03-08-2009, 23:33 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: BANGLADESH
Member: 684506 Status: Offline Thanks Meter: 46 | A 38 (Benq-Siemens) Restart Solved Thanks to this wonderful team of their excellent support COM4 [VCP0] selected module v1.31 Device: BenQ A38 Checking data, wait... Action: flash write "smart write" active Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E221D2200 flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0001:227E221D2200 flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb Write: Language Pack flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb Writing Done Finished, time used: 192 sec Remove/Install battery now ! |
The Following User Says Thank You to s@zol For This Useful Post: |
03-09-2009, 10:48 | #2 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
The Following 2 Users Say Thank You to InfinityN For This Useful Post: |
China BENQ C30 restart and hang problem | masudmobile | Chinese Models & Cloned Phones | 6 | 08-14-2010 10:27 |
w800i restart solve 100% | GSMTURBO | Sony Ericsson Hardware Repair | 3 | 11-22-2008 16:09 |
Benq M315 Restart After Flashing | alamgarh | Infinity-Box | 2 | 02-23-2008 14:00 |
A 38 Benq Siemens ?/ | alunecosu_hd | Infinity-Box | 16 | 09-09-2007 08:56 |
Benq S660C Restarts... | LoveLess | VygisToolbox | 1 | 06-20-2006 19:17 |
