11-20-2009, 16:54 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to use this software: http://www.infinity-box.com/download...e_v2.95_v1.rar - unlock phone again - if phone still can not power-on try to make "Repair security area" operation - if phone still can not power-on flash phone with any firmware from support area and unlock phone again Waiting for your results |
11-21-2009, 08:27 | #3 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 52
Member: 130367 Status: Offline Thanks Meter: 7 | thank you for infinity team ot 708 dead and survive with infinity COM3 [VCP0] selected module v2.95 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:5903:A000 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is damaged, recalculation required rom info detection finished TCL-ID detection... TCL-ID detection done device-id: D177BE20 rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, C57C66A8 address offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 16E provider: 708X-2CALRU1 customization: CN16BN24 customization: XN16BN24 TCL-ID identification done ffs address assigned: 01800000 startup code area #1 check... flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: startup code area #1 startup code area #1 fixed sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 00006F50 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: SN16E050 customization: SN16E050 customization: XN16BN24 flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: SN16E050 customization: SN16E050 customization: XN16BN24 flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_D177BE20_A8667CC5_20 091121-082229.B0X.bin Finished, time used: 375 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to chalbi For This Useful Post: |
03-25-2010, 13:58 | #4 (permalink) |
Insane Poster Join Date: Jan 2010 Location: center of the earth <hell>
Member: 1219358 Status: Offline Sonork: misu Thanks Meter: 27 | [QUOTE=InfinitySupport;5058212]Hello, Try to use this software: http://www.infinity-box.com/download...e_v2.95_v1.rar - unlock phone again - if phone still can not power-on try to make "Repair security area" operation - if phone still can not power-on flash phone with any firmware from support area and unlock phone again -uncheck all the options -load firmware from the support area ( freesim ) is better -unlock the phone ; if the phone is still dead try to flash the phone, firmware only ( set speed auto 921k ) power on the phone and see the result for me it works |
06-23-2011, 10:58 | #6 (permalink) |
Freak Poster Join Date: Jan 2010 Location: romania Age: 33
Member: 1202098 Status: Offline Sonork: none Thanks Meter: 19 | hi i got an alcatel 708 after flash done only shown white screen? ive tried to write eeprom from another phone result same ive tried with 5-6 flash file result same ive tried repair sec zone result same can anyone help me where to go? before flash display was okay. got no any idea what else i can do. wbr. demoxx. |
Alcatel ot-708 dead? [ANSWERED] | zeemar | PolarBox 3 | 29 | 08-25-2010 21:27 |
Alcatel OT-708 dead after unlocked | godwin | Infinity-Box | 44 | 03-31-2010 13:44 |
Alcatel ot-708 dead.help plz [ANSWERED] | redpig | PolarBox 3 | 1 | 03-22-2010 17:53 |
Vodafone 541 / Alcatel OT-708 Connectivity Problem / Unlocking Problem [ANSWERED] | Mr.Ultimate | PolarBox 3 | 12 | 12-28-2009 18:40 |
Alcatel BH4 --OT 735 dead after unlocking?? | Unlocker AL | Multi-Box | 7 | 05-19-2007 08:59 |
