Old 09-27-2006, 15:56   #1 (permalink)
muksforu's Avatar
Member: 50805
Thanks Meter: 101
C117 Phone is Hacked..
after unlock Mot C117 phone say Phone is Hacked how to solve this...any solution i used Moto01_v116 i m using Inifinity on COM1
UNLOCK
Log opened: [9/27/2006] [7:00:56 PM]
App: C:\Program Files\InfinityBox\Moto01_v116\Moto01.exe
[Infinity Box] v.1.16A
Loading, wait...
S/N: 0A8A:0108
Standard firmware detected
Current device: C113,C115,C116,C117,C118
Ready
COM1 selected
Action: Unlock
Device: C113,C115,C116,C117,C118
Checking data, wait...
Connect...
Press and HOLD Power button...
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW Ver: 2.5.78.N.
HW Ver: MOTOROLA_E88
Check Flash-1 Done
Check Flash-2...
In progress...
File saved: Backup_eeprom-1__2006-9-27_19-1-41.18E.bin
Check Flash-2 Done
Write...
Write Done
Finished
Remove/Install battery now !
Time used: 48 sec
FORMAT
Log opened: [9/27/2006] [7:08:39 PM]
Loading, wait...
S/N: 0A8A:0108
Ready
COM1 selected
Action: Format
Connect...
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW Ver: 2.5.78.N.
Check Flash-1 Done
Check Flash-2...
Check Flash-2 Done
Write...
Write Done
Finished
Time used: 25 sec
i do this two step but not result
here is backup file if its help..
File Type: rar Backup_eeprom-1__2006-9-27_19-1-41.18E.rar (7.0 KB, 279 views)
Old 09-27-2006, 16:43   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
Pls, make this:
1. make full flash backup
2. send full flash backup to [email protected]
3. flash phone with any 1.x.x firmware from support area
Old 09-27-2006, 16:52   #3 (permalink)
..::Mr999::..'s Avatar
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
Cut the Tp and Repair then full flash hope it will work
Wbr
Mr999
Old 09-27-2006, 17:16   #4 (permalink)
muksforu's Avatar
Member: 50805
Thanks Meter: 101
Originally Posted by InfinitySupport View Post
Hi,
Pls, make this:
i try to flash but not with 1.x.x i try it to flash it with 2.x.x
this error comes i try with 1.x.x. and post result again
COM1 selected
Action: Flash
Write: Firmware
Write: Flex
Write: Language Pack
Connect...
Err: boot[04]
Connect Fail
Finished
Time used: 9 sec
this is with 2.x.x
Old 09-27-2006, 23:56   #5 (permalink)
MR PROTEC's Avatar
Member: 86655
Thanks Meter: 385
COM1 selected
Action: Flash
Write: Firmware
Write: Flex
Connect...
Err: boot[04]
Connect Fail
Finished
Time used: 9 sec
this is with 2.x.x
interesting....
P.S: what about "Latency Timer" is the value set to 4 (check your Documentation folder )
but about your main problem i think you need special flex wait mr InfinitySupport he ''ll do his best for sure
Old 09-28-2006, 02:00   #6 (permalink)
Member: 70573
Thanks Meter: 24
I have same Proplem with C118
after unlock phone is OK, Flash with other Firmware ----> Phone is dead----> try with other firmware ---> Err: boot[04]
Fix by original cable include box of phone( SKN6233A, USB to COM)!!!!!!
---->Full flash with this cable -----> phone is OK.
Good Luck!
Old 09-28-2006, 04:42   #7 (permalink)
mehta's Avatar
Member: 102598
Thanks Meter: 68
1. Open phone and GENTLY cut track according to picture
NOTE !!! Track have to be restored after repair procedure,
so, cut track very gently and be sure that you can restore
track back after repair process.
2. Start "Repair Module" software
3. Load "Repair data" file
4. Press phone "Power" button and wait until process finished (about 1 min)
5. Now phone repaired, but can't power-on
6. Restore track back
7. To make phone completely repaired you need to flash phone (Main+Flex+LP) tested by me 1000% work
Old 09-28-2006, 08:30   #8 (permalink)
Member: 130995
this is with 2.x.x
I think it can be cable problem or empty battery.
And "RepairModule" can helps with any firmware version. After writing firmware 1.x.x phone must be alive even after "phone is hacked" message.
Old 09-29-2006, 07:15   #9 (permalink)
muksforu's Avatar
Member: 50805
Thanks Meter: 101
yes phone is still alive and display "phone hacked msg" and i m using Serial Com cable so not need to set "Latency Timer"
not able to flash phone everytime it shows error
Old 09-29-2006, 09:23   #10 (permalink)
Member: 130995
http://forum.gsmhosting.com/vbb/show...91&postcount=3
http://forum.gsmhosting.com/vbb/show...35&postcount=7
http://forum.gsmhosting.com/vbb/show...11&postcount=8
Old 09-29-2006, 10:17   #11 (permalink)
sudeeshveekey's Avatar
Member: 18837
Sonork: 100.1601544
Thanks Meter: 71
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW ver: 2.5.78.N.
HW ver: MOTOROLA_E88
Check Flash-1 Done
Check Flash-2...
In progress...
file saved: Backup_eeprom-1__2006-9-29_14-24-19.18E.bin
Check Flash-2 Done
Write...
Write Done
Finished
Time used: 18 sec
another c117 after unlocking with infinity "phone hacked"
Old 09-29-2006, 10:50   #12 (permalink)
Member: 130995
Hello,
To avoid double posting and endless discussion here is manual attached.
Old 09-29-2006, 11:31   #13 (permalink)
Member: 18837
Sonork: 100.1601544
Thanks Meter: 71
Loading...
C115_1.0.38_Main.18M.bin Loaded
Loading...
C115_1.0.38_Flex_03_132.18F.bin Loaded
Loading...
C115_1.0.38_LP_T14_132.18P.bin Loaded
Write: Firmware
Write: Flex
Device: C115,C116,C117,C118
Connect...
Connect Done
Boot...
Boot Done
Set Baud...
Set Baud Done
Check Flash-1...
SW Ver: 2.5.78.N.
Check Flash-1 Done
Check Flash-2...
Check Flash-2 Done
Write...
Writing: all flash areas
Write Done
Finished
Time used: 310 sec
its working perfectly now.my phone has been unlocked perfectly with infinity.many thax to infinity team. am ride out from phone hacked of c117
Old 09-29-2006, 17:14   #14 (permalink)
balu_dark's Avatar
Member: 16251
Thanks Meter: 38
man - about this procedure many peoples tell to you many times !
why you understand only after support team write specially for you this doc?
all is simply man!!! just use your brain - nothing else and nothing impossible!
Old 09-29-2006, 17:31   #15 (permalink)
Member: 18837
Sonork: 100.1601544
Thanks Meter: 71
i did not seen any post before speciay for c117.
can u show me that tred which is usefull for c117?.
what i did its helpfull for other infinity users. u can see one person having this same problem on this same thred.this thred started by him only.
one more thing................. if the team write specialy for me then whts the problem?
i also purchased this box from infinity team only
j100i phone is hacked djpaul Infinity-Box 32 12-15-2009 18:44
j100 phone is hacked fereemetal Sony Ericsson 4 07-29-2008 19:00
c140 phone is hacked shripalkawdia Infinity-Box 25 05-11-2007 20:22
c261 phone is hacked kulvindersingh Infinity-Box 3 03-14-2007 19:04
c117 phone is hacked ..:MumbaiGsm:.. Infinity-Box 2 01-30-2007 10:11
Page generated in 0.25697 seconds with 10 queries
