12-24-2009, 08:31 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | U installed Drivers Properly Proceed should went fine.. if not Remove phone power it on and make a Full RESET to phone then again Repeat Procedure.. post results |
The Following User Says Thank You to Amir-SkillZ For This Useful Post: |
12-24-2009, 17:56 | #3 (permalink) |
Banned Join Date: Nov 2009 Location: Lima, Perú
Member: 1159099 Status: Offline Thanks Meter: 6,371 | 1)install correct driver. 2)press*♯726872♯,after press *♯7465625♯. 3)Press Get Info... Check Image. |
The Following 2 Users Say Thank You to xcachorrox For This Useful Post: |
02-18-2010, 15:10 | #8 (permalink) |
Insane Poster Join Date: Jan 2010 Location: center of the earth <hell>
Member: 1219358 Status: Offline Sonork: misu Thanks Meter: 27 | for a s5600v it goes like .....after i insert the code in the phone ( *#782827# ) the program crash after i press OK :| i have no solution so farr........ :S http://img697.imageshack.us/img697/9660/26709393.jpg |
02-20-2010, 11:29 | #10 (permalink) |
Insane Poster Join Date: Apr 2007
Member: 496853 Status: Offline Thanks Meter: 2 | s 5600 Hi,i appologise because I did not post the results earlier.All the problems was from drivers.I did uninstall/install carefully all drivers and work for me without any problems.B.R. |
04-06-2010, 10:35 | #11 (permalink) |
Member: 1219358 Status: Offline Sonork: misu Thanks Meter: 27 | for a s5600v it goes like .....after i insert the code in the phone ( *#782827# ) the program crash after i press OK :| i have no solution so farr........ :S |
04-06-2010, 14:09 | #12 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: Scotland, UK. Age: 43
Member: 83741 Status: Offline Sonork: 100.1624702 Thanks Meter: 88 | Quote:
WBR | |
Motorola A1000 can not unlock ...Phone not detected | kosta25 | Motorola P2k | 0 | 10-29-2009 08:08 |
6300 can not unlock, downgraded, full flashed, not helped! It's Lock!! | Wais777 | BB5BOX | 3 | 04-25-2008 21:15 |
there is no hope from mr Julvir, I can not Unlock X1-X5, anybody can help me!? | KUBAT1 | SwS_SaG_BoX | 6 | 05-16-2006 11:17 |
tornado 1.2n can not unlock 7600 but griffin can | saiful2001 | UFS2 + UFS3-Tornadoflasher | 2 | 04-11-2004 06:07 |
