12-20-2008, 08:05 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Alcatel E221 Successfully Unlock Alcatel E221 Successfully Unlock...............thanks infinity team COM13 [VCP0] selected module v1.30 Device: Alcatel-E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E221_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20081220-114409.80E.bin Read data done Check data ... Check data done Write ... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 76 sec Remove/Install battery now ! |
The Following User Says Thank You to zeerik For This Useful Post: |
12-20-2008, 08:58 | #2 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
12-24-2008, 19:36 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
12-27-2008, 12:05 | #6 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Another E221 Alcatel Unlocked like sharm Hear Log COM8 [VCP2] selected module v1.30 Device: Alcatel-E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E221_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20081227-120321.80E.bin Read data done Check data ... Check data done Write ... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 80 sec Remove/Install battery now ! Regards Infinity Team |
The Following User Says Thank You to Formingus For This Useful Post: |
01-04-2009, 03:01 | #9 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 94806 Status: Offline Thanks Meter: 19 | e221 unlock succesfully Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E221_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20090104-095849.80E.bin Read data done Check data ... Check data done Write ... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 79 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to _iskor_ For This Useful Post: |
01-04-2009, 13:17 | #10 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
Alcatel E221 Sucessfuly Unlock By Infinity | Shakeel Communication | Infinity-Box | 2 | 03-19-2024 10:33 |
alcatel e221,e227 unlock succesffuly with infinity-box | KARIM GSM-ZONE | Infinity-Box | 21 | 04-02-2012 20:42 |
alcatel s521a successfully unlocked ::: USER REPORT THX ::: | luinaranjo | PolarBox 3 | 0 | 02-23-2009 22:43 |
Alcatel s920 successfully unlocked with polar box | dasuza | PolarBox 3 | 3 | 10-28-2008 21:16 |
Alcatel e221 100% unlocked | godwin | Infinity-Box | 0 | 04-15-2008 11:13 |
