Unlock Server
Old 05-05-2007, 17:45   #1 (permalink)
Member: 281925
Sonork: 100.113915
Red face c140 phone is hacked
hi infinity help i have c140 dead i try to flash here is log
COM45 selected
"smart write" active
Action: flash
Write: Firmware
Write: Flex
Write: Language Pack
Skip: Eeprom
Device: C139,C140
Checking data, wait...
Connect...
Press and HOLD Power button...
connection mode: 02
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
921600
Set Baud Done
Check Flash-1...
SW version: 1.3.29
HW version: _E88
LP ver: LPH_C139_ASIA2_Z1C
Flex ver: FFH_C139_6H_Z1C
imei otp: xxxxxxxxxx
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_351549011324119_20070505-214104.31E.bin
imei eeprom: 351549011324119
Check Flash-2 Done
Write...
Writing: Firmware
file/phone "Firmware" version the same: 1.3.29
continue: Firmware
Writing: Flex
Writing: Language Pack
Write Done
Finished, time used: 75 sec
Remove/Install battery now !
then flash phone is on but show phone is hacked
what can i do please help me
i write eeprom download to infinity but i got massage flash chip detaction problem what i can do? help me
i am flash another flash file then phone show sim not valid see 2nd pic
Old 05-05-2007, 21:08   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Hi,
make "sp-unlock" operation
Old 05-06-2007, 02:15   #3 (permalink)
sunil kumar's Avatar
Member: 75838
flash with original c140 unlock flash file
Old 05-08-2007, 09:02   #4 (permalink)
Member: 281925
Sonork: 100.113915
c 140 phone not detact meen inital conaction problem
Originally Posted by InfinitySupport View Post
Hi,
i am doing sp unlock but my phone not detact by infinity box or com cable
after flash another flash file (C139_8.8.17_Flex_FFN_C139_TP_T0H.31F)
i am also use this trick but my phone not detact not on green led in the box when i am boot phone
the trick is attach in post
Old 05-08-2007, 09:26   #5 (permalink)
Member: 130995
@shripalkawdia
if you flashed phone with version 8.8.17 you must open phone, cut track and flash it back to v1.x.x
Old 05-08-2007, 10:08   #6 (permalink)
Member: 281925
Sonork: 100.113915
yes i do but pro same
@shripalkawdia
yse sir i am do this method cut track but my phone not detact not boot help me
Old 05-08-2007, 10:44   #7 (permalink)
Member: 130995
After you cut track you must use "repair mode" connection in "Settings" page.
Old 05-08-2007, 15:51   #8 (permalink)
Member: 281925
Sonork: 100.113915
same problem
hi infinity my problem same not detact my phone by box or com cable
it is only made after i am flash this phone another flash file
i cut track & connact phone in repair mode but it not detact
but when i doing usercode/phonelock opration or reset sp-lockstatus box conact my phone work do
so when i am doing to spunlock or flash this versionC139_1.3.29_Flex_FFH_67_Z1C.31F
to ok my phone? please help me i am in a problem 2 dayes
Old 05-08-2007, 16:00   #9 (permalink)
Member: 130995
Please, read: F.A.Q., Contacts, Supported models, Cables/pinouts
Old 05-08-2007, 17:15   #10 (permalink)
Member: 281925
Sonork: 100.113915
help whith detail
i did not understand this link
please post u r reply in this topic
Old 05-08-2007, 18:18   #11 (permalink)
Member: 130995
how about this link: How to unlock Mot C123 released in Pakistan
Old 05-08-2007, 18:22   #12 (permalink)
Member: 281925
Sonork: 100.113915
no
no this is not a my problem
please read my post starting to end careful
Old 05-08-2007, 18:29   #13 (permalink)
samgsm's Avatar
Member: 478781
brother check the cable if cable is ok ffs first then flash it i think u r prob will solve
Old 05-08-2007, 18:40   #14 (permalink)
Member: 148515
helllo!
after you cut track phone should not power ON.
Is this heppend in your case?
Old 05-08-2007, 18:42   #15 (permalink)
Member: 281925
Sonork: 100.113915
cable is ok
brother cable is ok i unlock other phone daily
but this phone after flash this file C139_8.8.17_Flex_FFN_C139_TP_T0H.31F
in infinity box not on green rx led
but before flashing phone by this file C139_8.8.17_Flex_FFN_C139_TP_T0H.31F
phone is detact by infinity
j100i phone is hacked djpaul Infinity-Box 32 12-15-2009 17:44
j100 phone is hacked fereemetal Sony Ericsson 4 07-29-2008 19:00
c261 phone is hacked kulvindersingh Infinity-Box 3 03-14-2007 19:04
c117 phone is hacked ..:MumbaiGsm:.. Infinity-Box 2 01-30-2007 09:11
C117 Phone is Hacked.. muksforu Infinity-Box 24 01-03-2007 11:11
vBulletin Optimisation provided by vB Optimise (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting. ()
Page generated in 0.59975 seconds with 9 queries
