02-16-2009, 12:06 | #16 (permalink) |
No Life Poster Join Date: Aug 2005 Location: 5AAB Age: 37
Member: 167191 Status: Offline Thanks Meter: 363 | are these files only customization????? may be that menu have no further sub menu bcoz these files as u wrote are customize.. this is my guess... correct me if i m wrong... may i try again with other files. may be this type of behaviour of handset is by default.... gurinder |
02-16-2009, 19:50 | #17 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | great support from infinity team !!! I will test and post result, but I think menu and other problem need to be solved ... again Thanks for ur supper support ... |
02-17-2009, 06:27 | #18 (permalink) |
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | @Infinity set unlocked but menu and language problem is still not solved pls modify the file and post asap ------------ Alam |
02-19-2009, 20:43 | #22 (permalink) |
No Life Poster Join Date: May 2006
Member: 273834 Status: Offline Thanks Meter: 68 | SAME PROBLEM, I HAVE TRIED ALL THE CUSTOMIZING FILES TOO. PLS HELP ==== log: [2/19/2009 1:54:48 PM] ==== COM7 [VCP7] selected module v2.58 Device: Alcatel-S319X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:37C0:A00C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090219-135516.B0X.bin Area: Firmware flash: 98004900000002:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16VU10 done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090219-141543.B0X.bin Finished, time used: 1252 sec Remove/Install battery now ! |
02-26-2009, 01:38 | #25 (permalink) |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | well finally for my luck my client want his phone in movistar the s319a was from tigo guatemala and since in support you dont have the sim free file i decide to flash with movistar so now phone is locked to movistar and client is satisfy thanks for your help i hope soon you can give us sim free flash file for s319a here is log of operation soft work like a charm dont need to format fss COM20 [VCP0] selected module v2.66 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:360D:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090225-150206.B0X.bin Area: Firmware flash: 98004900000002:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16NO30 done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................counter: 01 security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090225-151106.B0X.bin Finished, time used: 581 sec Remove/Install battery now ! |
03-07-2009, 05:14 | #28 (permalink) |
No Life Poster Join Date: Apr 2006
Member: 268887 Status: Offline Thanks Meter: 91 | You can download those files from flashfiles / Alcatel / S319 / Parts folder. InfinitySupport, what about menu problem. Please resolve this ASAP as customer is getting impetient now. Thanks for understanding. |
03-08-2009, 22:12 | #29 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Our programmers is working about this, hope on good results soon/ |
03-25-2009, 11:50 | #30 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 47
Member: 88402 Status: Offline Thanks Meter: 489 | i hav alcatel s319x for unlock after sim free flash all ok but no display,then i flash with orange now display ok but locked, then do customation file and cheak at format ffs now mobile unlocked, language in english, but inside menu select (that "ok") button not work,but mobile unlocked log: COM5 [VCP0] selected module v2.58 Device: Alcatel-S319X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active skip: Firmware write: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:053C:A00C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090325-161547.B0X.bin Area: Customization/Language Pack flash: 98004900000002:2AEA0000000000 Write: Customization/Language Pack detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16VU10 done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090325-162218.B0X.bin Finished, time used: 419 sec Remove/Install battery now ! |
Pls help with alcatel s319x unlock | TALIAT | Infinity-Box | 3 | 08-02-2009 14:12 |
Alcatel S319X unlock done but no service | kemot | Infinity-Box | 4 | 06-20-2009 07:37 |
Alcatel s319x unlock ok but help | Lutfur | Infinity-Box | 0 | 04-22-2009 09:29 |
alcatel s319x unlock problem | zeeshan tayyab | Infinity-Box | 4 | 03-26-2009 07:46 |
Alcatel S319x unlocked in one pass | jepetu | Infinity-Box | 2 | 03-23-2009 12:59 |
