11-28-2009, 11:51 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: in your Hart
Member: 882699 Status: Offline Thanks Meter: 8 | Problem unlocking S5230 not unlocking...... ????? . . Connect powered off phone to cable! Reading data... Reading data... Waiting for 30 seconds for the phone to power on... Operation failed! |
11-28-2009, 13:20 | #2 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | when it say "wait 30 seconds...." connect the phone to USb cable connect powered on phone to cable and check if the phone is detected on device manager as "Samsung Mobile USB Modem" * install the driver manualy. * select the driver from S5230 driver folder * the device mane should be different "Samsung USB Mobile Modem" * if the phone is correctly detected, you can unlock it |
11-28-2009, 15:17 | #4 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Quote:
first fully turn on and install drivers from NSPRO Drivers and S5230 folder.. Now proceed as Soft says...No need USB connection at 30sec Its only a Alternate if Rj45 not works...but mostly it work like 99% | |
11-30-2009, 13:23 | #5 (permalink) |
Member: 882699 Status: Offline Thanks Meter: 8 | thanks for reply amir-skillz but the problem is still there can you tell me how to install drivers , becoz when i conenct the phone with rj45 cable it dosent ask any driver and the same with usb ??? |
11-30-2009, 13:34 | #7 (permalink) |
Member: 882699 Status: Offline Thanks Meter: 8 | Disappointed by NSPRO Z3X box did it in 44 sec thanks unlock done NSPRO is faild to unlock even i pay for activation and its still so complicated...... Disappointed |
11-30-2009, 13:38 | #8 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | Quote:
really nspro cannot fixed this problem | |
12-01-2009, 06:06 | #10 (permalink) |
Member: 91045 Status: Offline Thanks Meter: 8,696 | all crap here...user if dont do it right their is no point of blaming on nspro .... installing driver is very simple... execute unlock operation now when asked to connect powered off phone to nspro do so... drivers will be asked so proceed to install as i said above..now phone will be powered on and pc studio connection will be made (if bt is on u need to disable it in order to enable usb connection)..again driver will be asked after installing u r done...if operation fail comes dont panic...repeat procedure of unlocking as now drivers are installed no error will come and process will be done fast.... hundreds of people posted successfully done s5230 its simple like that plz do not blame the product if u doing wrong from your side |
12-01-2009, 13:51 | #11 (permalink) |
Member: 882699 Status: Offline Thanks Meter: 8 | Dear Amir-Skilz i m not stupid. i dont have time to mess around ,,, its a serious problem all the drivers installed and working fine but unlocking faild after it says ( Waiting for 30 seconds for the phone to power on... ) if you cant help then dont answer but dont say crap and bul****s .. Thank you very much |
12-01-2009, 13:52 | #12 (permalink) |
Member: 882699 Status: Offline Thanks Meter: 8 | thNK YOU VERY MUCH FOR YOUR HELP Dear Amir-Skilz i m not stupid. i dont have time to mess around ,,, its a serious problem all the drivers installed and working fine but unlocking faild after it says ( Waiting for 30 seconds for the phone to power on... ) if you cant help then dont answer but dont say crap and bul****s .. Thank you very much |
12-01-2009, 14:08 | #13 (permalink) |
Junior Member Join Date: Mar 2008
Member: 715966 Status: Offline Thanks Meter: 16 | SEE THIS dear http://forum.gsmhosting.com/vbb/show...18#post5025418 |
unlock s5230 problem | guillaum | UST Pro II | 0 | 01-27-2010 08:54 |
unlocking problem with s5230 urgnet | pachicoo | UST Pro II | 0 | 01-14-2010 18:37 |
Problem with Multi Downloader unlocking S5230 | duke2k7 | 2G Latest Models | 2 | 12-15-2009 00:27 |
s5230 problem unlock | KARIM GSM-ZONE | Z3X-Team Products | 16 | 12-12-2009 01:32 |
Problem to unlock s5230 | blueteamgsm | UST Pro II | 4 | 08-20-2009 12:18 |
