Old 11-24-2009, 04:32   #1 (permalink)
Member: 761984
pinfinder-problem Rx,Tx Finding
help me
i bought new pinfinder
that was not decet Rx,Tx
i do all like u shown in pdf
short diod, cut wire in cable
and after also like same problem like below picture
Old 11-24-2009, 19:40   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
regarding this case i can say that very small number of phones keep tx/rx in system connector.
usually they are presented as test points on PCB.
what phone model do we talk about?
are you sure that it is MT62xx CPU based?
you can check this by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- then OK, this is MT62xx
Do you able to power On phone using pinfinder power?
(battery removed and phone sourced from pinfinder)
Old 11-25-2009, 05:39   #3 (permalink)
Member: 761984
thank u for u r replay
u r wright but other pinfinder box find tx rx with the same mobile which i am trying
Old 11-25-2009, 09:11   #4 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
which model you are finding rx tx ?????
Old 11-25-2009, 16:19   #5 (permalink)
Member: 761984
s90i,H1,T99,Vodafone 225,898 like these i tryed
Old 11-25-2009, 20:42   #6 (permalink)
Member: 148515
hello!
looks like quality problem.
if one pinfinder finds pinout, but other- no >this is not normal.
in few days i am recieving one faulty pinfinder from spain.
i will check why it is not working and probably will advice how to fix this.
(if this is common fault)
another option is to exchange it under warranty conditions at your reseller
Old 11-26-2009, 04:05   #7 (permalink)
Member: 761984
thank u for infinity team
but how much day's it will take to exchange with my reseller
he is in baroda name was Krinovate communications
Old 11-26-2009, 16:16   #8 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
hello!
hello
i also have this problem in my NKTEL A200 i have a NKTEL A200 invalid sim when i go to find for rx tx on pin finder but my phone not finding rx tx........
i also try with rx tx cable on board but not detect my phone chinese miracle software........
Old 11-26-2009, 19:12   #9 (permalink)
Member: 148515
Originally Posted by rameez_gsm View Post
hello
hello!
you must correctly connect infinity box to test points.
remove pinfinder, insert cable to RJ45 port.
box pin 2 & 3 solder to tx/rx
box pin 8 (ground) solder to some phone grounded part.
attach battey, try to connect.
if it is not connecting- swap Tx/Rx with places
repeat agian
in one of two ways it will work.
pinfinder do not find pinout in this phone because tx/rx are not presented in system connector
Old 11-26-2009, 19:12   #10 (permalink)
Member: 148515
Hello!
what is written on warranty label?
Old 05-14-2011, 11:58   #11 (permalink)
Member: 824510
Sonork: 41000
Thanks Meter: 2
A200 invalid sim can you healp me any one
Old 05-14-2011, 21:06   #12 (permalink)
Member: 148515
hello!
make full backup and try format FFS complete and restore IMEI to original value
Old 05-15-2011, 04:25   #13 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,313
Bro. try to repair imei.
Old 05-19-2011, 13:26   #14 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
hello!
very good trick to find if phone cpu is mtk
Old 05-21-2011, 11:40   #15 (permalink)
Member: 148515
hello guys!
this information is outdated. Nowadays spreadtrum phones also give same response to *#0044# code. Better to use following codes: *#8375# or *#3646633#. if you will get positive response on them- then it will be big chance to be MT62xx family
why cant infinity pinfinder detect rx,tx for this mtk phone GOODNESS Infinity-Box 2 08-14-2010 14:09
Rx,tx find failure solution weru CPF-BOX Ⅱ 2 12-05-2009 08:32
sucessfully find cdma rx tx with pinfinder madho Infinity-Box 0 10-03-2008 04:48
Pinfinder - problem with Rx/Tx detection realdodo Infinity-Box 15 06-30-2008 16:31
can infinity pinfinder rx/tx find any mobile?? kabirhossain Infinity-Box 8 03-23-2008 14:19
Page generated in 0.23654 seconds with 10 queries
