09-23-2009, 08:10 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Back to GSM from AV
Member: 325999 Status: Offline Thanks Meter: 113 | B200 imei repair (0000) failed Phone must be ON! CONNECT PHONE TestModeOn - ok SoftWare-> B200DDHCC Langpack-> India IMEI-> Read - fail! S/N-> Read - fail! HW-> MP 0.300 Phone password-> 00000000 Sum Flash-> 1 Flash Prod ID-> 0b0 Flash Device ID-> 001d1111 Flash size-> 16777216 Bytes Flash sectors-> 131 sectors Bluetooth ID-> BT not found Status OTP-> OTP is dead ! MSL DEACTIVATED - FALSE Read info - false Elapsed time: 10 second ---> with soft version -> 3.3 beta 0008 REGARDS |
09-23-2009, 08:16 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
2nd. Status OTP-> OTP is dead ! <========== so you should repair OPT before imei repair. for this fill correct SN from phone sticker, fill imei, press OTP Repair. | |
The Following User Says Thank You to blang For This Useful Post: |
09-23-2009, 08:45 | #3 (permalink) |
Member: 325999 Status: Offline Thanks Meter: 113 | Thanx for replay fast,now i have this error Selected model: B200 Selected com port: COM9 Selected speed port: 460800 Encode *.s3 - wait... EEP saved to file-> C:\Program Files\Z3X\Samsung\All\B200_R1XQ492544L_.sre Decode *.s3 file - please wait segments 1 segment 1 00018000 8784 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader1... OK Syncing phone... OK Sending loader2... OK Syncing phone... OK Syncing phone... OK Flash ID: B00000001D00 Syncing phone... Send loaders - fail Repair OTP - false Elapsed time: 18 second, sw ver: 3.3 beta 0015 -------------------------------------------------------------- REGARDS |
09-23-2009, 08:48 | #4 (permalink) |
Member: 325999 Status: Offline Thanks Meter: 113 | Sorry my fault after right msl code otp repair working ------------------------------------------------------------------------------- Selected model: B200 Selected com port: COM9 Selected speed port: 460800 Encode *.s3 - wait... EEP saved to file-> C:\Program Files\Z3X\Samsung\All\B200_R1XQ492544L_.sre Decode *.s3 file - please wait segments 1 segment 1 00018000 8784 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader1... OK Syncing phone... OK Sending loader2... OK Syncing phone... OK Syncing phone... OK Flash ID: B00000001D00 Syncing phone... OK Sending *.s3 file... OK Repair OTP - ok Elapsed time: 12 second, sw ver: 3.3 beta 0015 ------------------------------------------------------------- now what is nex step ? REGARDS |
09-23-2009, 08:53 | #5 (permalink) | |
now check phone imei. try read info from phone. if all ok. so fill new any needed imei in imei window - press custom -> imei repair | |
09-23-2009, 09:09 | #6 (permalink) |
Member: 325999 Status: Offline Thanks Meter: 113 | Sorry but this step not working for me, Selected model: B200 Selected com port: COM9 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start repair IMEI...... SW: B200DDHCC IMEI: Read - fail! MSL DEACTIVATED - FALSE Serch msl code: 721465 Repair - false Elapsed time: 24 second, sw ver: 3.3 beta 0015 REGARDS |
09-23-2009, 10:18 | #9 (permalink) |
Member: 325999 Status: Offline Thanks Meter: 113 | Here is log Selected model: B200 Selected com port: COM9 Selected speed port: 460800 Encode *.s3 - wait... EEP saved to file-> C:\Program Files\Z3X\Samsung\All\B200_R1XQ492544L_.sre Decode *.s3 file - please wait segments 1 segment 1 00018000 8784 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader1... OK Syncing phone... OK Sending loader2... OK Syncing phone... OK Syncing phone... OK Flash ID: B00000001D00 Syncing phone... OK Sending *.s3 file... OK Repair OTP - ok Elapsed time: 13 second, sw ver: 3.3 beta 0015 ------------------------------------------------------------------------------- Selected model: B200 Selected com port: COM9 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: B200DDHCC Langpack: India IMEI: Read - fail! S/N: Read - fail! HW-> MP 0.300 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 0b0 Flash Device ID: 001d1111 Flash size: 16777216 Bytes Flash sectors: 131 sectors Bluetooth ID: BT not found Status OTP: OTP is dead ! MSL DEACTIVATED - FALSE Serch msl code: 721465 Read info - false Elapsed time: 7 second, sw ver: 3.3 beta 0015 ------------------------------------------------------------------------------- REGARDS |
The Following User Says Thank You to neo_49 For This Useful Post: |
09-23-2009, 10:47 | #10 (permalink) | |
Do you have any full working B200 in hand? | |
09-23-2009, 11:47 | #14 (permalink) | |
Member: 325999 Status: Offline Thanks Meter: 113 | Quote:
http://rapidshare.com/files/283867908/B200__FULL.rar REGARDS | |
09-23-2009, 13:58 | #15 (permalink) |
Member: 325999 Status: Offline Thanks Meter: 113 | Steel waiting for u r replay, or i have to give new set to customer ,all ready i have invested in this new box ( i have some other box to) REGARDS |
3310 Imei osn = 65656565... imei net = 0000.. | miq | Twisterflasher | 8 | 02-09-2010 06:50 |
B200 imei repair (0000) failed | neo_49 | UST Pro II | 1 | 09-21-2009 12:48 |
z540V unlock or imei repair fail ! | kimo59 | NSPRO | 0 | 01-17-2007 18:55 |
x490 BUG after flash imei only 0000 | AnToS | UST Pro II | 5 | 10-26-2006 17:15 |
J70 after change IMEI from 0000 to normal, phone still says SIM LOCKED | dannyogolo | Sony | 10 | 09-02-2003 13:36 |
