Old 11-20-2008, 14:05   #1 (permalink)
az cells's Avatar
Member: 115516
Thanks Meter: 113
Bluetooth C003
hi
need flash file
Bluetooth C003 when insert sim restart . after format set is dead
plz help
COM6 selected
module v2.64
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:8FA2:8DEC
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5AC625A3.[E553_Y7ARTF3_E553_GPRS_MT6226_S01.V22_01_1.BIN_893 E952D].rpl
New firmware detected (2.64) :
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 5AC625A3
identification#1 protocol ver: 04
ver. sw1: E553_Y7ARTF3_E553_GPRS_MT6226_S01.V22_01_1.BIN
ver. sw2: E553_Y7ARTF3.V22.01.1, D26AC176
ffs offset/size: 00800000/001FF000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00E00000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[E553_Y7ARTF3_E553_GPRS_MT6226_S01.V22_01_1.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\c003\eeprom[E553_Y7ARTF3_E553_GPRS_MT6226_S01.V22_01_1.BIN]_20081119-220515.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_5AC625A3_E553_Y7ARTF3_E553_GPRS_MT6226_S 01.V22_01_1.BIN_893E952D_20081119-220536.B0X.bin
Finished, time used: 265 sec
Remove/Install battery now !
Hear is reded flash
http://rapidshare.com/files/16562679...7.B0M.bin.html
thanks
Old 11-20-2008, 22:38   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
If you have original backup just flash phone with original backup and then try to make format ffs in "safe" mode.
Old 11-21-2008, 13:27   #3 (permalink)
az cells's Avatar
Member: 115516
Thanks Meter: 113
Originally Posted by InfinitySupport View Post
Hello,
still same set not power on
plz help any budy
Old 11-21-2008, 17:39   #4 (permalink)
Member: 130995
Hello,
What file you have used for flashing ?
Is it was ORIGINAL backup (that was made BEFORE format) or not ?
Old 11-22-2008, 16:18   #5 (permalink)
az cells's Avatar
Member: 115516
Thanks Meter: 113
s sir it was ORIGINAL backup reded
Old 11-22-2008, 17:19   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you must find working phone with version "E553_Y7ARTF3_E553_GPRS_MT6226_S01.V22_01_1"
or try similar from support area
Old 01-09-2009, 15:39   #7 (permalink)
az cells's Avatar
Member: 115516
Thanks Meter: 113
it is readed this fle from working handset .I flashed still same problem
http://rapidshare.com/files/181404229/C003.rar.html
Old 01-09-2009, 20:33   #8 (permalink)
Member: 130995
If you see "unknown version" during flash this means you need to wait ChineseMiracle update.
Update will be released in nearest days.
Bluetooth A5 omtanwer1 Chinese Models & Cloned Phones 1 04-03-2010 11:26
Bluetooth nony S208 Flash File Help me .:ISMAIL_BD:. SpiderMan 0 03-29-2010 15:34
Bluetooth Software Which Allows You to Browse Someone Else's Bluetooth Phone gaz_0001 Nokia Multimedia 12 04-13-2008 19:17
Microsoft Bluetooth Stack + Bluetooth Headset = NO WAY???? CEO Bluetooth-Software 2 06-08-2005 20:56
USB bluetooth device-Generic bluetooth Radio aisin Bluetooth-Software 1 04-26-2005 09:55
Page generated in 0.19592 seconds with 9 queries
