07-21-2009, 16:35 | #1 (permalink) |
No Life Poster Join Date: May 2006
Member: 273834 Status: Offline Thanks Meter: 68 | Pls help with alcatel s319x unlock Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.67 S/N: 1C71:0112 Wait... Device: Alcatel-S319X, S319A Done Loading file v.04... S319X-2BVGGB1_XH16VU10_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-06-20_En_De_Ru_Bg_Ua_simfree.B0M.bin loaded identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ==== log: [7/21/2009 3:43:22 PM] ==== COM7 [VCP0] selected module v2.67 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection disabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:0FAC:A00C status: 01 high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished Area: Firmware flash: 98000300000001:FFFFFF00000000 Write: Firmware error: error# 0000FFFF error: flash write error: 00000000:00002000 detect device identification#2... detection phase #1... . detect device identification#2 finished Write Fail Finished, time used: 164 sec Remove/Install battery now ! PHONE IS DEAD PLS HELP |
07-31-2009, 16:18 | #3 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: WORKS WITH THE BEST
Member: 821156 Status: Offline Thanks Meter: 42 | Quote:
OM7 [VCP0] selected module v2.82 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware S319X-2BVGGB1_XH16JB10_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-05-08_En_Fr_Es_It_De_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:28C4:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) check... security area (code #1) fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20090731-160910.B0X.bin Area: Firmware flash: 98000300000001:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16JB10 done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 98000300000001:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20090731-161307.B0X.bin Finished, time used: 272 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! | |
alcatel s319x unlock problem | gurinder | Infinity-Box | 43 | 11-16-2009 22:51 |
Alcatel s319x unlock ok but help | Lutfur | Infinity-Box | 0 | 04-22-2009 09:29 |
alcatel s319x unlock problem | zeeshan tayyab | Infinity-Box | 4 | 03-26-2009 07:46 |
Alcatel S319x unlocked in one pass | jepetu | Infinity-Box | 2 | 03-23-2009 12:59 |
pls help with alcatel 501 buttons are not working | darkeye | Alcatel TCL Hardware Repair | 1 | 11-11-2002 02:36 |
