Old 09-27-2008, 09:46   #1 (permalink)
Member: 73455
Thanks Meter: 23
Arrow 5310 NMM-3 deadset how to flash?
good day sir i got here 5310 NMM-3 express music i recieve this dead set....i downloaded flash file from the support and try to flash the phone but have errors on it...
action taken:
1. detect pinout on pinfinder
2. open chinese miracle then set flashfile and write....
here's the logs:::
COM23 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:4603:0004
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
error: no any expected answer
error: no any expected answer: wrong answer after chip id request
error: no any expected answer: wrong answer after chip cfi request
number of flash chip/regions detected: 00/01
Unknown or damaged flash chip, operation aborted.
Fault reasons:
1. damaged flash chip: replace or resolder/reball flash chip
2. damaged hardware: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 48 sec
Remove/Install battery now !
i would like to ask if after findng pinouts on pinfinder, do i have to disconect the phone's cables from pinfinder? or after finding pinout can i derectly flash the phone? pls give me an idea for this...i got this boxes yesterday and a new user for this box....
Old 09-27-2008, 10:29   #2 (permalink)
kungpaoski's Avatar
Member: 329609
Thanks Meter: 245
Bro do not disconnect cables from phone after you have detected pinouts. First try read flash to determine what fw ver. of you're unit. Based on you're flashing logs phone has hardware problems. Possible flash chip. Try to do this first mildly reheat mtk chip (cpu) and try read phone flash again or flash unit. If still same errors appear. Reheat flash chip. Check first if it is glued because some flash chips are glued. And repeat operation again. If still same errors sad to say flash chip is damaged.
b.r.
The Following User Says Thank You to kungpaoski For This Useful Post:
Old 09-27-2008, 10:41   #3 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 434
@ topnoyze
it's a HW matter,
try to reheat CPU.
software always says FLASH CHIP, but for me I always go with CPU.
The Following User Says Thank You to 3stanGsm For This Useful Post:
Old 09-27-2008, 12:41   #4 (permalink)
Member: 73455
Thanks Meter: 23
b.r.
thanks for the reply bro....i tried reheating flash i.c. and back to process again the phone went on flashing......and finished...but when i tried to power on the phone just nokia logo appear and it hangs up.....so i tried detecting it again it i still got error like the one i showed the above logs....i'll try to mild reheat cpu and post result like 3stanGsm suggestion....and i'll post result again....
The Following 2 Users Say Thank You to topnoyze For This Useful Post:
Old 09-27-2008, 23:13   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
both CPU & Flash IC can be reason for such behavior.
try to heat them both
how to flash e250i adda2004 Samsung Flashers, Software, Firmware. 0 03-29-2010 12:26
Help !! ....5310 Code Counter Blocked !! how to reset 3/3 counter N/East Unlocker Cyclonebox 2 10-07-2009 08:54
problem whit nokia 5310 nmm-3 alssalafiy Infinity-Box 6 05-07-2009 20:51
805SC 3.1 How to flash saajith SPT BOX 3 03-02-2009 01:57
need pinout 5310 NMM-3 99026 Infinity-Box 1 11-30-2008 12:41
Page generated in 0.17328 seconds with 9 queries
