06-27-2016, 18:28 | #1 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1925843 Status: Offline Thanks Meter: 6 | Can Be Possible to Read pac file With CM2??? Have any way to read Symphony V85 pac file With CM2?? (It's my first post.I hope Senior Member can help me) |
06-28-2016, 03:32 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Button for convert PAC.SC to SPD FACTORY PAC exists since "Read FW" was implemented. Need moment still not come. |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
06-30-2016, 09:03 | #10 (permalink) |
Member: 1925843 Status: Offline Thanks Meter: 6 | I can't read symphony V85 pac with cm2... here is log... Card found: S/N : D09C9343 , v0130 Chinese Miracle II [SPD module] v 1.19 Operation : Read FullFlash [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 58 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:31 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.19 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 58 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:14 Reconnect Power/Cable! |
06-30-2016, 10:17 | #11 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
There are two options for SC7730..7731- Generic and A5, try with both options, with and without Alternative LDR Mode. Also try with sldr files manually. If nothing works need to select similar pac file. Br. Infinity Box Support Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
06-30-2016, 12:15 | #12 (permalink) | |
Member: 1925843 Status: Offline Thanks Meter: 6 | Quote:
Where from I can find Sldr files??? plz sir ans me. | |
06-30-2016, 12:23 | #13 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | ITS IN CM2SPD MODULE UNDER MODELS NAME. WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
