sulation for my phone. BR. farrukh ps. Cable is 100% working , i unlock more then 10 phone after this happen |
03-27-2010, 18:18 | #3 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Well hack3r2k it's trying to give with the solution but it's not as easy as you think. did you try to use this exe http://forum.gsmhosting.com/vbb/5623487-post11.html And with the correct partial? http://forum.gsmhosting.com/vbb/5625487-post15.html |
03-28-2010, 06:12 | #4 (permalink) | |
Member: 202298 Status: Offline Thanks Meter: 35 | Quote:
hare is .. HUAWEI_REL_P1.2PU04V01.04_35633xxxxxxxxxx_19.00.07_27.03.2010_PARTIAL plz plz make solution as soon as possible. BR. farrukh | |
03-28-2010, 08:59 | #6 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Br | |
03-28-2010, 13:00 | #7 (permalink) | |
if you need backup for reference " for programming for solution". i can upload here . if it is possible for making solution then no problem i will wait even you make solution for this partial "REL_P1.2PU04V01.04". So it is not hard ware problem like missing TX RX or other. it's only partial problem. so i will wait for correct partial for repairing this phone. thank you for your reply.. BR. Farrukh | |
03-28-2010, 13:35 | #8 (permalink) |
Freak Poster Join Date: Oct 2004 Location: 03453007200
Member: 86994 Status: Offline Sonork: 100.1584487 Thanks Meter: 124 | sometime it looks very strange that i unlocked(using 4059) more than 1000 sets(have partial of each) without ne problem no set is dead not b able to understad the situation nothing wrong with exe every thing is fine i mean excellent |
03-29-2010, 07:55 | #11 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
Bro Mine is DONE with out problem the same SW version LOGS: ------ Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 35xxxxxxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_35xxxxxxxxxxxxx_21.46.00 _28.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:55 BR | |
G1157 Dead by unlocking SOLUTION! | Nadjombe | FuriousGold | 1 | 07-05-2010 08:01 |
Huawei g1157 dead after unlock help please!!!! | toptech | FuriousGold | 9 | 04-25-2010 08:20 |
Nokia 2720 dead after unlock | unlocklleida | Cyclonebox | 3 | 03-31-2010 17:25 |
help urgently G1157 dead after unlock.. | razisamb | FuriousGold | 4 | 03-29-2010 15:38 |
g1157 dead after unlock hlp me plz | naveedbutt | FuriousGold | 3 | 03-17-2010 14:50 |
