07-19-2007, 16:24 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: U-A-E Dubai---->Pak
Member: 315789 Status: Offline Thanks Meter: 3,428 | C168 Repair IMEI Failed Now set has no imei .... whenever i press *#06# no imei is shown I tried to write imei...but with following error: - Error: error flash command... try #1 to recover erase error # 43.... Writing Done What to do now ??? |
07-20-2007, 16:38 | #3 (permalink) |
Freak Poster Join Date: Jun 2007 Location: EasyLinks
Member: 520336 Status: Offline Thanks Meter: 50 | I also have same problem with c168 imei corrupt ... tried to flash it and log is below.... COM1 selected Device: C168 Checking data, wait... Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1490-000 HW ver: TCT-9- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF flash: ST M58WR064FT, M36D0R6040T0 T 8Mb error: error flash command try#1 to recover erase error#43 Write: Flex flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Write: Language Pack flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Write: Images flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Write: Melody flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Writing Done Finished, time used: 63 sec Remove/Install battery now ! ================================== and here is log for change imei .... COM1 selected Device: C168 Checking data, wait... Action: imei repair new imei: 357482001234565 Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1490-000 HW ver: TCT-9- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... error: error flash command try#1 to recover erase error#43 Writing Done Finished, time used: 39 sec Remove/Install battery now ! Still same error #43.... and imei not changed still show blank imei... What to do know ? |
07-21-2007, 14:21 | #5 (permalink) | |
Member: 520336 Status: Offline Thanks Meter: 50 | Quote:
Yes i did the same and flashed it with fw 1490 with following files.... Battery 100% full... C168_Flex_1490-013.69F C168_Images_1490-004.69G C168_LP_1490-008_En_Fr_Arabic_Farsi_Urdu.69P C168_Main_9-1490-000.69M C168_Melody_1490-004.69G But still write error #43 and same situation no imei rebuild | |
09-11-2007, 17:48 | #7 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Faisalabad, Pakistan Age: 41
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | it is not hardware. just write good repair eeprom from support area and flash it after that just repair imei and all is ok. @infinityhelp why u always take it for hardware if u not know about that? Kind regards, Vicky |
09-11-2007, 19:02 | #8 (permalink) | |
Many people even can't imagine that phone can be hardware damaged, they flash water-damaged buggy phones 1000 times, write eprom, write firmware and finally phone become totally dead. After that they cry that box killed device, but when they open phone (after 2 days of "software repair") they say to me "sorry" in ICQ (but in most cases not in public forum). I hope I have made a good explanation. | |
09-11-2007, 19:35 | #9 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | @infinityhelp yes u right for some people but if someone is confirm that is software problem but u force them that should check hardware like me about LG KG110 but i not opened phone and keep try with software and set is alive and working so u released new version as fix kg110 flashing so C168 may be soft bug coz i also try in working phone but still same problem |
09-11-2007, 19:43 | #10 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | here is log when try sp-unlock COM7 [VCP0] selected Model: Motorola C168 Action: unlock Phone must be POWERED-ON ! Connecting, wait... Phone connected. Working... imei: 0000510081000000 error: probably phone not ready, make "Prepare" operation first ! Finished IMEI is correct and also same with working phone so what u say about this problem? Kind regards, Vicky |
Z370 repair imei fail! | yungcable | Z3X-Team Products | 4 | 03-29-2012 08:27 |
D980 repair imei & flash tfs(slave) fail..... | BABAK NURI | Z3X-Team Products | 14 | 07-17-2010 15:00 |
B200 imei repair (0000) failed | neo_49 | Z3X-Team Products | 17 | 09-24-2009 08:39 |
B200 imei repair (0000) failed | neo_49 | UST Pro II | 1 | 09-21-2009 12:48 |
Lg mg160 repair imei ok but unlock fail nothing | ruchito | HWK | 5 | 05-16-2009 17:52 |
