04-10-2014, 17:06 | #151 (permalink) | |
Please, in future post this kind of request and advices in this thread: http://forum.gsmhosting.com/vbb/f296...tions-1793878/ Current thread is for TECHNICAL discussion and TEST REPORTS only. Anyway here is an answer: currently we have released (Test Version) software, we must get users test reports and make many our own tests. When final software will be ready we will see how to release it for public use. | |
04-10-2014, 21:19 | #152 (permalink) |
No Life Poster Join Date: Feb 2010
Member: 1228709 Status: Offline Thanks Meter: 268 | Nokia Bocoin 302 read user code by USB. Code: Chinese Miracle II [RDA module] v 0.04 Start at : [08/04/2014 / 03:29:50 p.m.] Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 55555555 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read done, sorting EXTData Following items found : Item : NVRAM Required data found, extracting code UserCode : 82759684 Elapsed: 00:00:15 Done Reconnect Power/Cable! Finish at : [08/04/2014 / 03:30:07 p.m.] |
The Following User Says Thank You to JorgeVla For This Useful Post: |
04-11-2014, 11:08 | #154 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | sking s5888 blanking done after format don |
The Following 2 Users Say Thank You to .::TEJARAM::. For This Useful Post: |
04-12-2014, 07:30 | #155 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | YESTEL_M311 toucch problem solved after format YESTEL_M311 touch problem solved after format |
The Following 5 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
04-12-2014, 08:20 | #156 (permalink) |
No Life Poster Join Date: Jan 2014
Member: 2108593 Status: Offline Thanks Meter: 839 | format done Chinese Miracle II [RDA module] v 0.05 Start at : [4/10/2014 / 8:52:21 PM] Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU Current CPU is under test support! Make 'FlashRead' before 'Format' or 'Flash Write' operations! CPU_ID : 8808 , rev : 7000 CPU_CN : CoolSand CT , RDA8853C ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8808_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C056FC , 81C05710 CSD DR : A0000000 , A0008000 , A0010000 CSD MB : 00008000 Format Done Elapsed: 00:01:08 Reconnect Power/Cable! Finish at : [4/10/2014 / 8:53:29 PM] |
The Following 2 Users Say Thank You to chkhurram_457 For This Useful Post: |
04-12-2014, 11:22 | #157 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Indonesia(Jambi)
Member: 246444 Status: Offline Thanks Meter: 124 | sky phone 606 format error Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 25C2 , rev : 3800 FL_CNM : Macronix , MX25 FL_CAP : 00000000 ==== Booting Sending RamRun Loader... Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! |
04-12-2014, 11:22 | #158 (permalink) |
The Following User Says Thank You to vampire13 For This Useful Post: |
04-12-2014, 12:17 | #160 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Try few times with holding power button longer. Hello. Press and hold power button LONGER. | |
04-15-2014, 13:01 | #163 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hope 6700 Code: Chinese Miracle II [RDA module] v 0.06 Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 55555555 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C Boot Done! Elapsed: 00:00:11 Done Reconnect Power/Cable! Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 55555555 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : VDS0 Item : CSW Item : NVRAM Required data found, extracting code UserCode : 1234 Elapsed: 00:00:11 Done Reconnect Power/Cable! Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 55555555 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851A Target Flash : flsh_spi32m Project Name : C121D_XLD_6700_RDA8851A_U06_T7_ST3216_PCB31_QCIF_ENG_RUS_PER_FRE_ARA_HOPE_V01 Project Info : XingLongDa_C121D_6700_RDA8851A_3216_QCIF Compile Date : 20130705Fri1401 [BIN] Saved as : C121D_XLD_6700_RDA8851A_U06_T7_ST3216_PCB31_QCIF_ENG_RUS_PER_FRE_ARA_HOPE_V01_XingLongDa_C121D_6700_RDA8851A_3216_QCIF_CT8851A_flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\Users\Kurt Irving\Desktop\RDA\Flash\IFF\C121D_XLD_6700_RDA8851A_U06_T7_ST3216_PCB31_QCIF_ENG_RUS_PER_FRE_ARA_HOPE_V01_XingLongDa_C121D_6700_RDA8851A_3216_QCIF_CT8851A_flsh_spi32m.iff [CAL] File saved to : C:\Users\Kurt Irving\Desktop\RDA\Flash\IFF\C121D_XLD_6700_RDA8851A_U06_T7_ST3216_PCB31_QCIF_ENG_RUS_PER_FRE_ARA_HOPE_V01_XingLongDa_C121D_6700_RDA8851A_3216_QCIF_CT8851A_flsh_spi32m.ifc Build done Done Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 55555555 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05CA8 , 81C05CBC CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:00:19 Reconnect Power/Cable! Load file... IFF (MCU) : C121D_XLD_6700_RDA8851A_U06_T7_ST3216_PCB31_QCIF_ENG_RUS_PER_FRE_ARA_HOPE_V01_XingLongDa_C121D_6700_RDA8851A_3216_QCIF_CT8851A_flsh_spi32m.iff Target BbCpu : CT8851A Target Flash : flsh_spi32m Project Name : C121D_XLD_6700_RDA8851A_U06_T7_ST3216_PCB31_QCIF_ENG_RUS_PER_FRE_ARA_HOPE_V01 Project Info : XingLongDa_C121D_6700_RDA8851A_3216_QCIF Compile Date : 20130705Fri1401 Load Ok Load file... IFC (CALIB) : C121D_XLD_6700_RDA8851A_U06_T7_ST3216_PCB31_QCIF_ENG_RUS_PER_FRE_ARA_HOPE_V01_XingLongDa_C121D_6700_RDA8851A_3216_QCIF_CT8851A_flsh_spi32m.ifc Load Ok Operation : Flash ======= Settings Settings : BIN : NVwrite Disabled Settings : Factory Settings Enabled ======= Flash Files set for flashing : [ MCU ] : C121D_XLD_6700_RDA8851A_U06_T7_ST3216_PCB31_QCIF_ENG_RUS_PER_FRE_ARA_HOPE_V01_XingLongDa_C121D_6700_RDA8851A_3216_QCIF_CT8851A_flsh_spi32m.iff [ CFP ] : C121D_XLD_6700_RDA8851A_U06_T7_ST3216_PCB31_QCIF_ENG_RUS_PER_FRE_ARA_HOPE_V01_XingLongDa_C121D_6700_RDA8851A_3216_QCIF_CT8851A_flsh_spi32m.ifc Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 5755755D Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! ======= Flashing MCU Processing file : C121D_XLD_6700_RDA8851A_U06_T7_ST3216_PCB31_QCIF_ENG_RUS_PER_FRE_ARA_HOPE_V01_XingLongDa_C121D_6700_RDA8851A_3216_QCIF_CT8851A_flsh_spi32m.iff CSD WR : 81C05CA8 , 81C05CBC CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Flash Done ======= Flashing CFP Processing file : C121D_XLD_6700_RDA8851A_U06_T7_ST3216_PCB31_QCIF_ENG_RUS_PER_FRE_ARA_HOPE_V01_XingLongDa_C121D_6700_RDA8851A_3216_QCIF_CT8851A_flsh_spi32m.ifc CSD WR : 81C05CA8 , 81C05CBC CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Flash Done ======= Setting Factory Defaults NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Format User Area ... CSD WR : 81C05CA8 , 81C05CBC CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:00:41 Reconnect Power/Cable! |
The Following User Says Thank You to Dzirt For This Useful Post: |
04-15-2014, 16:23 | #165 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | READ user code done Card found: S/N Chinese Miracle II [RDA module] v 0.06 Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : NVRAM Required data found, extracting code UserCode : 4545 Elapsed: 00:00:43 Done Reconnect Power/Cable! |
The Following User Says Thank You to sultan_ For This Useful Post: |
