11-24-2009, 04:32 | #1 (permalink) |
Junior Member Join Date: Apr 2008
Member: 761984 Status: Offline Thanks Meter: 0 | pinfinder-problem Rx,Tx Finding i bought new pinfinder that was not decet Rx,Tx i do all like u shown in pdf short diod, cut wire in cable and after also like same problem like below picture |
11-24-2009, 19:40 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! regarding this case i can say that very small number of phones keep tx/rx in system connector. usually they are presented as test points on PCB. what phone model do we talk about? are you sure that it is MT62xx CPU based? you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- then OK, this is MT62xx Do you able to power On phone using pinfinder power? (battery removed and phone sourced from pinfinder) |
11-25-2009, 20:42 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! looks like quality problem. if one pinfinder finds pinout, but other- no >this is not normal. in few days i am recieving one faulty pinfinder from spain. i will check why it is not working and probably will advice how to fix this. (if this is common fault) another option is to exchange it under warranty conditions at your reseller |
11-26-2009, 16:16 | #8 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Quote:
i also have this problem in my NKTEL A200 i have a NKTEL A200 invalid sim when i go to find for rx tx on pin finder but my phone not finding rx tx........ i also try with rx tx cable on board but not detect my phone chinese miracle software........ | |
11-26-2009, 19:12 | #9 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
you must correctly connect infinity box to test points. remove pinfinder, insert cable to RJ45 port. box pin 2 & 3 solder to tx/rx box pin 8 (ground) solder to some phone grounded part. attach battey, try to connect. if it is not connecting- swap Tx/Rx with places repeat agian in one of two ways it will work. pinfinder do not find pinout in this phone because tx/rx are not presented in system connector | |
05-19-2011, 13:26 | #14 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: rainak bazar jalandhar
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | Quote:
05-21-2011, 11:40 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello guys! this information is outdated. Nowadays spreadtrum phones also give same response to *#0044# code. Better to use following codes: *#8375# or *#3646633#. if you will get positive response on them- then it will be big chance to be MT62xx family |
why cant infinity pinfinder detect rx,tx for this mtk phone | GOODNESS | Infinity-Box | 2 | 08-14-2010 14:09 |
Rx,tx find failure solution | weru | CPF-BOX Ⅱ | 2 | 12-05-2009 08:32 |
sucessfully find cdma rx tx with pinfinder | madho | Infinity-Box | 0 | 10-03-2008 04:48 |
Pinfinder - problem with Rx/Tx detection | realdodo | Infinity-Box | 15 | 06-30-2008 16:31 |
can infinity pinfinder rx/tx find any mobile?? | kabirhossain | Infinity-Box | 8 | 03-23-2008 14:19 |
