Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Remote Universalbox Team
Old 12-02-2004, 11:44   #1 (permalink)
Member: 12896
Thanks Meter: 9
USB high speed flashing
Please help me, comunication very slowly.
I try win98se, win xpsp1, and this modified china usb cable:
http://www.davinciteam.com/index.php...anual-cablemod
How get the real 921600kbps flashing speed?
MB
Old 12-04-2004, 00:49   #2 (permalink)
universalbox's Avatar
Member: 68982
Thanks Meter: 17,853
MB
We prefer USB<->serial cable with FTDI chip. We have no experience cables with PL-2303xx. You can use the original DSS cradle as well.
Old 12-09-2004, 02:28   #3 (permalink)
Member: 12896
Thanks Meter: 9
I buying DSS-25 syncstation, and not working whit remote unlocker!
I use original Sony-Ericsson "USB Drivers for Sync Station DSS", and
software not recognize phone after pressed the power switch,
and phone powered on.
What my problem? Need modify the DSS-25 for flashing?
MB
Old 12-09-2004, 02:41   #4 (permalink)
arash111
Guest
Posts: n/a
Member:
Have you selected right COM-port? Look at device manager if there is any '?' symbol about drivers e.tc for your syncstation . if so try to update drivers from c:/windows/ local registry root.
Old 12-13-2004, 12:27   #5 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
Not working for me too... DSS20 can't detect phone, fighter usb cable ( FTDI ) very slow, approx. 2 hrs for .sw, .lfs and .cus...
br
vule
Old 12-13-2004, 13:08   #6 (permalink)
Invader's Avatar
Member: 1580
Thanks Meter: 2
Prolific USB cheap china cable works perfect on maximum speed for me.
Old 12-14-2004, 11:13   #7 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
Can u pls write here flashing times???
I have tried everything... It is not up to server 'cause files are stored locally...
On PIII 733 takes ages to flash, on PIV2.4 takes 2 hours no matter what connection i use ( 56K modem, ISDN single and dual, astrasat )...
Still i did not manage DSS to run with it, FTDI fighter runs as in above post, PL2303xx limited by drivers on 115200 ( i have old one )...
Vule
Old 12-16-2004, 17:37   #8 (permalink)
Member: 68982
Can you please try to use more recent version of your USB<->serial driver?
Also you can try that Prolific cable mentioned by Invader. Theoritically many of the USB<->serial cables should work. Some of our customers uses FTDI's USB<->serial with success. We are using a simple cheap serial cable with HiSerial.sys usually on 46800baud so we don't have too much experience with USB<->serial cables. I will remove DSS cradle from the site if it really not work.
Old 12-16-2004, 20:32   #9 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
My FTDI works perfect with fighter and i really can't figure what's wrong. DSS-20 definitely does not work with Your remote unlocker and original SE drivers.
Anyway, i will try tommorow to run it on clean XP pro installation just to make sure that messy thing from microsoft called OS does not making any problems.
br
vule
High speed flash file download link imran777750 Nokia Base Band 5 ( BB-5 ) 4 12-10-2009 22:42
Free!!! High Speed Flash Files Download Link Sandeep9669 GSM Mobile Links 0 01-30-2009 00:22
High Speed Multi Ports USB Expansion Splitter ponyflasher Sell ur Old and Used Stuff 0 03-20-2008 22:14
TST and high speed flashing again Potvora TST Dongle 1 10-06-2005 19:07
Siemens high speed flashing pci card? gsmsalers Siemens-Benq RingTones and WallPapers 9 02-18-2004 09:02
Page generated in 0.26749 seconds with 9 queries
